On 27/11/2020 20:33, Ray West wrote:
Hi Torsten,
My mistake - it's Cura, and other slicers I guess, that do not send
G3, G2. Which means that 'stuttering' can occur, due to the serial
port not keeping up with the multitude of small steps being sent.
Best wishes,
RTay
On 27/11/2020 19:38, Torsten Paul wrote:
On 27.11.20 20:13, Ray West wrote:
It is only recently that Marlin (a common 3d printer firmware) is
going to be able to handle G2,G3 commands (and then a circle will
be a number of micro-steps...)
That's 2015: https://github.com/MarlinFirmware/Marlin/pull/2469
and G2/G3 support for cartesian printers goes back to maybe 2011
or so.
It's probably not used a lot as the earlier parts of the tool
chain rarely generate those. In my totally personal opinion that
is not a critical issue. I've always saw much more potential
gain in other topics and that is still the case.
Yeah, we need better comms from the RPi.
klipper and a fast 32-bit control board get closer due to the higher
apparent bit-rates transferred.
Hi Torsten,
Best wishes,
RTay
or so.
