This code:
scale([1, 1, 0.1])
surface(file = "softfold.png", center = true, invert = true);
produces this output:
WARNING: PolySet has degenerate polygons
and no object appears onscreen.
Here's the file:
softfold.png http://forum.openscad.org/file/n20889/softfold.png
View this message in context: http://forum.openscad.org/Trying-to-import-2D-object-tp20889.html
On 14. mars 2017 22:10, jazzjohn wrote:
This code:
scale([1, 1, 0.1])
Here's the file:
I would add some margins to that file, the object touches the image
edges. Depending on the algorithm, it could cause problems. I would also
reduce the image size by half or more, as the surface command really
eats memory.
If you want to create solids from such images, there are several ways to
do it, the surface command may not always be the best or easiest. See
attached file for the result of an alternative approach.
Very nice!
Is your generator available?
Thank you!
View this message in context: http://forum.openscad.org/Trying-to-import-2D-object-tp20889p20892.html
On 14. mars 2017 23:33, jazzjohn wrote:
Very nice!
Thank you!
It will be considered after I manage to publish some other code (based
on Carve), but right now it isn't. It works well on many images (white
foreground, black background, 1bit PNG), but if you don't know how it
works it is easy to screw up. Some polishing needed.
