Re: [OpenSCAD] rotations not showing as commutative
Mon, Nov 21, 2016 4:28 PM
Subject: rotations not showing as commutative
If we apply two rotations to an object, then the resulting object position
should be the same as if the rotations are applied simultaneously.
Rotation in 3 dimensions isn’t commutative unless you limit yourself to a single axis.
The order of the individual rotation operations matter.
In OpenSCAD rotate([a,b,c]) is equivalent to rotate([0,0,c]) rotate([0,b,0]) rotate([a,0,0])
> > From: alphlim <safarat@cardiff.ac.uk> > Subject: rotations not showing as commutative > If we apply two rotations to an object, then the resulting object position > should be the same as if the rotations are applied simultaneously. > Rotation in 3 dimensions isn’t commutative unless you limit yourself to a single axis. The order of the individual rotation operations matter. In OpenSCAD rotate([a,b,c]) is equivalent to rotate([0,0,c]) rotate([0,b,0]) rotate([a,0,0]) -Marius
