parameterized export file name
D
dinther
Fri, Mar 5, 2021 4:25 AM
Hi I am Paul, new to this forum. I use openSCAD for all my FDM 3D print
designs and as such iterate through designs rapidly with changing parameters
to get parts to fit just right.
For example: A shaft adapters external diameter needs to fit tightly in a
wheel housing and the inside diameter must fit tightly around a motor shaft.
Let's call the project "adapter.scad" with two parameters called od and an
id
I render the project with od = 8.25 and id = 5.13 then export the STL file.
The default STL filename is the project name followed by ".stl" like
"adapter.stl" and currently I manually rename it by adding the parameter
values to the filename. eg: "adapter_8.25_5.13.scad"
This helps me a lot to keep track of what files worked. We could have
arguments about version control and appropriate annotation but for my one
man operation version control get's in the way. I read the thread about the
proposed export() function and I understand the objections and risks.
What I think would be extremely helpful is the ability to define the
filename or a suffix to the file name in code while the actual export action
is only triggered by the UI as it is now. For example:
$suffix = str("_od", od, "_id", id);
Then, when I click on export STL the default filename will appear as
"adapter_8.25_5.13.scad". I so hope I haven't missed anything in the manual
that could be helpful for this but I am keen to hear how this can help.
Hi I am Paul, new to this forum. I use openSCAD for all my FDM 3D print designs and as such iterate through designs rapidly with changing parameters to get parts to fit just right. For example: A shaft adapters external diameter needs to fit tightly in a wheel housing and the inside diameter must fit tightly around a motor shaft. Let's call the project "adapter.scad" with two parameters called od and an id I render the project with od = 8.25 and id = 5.13 then export the STL file. The default STL filename is the project name followed by ".stl" like "adapter.stl" and currently I manually rename it by adding the parameter values to the filename. eg: "adapter_8.25_5.13.scad" This helps me a lot to keep track of what files worked. We could have arguments about version control and appropriate annotation but for my one man operation version control get's in the way. I read the thread about the proposed export() function and I understand the objections and risks. What I think would be extremely helpful is the ability to define the filename or a suffix to the file name in code while the actual export action is only triggered by the UI as it is now. For example: $suffix = str("_od", od, "_id", id); Then, when I click on export STL the default filename will appear as "adapter_8.25_5.13.scad". I so hope I haven't missed anything in the manual that could be helpful for this but I am keen to hear how this can help. -- Sent from: http://forum.openscad.org/
Fri, Mar 5, 2021 10:46 PM
Sounds reasonable to me.
Note that depending on your exact application, you may be able to
achieve the same goals by wrapping a script around a non-interactive
invocation of OpenSCAD.  If you know that you need six different ID/OD
combinations, have a script invoke OpenSCAD six times, writing the
resulting STL to six different output files.
On 3/4/2021 8:25 PM, dinther wrote: > $suffix = str("_od", od, "_id", id); Sounds reasonable to me. Note that depending on your exact application, you may be able to achieve the same goals by wrapping a script around a non-interactive invocation of OpenSCAD.  If you know that you need six different ID/OD combinations, have a script invoke OpenSCAD six times, writing the resulting STL to six different output files.
Sat, Mar 6, 2021 4:27 AM
If this is done, it should probably conceptually include a prefix.
Some additional information would be useful to construct a filename:
  • date
  • time
  • filename
  • etc
Possibly from a function, say system(), e.g.
fn = system("filename");
dt = system("now"); // date-time
combine both into something like
$filename = str("prefix",fn, "_", dt,"_suffix");
There a many issues on GitHub asking for 'system' type information, e.g.
https://github.com/openscad/openscad/issues/339 -
https://github.com/openscad/openscad/issues/380 - includes my raving late
night thoughts...
https://github.com/openscad/openscad/pull/2741 - proposed waiting for
'Objects'
https://github.com/openscad/openscad/issues/2755 - seem to be the continuing
issue
My request for a  more detailed version()
https://github.com/openscad/openscad/issues/3593  , proposes a structured
vector as the result of a version_info() function.
Such could be part of a larger structure combining version details and
external info (date, time, etc).
But that is getting unwieldy, so maybe it returns subsets
v=system("version");
dt=system("date-time");
OK, I'll stop here.
JordanBrown wrote > On 3/4/2021 8:25 PM, dinther wrote: >> $suffix = str("_od", od, "_id", id); > > Sounds reasonable to me. If this is done, it should probably conceptually include a prefix. Some additional information would be useful to construct a filename: - date - time - filename - etc Possibly from a function, say system(), e.g. fn = system("filename"); dt = system("now"); // date-time combine both into something like $filename = str("prefix",fn, "_", dt,"_suffix"); There a many issues on GitHub asking for 'system' type information, e.g. https://github.com/openscad/openscad/issues/339 - https://github.com/openscad/openscad/issues/380 - includes my raving late night thoughts... https://github.com/openscad/openscad/pull/2741 - proposed waiting for 'Objects' https://github.com/openscad/openscad/issues/2755 - seem to be the continuing issue My request for a more detailed version() <https://github.com/openscad/openscad/issues/3593> , proposes a structured vector as the result of a version_info() function. Such could be part of a larger structure combining version details and external info (date, time, etc). But that is getting unwieldy, so maybe it returns subsets v=system("version"); dt=system("date-time"); OK, I'll stop here. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Sat, Mar 6, 2021 5:39 AM
Since it's only a suggestion, a default for a following "Export as",
perhaps it can be the entire suggested name.  Probably less file type,
to be filled in by the selected "Export as".  Probably not allowing
directories.
  • date
  • time
  • filename
  • etc
<bikeshed> Sounds like a fine idea, but I would use a different name.  You said system(something) and my mind immediately went to the C library system() function, which executes another program. </bikeshed>
On 3/5/2021 8:27 PM, MichaelAtOz wrote: > > JordanBrown wrote > On 3/4/2021 8:25 PM, dinther wrote: > > $suffix = str("_od", od, "_id", id); > > Sounds reasonable to me. > > If this is done, it should probably conceptually include a prefix. Since it's only a suggestion, a default for a following "Export as", perhaps it can be the entire suggested name.  Probably less file type, to be filled in by the selected "Export as".  Probably not allowing directories. > Some additional information would be useful to construct a filename: > - date > - time > - filename > - etc > > Possibly from a function, say system(), e.g. <bikeshed> Sounds like a fine idea, but I would use a different name.  You said system(something) and my mind immediately went to the C library system() function, which executes another program. </bikeshed>
D
dinther
Tue, Mar 9, 2021 5:00 AM
Well, we are using a programming language so I figure since the user still
initiates the export and confirms the file name, the feature might as well
allow full definition in code and not just a suffix. That keeps clutter to a
minimum and we can juggle what ever data we want into the file name.
Well, we are using a programming language so I figure since the user still initiates the export and confirms the file name, the feature might as well allow full definition in code and not just a suffix. That keeps clutter to a minimum and we can juggle what ever data we want into the file name. -- Sent from: http://forum.openscad.org/
WF
William F. Adams
Wed, Mar 10, 2021 3:21 AM
Agreed, and I'd like to see that logic extended to text files as well.
Sent: Tue, Mar 9, 2021 12:00 am
Subject: Re: [OpenSCAD] parameterized export file name
Agreed, and I'd like to see that logic extended to text files as well. -----Original Message----- From: dinther <vandinther@gmail.com> To: discuss@lists.openscad.org Sent: Tue, Mar 9, 2021 12:00 am Subject: Re: [OpenSCAD] parameterized export file name Well, we are using a programming language so I figure since the user still initiates the export and confirms the file name, the feature might as well allow full definition in code and not just a suffix. That keeps clutter to a minimum and we can juggle what ever data we want into the file name. Sent from the OpenSCAD mailing list archive at Nabble.com. _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Wed, Mar 10, 2021 4:00 AM
Text files don't have an "export" mechanism that the user invokes and
confirms.
In my earlier comments, I was thinking of the interactive "export"
operation.  I don't know how this hypothetical feature would interact
with command-line usage, or if it should.
On 3/9/2021 7:21 PM, William F. Adams via Discuss wrote: > Agreed, and I'd like to see that logic extended to text files as well. Text files don't have an "export" mechanism that the user invokes and confirms. In my earlier comments, I was thinking of the interactive "export" operation.  I don't know how this hypothetical feature would interact with command-line usage, or if it should.
