The transparent segments are a rendering glitch associated with convexity.
Although convexity is best known as an issue for linear_extrude, render,
and STL import, it affects any case where CGAL gets involved in the
rendering and can return a concave object. In this case, minkowski() is
the culprit. Although the convexity parameter is not documented for
minkowski(), it is implemented. Changing the minkowski() invocation
to set convexity - I used 5, but that's probably overkill - makes the
glitch go away.
minkowski(), it *is* implemented. Changing the minkowski() invocation
glitch go away.
