RobWLakes wrote
I chose to disregard the answer.
Is OpenSCAD the best language to extend OpenSCAD? How much do we multiply
failings? I don't have confidence in that idea given OpenSCAD's intrinsic
structural, functionsl and variable access limitations. Yes, some exotic
things can be done(most impressive libraries), but are they elegant , and
an extension most users can appreciate and further build on?
Just to clarify what you are talking about...
Are you talking about the language OpenSCAD is written in, or the language
used for generating objects?
I think the argument for OpenSCAD in a Python environment addresses the
fundimental dilemma of not just improving the functions that the OpenSCAD
paradigm defines, but the language structures that support it.
Clinging to the OpenSCAD language to support itself(no limitation to the
truly inspired) is fine for some, but a huge wall to scale for so many
other potential contributors.
Personally, I don't care much about what language OpenSCAD is written in. I
just care that it runs on my machines. The only thing I have against Python
being the language it is written in, is if it would require me to use Python
to write libraries, because, frankly, I really don't like Python, and only
have it on my machine to do a few things that absolutely require it.
If you are speaking of the OpenSCAD language itself, I would suggest to you
that if you really want that, to either rewrite it yourself or recruit a
team to do it, leaving the current OpenSCAD as-is, for those of us who will
not use Python syntax unless we are forced into it.
I share the distaste with the python syntax, and anything that uses
whitespace for block structuring, like yaml etc. When working with
kubernetes the biggest pain in the ass is getting the block nesting in yaml
files wrong.
intrinsic
Python
