2D SVG Export
F
fractorr
Wed, Jul 19, 2017 9:18 PM
This is probably a silly question but I am going to ask anyway.
I have created a library that allows me to basically generate 3D cubes with
some holes through the cubes and I can pass various parameters for width,
length and thickness of the cube.  I was looking at having some pieces laser
cut out of metal but the company requires flat 2D SVG files.  Without
rewriting my library is there any way to generate a SVG from what I have?
View this message in context: http://forum.openscad.org/2D-SVG-Export-tp21870.html
This is probably a silly question but I am going to ask anyway. I have created a library that allows me to basically generate 3D cubes with some holes through the cubes and I can pass various parameters for width, length and thickness of the cube. I was looking at having some pieces laser cut out of metal but the company requires flat 2D SVG files. Without rewriting my library is there any way to generate a SVG from what I have? -- View this message in context: http://forum.openscad.org/2D-SVG-Export-tp21870.html Sent from the OpenSCAD mailing list archive at Nabble.com.
F
fred_dot_u
Wed, Jul 19, 2017 9:34 PM
I'm not so sure about the not-rewriting part, as some code is necessary to
accomplish your objective.
The projection() feature will allow you to create an outline as if one had a
parallel light beam directly over the model and traced the shadow. One can
translate, rotate, scale as desired to develop the necessary section of the
model to outline.
The summary is located in the  wiki manual
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/3D_to_2D_Projection
and is quite easy to understand.
Experiment with various locations/rotations and cut=true or cut=false.
The export menu entry supports SVG files. I was able to create a couple test
files and open them in Inkscape.
View this message in context: http://forum.openscad.org/2D-SVG-Export-tp21870p21871.html
I'm not so sure about the not-rewriting part, as some code is necessary to accomplish your objective. The projection() feature will allow you to create an outline as if one had a parallel light beam directly over the model and traced the shadow. One can translate, rotate, scale as desired to develop the necessary section of the model to outline. The summary is located in the wiki manual <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/3D_to_2D_Projection> and is quite easy to understand. Experiment with various locations/rotations and cut=true or cut=false. The export menu entry supports SVG files. I was able to create a couple test files and open them in Inkscape. -- View this message in context: http://forum.openscad.org/2D-SVG-Export-tp21870p21871.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jul 19, 2017 10:16 PM
You can use projection() to convert a 3D object to 2D and then export an
SVG.
laser
You can use projection() to convert a 3D object to 2D and then export an SVG. On 19 July 2017 at 22:18, fractorr <fractorr@gmail.com> wrote: > This is probably a silly question but I am going to ask anyway. > > I have created a library that allows me to basically generate 3D cubes with > some holes through the cubes and I can pass various parameters for width, > length and thickness of the cube. I was looking at having some pieces > laser > cut out of metal but the company requires flat 2D SVG files. Without > rewriting my library is there any way to generate a SVG from what I have? > > > > > -- > View this message in context: http://forum.openscad.org/2D- > SVG-Export-tp21870.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
F
fractorr
Wed, Jul 19, 2017 10:20 PM
That is exactly what I need!!!!!  And only adding 1 line of code!!!!!
OpenSCAD never ceases to amaze me with what you can do with it.
View this message in context: http://forum.openscad.org/2D-SVG-Export-tp21870p21873.html
That is exactly what I need!!!!! And only adding 1 line of code!!!!! OpenSCAD never ceases to amaze me with what you can do with it. -- View this message in context: http://forum.openscad.org/2D-SVG-Export-tp21870p21873.html Sent from the OpenSCAD mailing list archive at Nabble.com.
