Preview OK, Render gets only half
rcadmus
Mon, Jun 7, 2021 1:07 AM
The file is a QR code svg.  Everything shows in preview but only the box part
is rendered.
// Basic square coaster -
translate ([-52,-53,0]) resize([90,90,0])
linear_extrude(height = 2){
import(file = "/home/ray/stupidPeople.svg");
cube([100,100,4],center=true);
translate([0,0,2])
cube([94,94,4],center=true);;
The file is a QR code svg. Everything shows in preview but only the box part is rendered. // Basic square coaster - translate ([-52,-53,0]) resize([90,90,0]) linear_extrude(height = 2){ import(file = "/home/ray/stupidPeople.svg"); } difference(){ cube([100,100,4],center=true); translate([0,0,2]) cube([94,94,4],center=true);; } -- Sent from: http://forum.openscad.org/
Mon, Jun 7, 2021 1:17 AM
I expect resize() to z=0 renders as nothing.
I expect resize() to z=0 renders as nothing. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
rcadmus
Mon, Jun 7, 2021 1:22 AM
Made sense - so I changed it .  No effect on render,  made it bigger on
preview...
Made sense - so I changed it . No effect on render, made it bigger on preview... -- Sent from: http://forum.openscad.org/
Mon, Jun 7, 2021 1:24 AM
Oops, RTFM.
Can you share the .svg?
Oops, RTFM. Can you share the .svg? ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Mon, Jun 7, 2021 1:29 AM
MichaelAtOz wrote
Oops, RTFM.
That was meant to me BTY. z=0 is ignored. So the .svg may have issues.
MichaelAtOz wrote > Oops, RTFM. That was meant to me BTY. z=0 is ignored. So the .svg may have issues. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
rcadmus
Workaround...
Each section will render by itself so I am creating 2 .stl's and merging
them in the slicer.  A pain but working for now but I really would like to
know what I may be doing wrong.  Thanks for trying to help.
Workaround... Each section will render by itself so I am creating 2 .stl's and merging them in the slicer. A pain but working for now but I really would like to know what I may be doing wrong. Thanks for trying to help. -- Sent from: http://forum.openscad.org/
rcadmus
Mon, Jun 7, 2021 1:32 AM
stupidPeople.svg <http://forum.openscad.org/file/t3243/stupidPeople.svg> -- Sent from: http://forum.openscad.org/
Mon, Jun 7, 2021 8:44 AM
I'm no expert in SVG, when I just do
import(file = "stupidPeople.svg");
cube(20); // forces CGAL render
I get
CGAL_Nef_Polyhedron.
That could be a few things, but I think the problem is the QR code has
2d corners which meet at a single point.
http://forum.openscad.org/file/t359/Capture_-_svg_non_manifold.jpg
They are non-manifold.
A work around is to use offset() which will change the just-touch into
just-embedded.
It takes longer to render.
resize([90,90,0])
offset(delta=0.001)
translate([0,0,2])
I'm no expert in SVG, when I just do linear_extrude(height = 2){ import(file = "stupidPeople.svg"); } cube(20); // forces CGAL render I get Compiling design (CSG Tree generation)... Rendering Polygon Mesh using CGAL... ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron. That could be a few things, but I think the problem is the QR code has 2d corners which meet at a single point. <http://forum.openscad.org/file/t359/Capture_-_svg_non_manifold.jpg> They are non-manifold. A work around is to use offset() which will change the just-touch into just-embedded. It takes longer to render. // Basic square coaster - translate ([-52,-53,0]) resize([90,90,0]) linear_extrude(height = 2){ offset(delta=0.001) import(file = "stupidPeople.svg"); } difference(){ cube([100,100,4],center=true); translate([0,0,2]) cube([94,94,4],center=true);; } ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Mon, Jun 7, 2021 8:45 AM
A QR code has lots of squares sharing one corner, which will not create a
2-manifold 3D object.  Try offsetting by a small amount. A small positive
amount will make the meeting points have finite thickness. A small negative
offset will make a tiny gap.
On Mon, 7 Jun 2021 at 02:32, rcadmus rcadmus@gmail.com wrote:
stupidPeople.svg http://forum.openscad.org/file/t3243/stupidPeople.svg
at Nabble.com.
A QR code has lots of squares sharing one corner, which will not create a 2-manifold 3D object. Try offsetting by a small amount. A small positive amount will make the meeting points have finite thickness. A small negative offset will make a tiny gap. On Mon, 7 Jun 2021 at 02:32, rcadmus <rcadmus@gmail.com> wrote: > stupidPeople.svg <http://forum.openscad.org/file/t3243/stupidPeople.svg> > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
RC
Ray Cadmus
Mon, Jun 7, 2021 3:16 PM
That did it.  Thank you very much.  I won't pretend to fully understand
why,  but I will accept that it works.
Thanks,
Ray
I get
just-embedded.
  resize([90,90,0])
        offset(delta=0.001)
    translate([0,0,2])
OpenSCAD Admin - email me if you need anything, * or if I've done
something stupid...
  • on the Forum, click on my MichaelAtOz label, there is a link to
    email me.
Public Domain;
the above.
That did it.  Thank you very much.  I won't pretend to fully understand why,  but I will accept that it works. Thanks, Ray -- On 6/7/21 3:44 AM, MichaelAtOz wrote: > I'm no expert in SVG, when I just do > > linear_extrude(height = 2){ >   import(file = "stupidPeople.svg"); > } > cube(20); // forces CGAL render > > I get > > Compiling design (CSG Tree generation)... > Rendering Polygon Mesh using CGAL... > ERROR: The given mesh is not closed! Unable to convert to > CGAL_Nef_Polyhedron. > > That could be a few things, but I think the problem is the QR code has > 2d corners which meet at a single point. > > > > They are non-manifold. > > A work around is to use offset() which will change the just-touch into > just-embedded. > It takes longer to render. > > // Basic square coaster - > translate ([-52,-53,0]) >   resize([90,90,0]) >     linear_extrude(height = 2){ >         offset(delta=0.001) >           import(file = "stupidPeople.svg"); >     } > difference(){ >     cube([100,100,4],center=true); >     translate([0,0,2]) >        cube([94,94,4],center=true);; > } > *OpenSCAD Admin - email* me if you need anything, * or if I've done > something stupid... > * on the Forum, click on my MichaelAtOz label, there is a link to > email me. > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; > to the extent possible under law, I have waived all copyright and > related or neighbouring rights to this work. > Obviously inclusion of works of previous authors is not included in > the above. > > ------------------------------------------------------------------------ > Sent from the OpenSCAD mailing list archive > <http://forum.openscad.org/> at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
