Ah you're using a delta printer. With this type of printer it is very
important to set up the right geometry in Configuration.h. Otherwise
nonlinear distorsions and strange scaling problems will occur.
You can test (and adjust) distorsions and scaling by sending gcode like
; home
G28
; set to millimeters
G21
; goto xyz (0,100,0) with speed 8000
G1 X00.0 Y100.0 Z0.0 F8000
to your printer, using some mm paper or a tape measure taped to the
headbead. Test positions like
(0,100,0), (100,100,0), (100,0,0), (0,-100,0), (-100,-100,0), (-100,0,0)
(0,50,0), (50,50,0), (50,0,0), (0,-50,0), (-50,-50,0), (-50,0,0)
and adjust geometry measures, until your positioning is perfect - i.e. your
printer reproduces all tested positions with high accuracy.
Also have a look into the G-code your slicer produces. Slicers usually offer
parameters to do some (minimal) inset/outset compensations. Also they
calculate an extrusion width. Printing a 60x60 square might produce gcode
like this:
G1 X29.65 Y29.65 E20.9915 F5400
with .6 mm extrusion width.
View this message in context: http://forum.openscad.org/Scaling-and-3D-Printing-Questions-tp17161p17170.html
