Re: CND milling machine
Roger Whiteley
Mon, Nov 6, 2023 3:12 PM
You can if you don't mind steps at the ends, indexing the cutter up and
across, not unlike a 3D printer would. In micro steps to achieve the
desired angle.
If you want a flat surface at each end you'll need to be able to rotate
the head of the machine to the desired angle, than cut the end faces
with an end mill OR cutting the shape in three settings.
If you have access to a tilting vice you could use that.
Alternatively, make a setting jig to keep your part at the correct angle
in the vice, if there is too much sticking out of the vice you will get
a lot of chatter or vibration as the part bends under the cutting
loads.  Machine one then, then turn it round and machine the other.
With slow feeds, a new cutter and small depths of cut you will probably
get away with it.
I used to make objects like this on a lathe with the part held in a
vertical slide and the milling cutter in the chuck, which is yet another
way :-).
HTH Roger.
You can if you don't mind steps at the ends, indexing the cutter up and across, not unlike a 3D printer would. In micro steps to achieve the desired angle. If you want a flat surface at each end you'll need to be able to rotate the head of the machine to the desired angle, than cut the end faces with an end mill OR cutting the shape in three settings. If you have access to a tilting vice you could use that. Alternatively, make a setting jig to keep your part at the correct angle in the vice, if there is too much sticking out of the vice you will get a lot of chatter or vibration as the part bends under the cutting loads.  Machine one then, then turn it round and machine the other.  With slow feeds, a new cutter and small depths of cut you will probably get away with it. I used to make objects like this on a lathe with the part held in a vertical slide and the milling cutter in the chuck, which is yet another way :-). HTH Roger.
WF
William F. Adams
Mon, Nov 6, 2023 4:07 PM
On Monday, November 6, 2023 at 10:12:57 AM EST, Roger Whiteley via Discuss discuss@lists.openscad.org wrote:
an excellent point.
Workholding and fixturing are a huge part of CNC, two excellent books on that are:
https://www.goodreads.com/book/show/53168863-jigs-and-fixtures
andhttps://www.goodreads.com/book/show/5042096-jig-and-fixture-handbook
On Monday, November 6, 2023 at 10:12:57 AM EST, Roger Whiteley via Discuss <discuss@lists.openscad.org> wrote: >If you have access to a tilting vice you could use that. an excellent point. Workholding and fixturing are a huge part of CNC, two excellent books on that are: https://www.goodreads.com/book/show/53168863-jigs-and-fixtures andhttps://www.goodreads.com/book/show/5042096-jig-and-fixture-handbook William
Mon, Nov 6, 2023 4:57 PM
You could also use a chamfering router bit if the angle is a common one
like 45 degrees and perhaps multiple passes.
On Mon, 6 Nov 2023, 16:09 William F. Adams via Discuss, <
an excellent point.
that are:
and
You could also use a chamfering router bit if the angle is a common one like 45 degrees and perhaps multiple passes. On Mon, 6 Nov 2023, 16:09 William F. Adams via Discuss, < discuss@lists.openscad.org> wrote: > On Monday, November 6, 2023 at 10:12:57 AM EST, Roger Whiteley via Discuss > <discuss@lists.openscad.org> wrote: > > >If you have access to a tilting vice you could use that. > > an excellent point. > > Workholding and fixturing are a huge part of CNC, two excellent books on > that are: > > https://www.goodreads.com/book/show/53168863-jigs-and-fixtures > and > https://www.goodreads.com/book/show/5042096-jig-and-fixture-handbook > > William > > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
KE
karl.exler (at) meinklang.cc
Tue, Nov 7, 2023 6:13 AM
excuse me, bit making 3 tumbles and one handstand to read a book is too complicated. "Goodread" is for non native speaker not very user friendly...
But thanknyou anyway for the hint
Regards
Karl
Am 6. November 2023 17:07:57 MEZ schrieb "William F. Adams via Discuss" discuss@lists.openscad.org:
an excellent point.
Diese Nachricht wurde von unterwegs gesendet...
excuse me, bit making 3 tumbles and one handstand to read a book is too complicated. "Goodread" is for non native speaker not very user friendly... But thanknyou anyway for the hint Regards Karl Am 6. November 2023 17:07:57 MEZ schrieb "William F. Adams via Discuss" <discuss@lists.openscad.org>: > On Monday, November 6, 2023 at 10:12:57 AM EST, Roger Whiteley via Discuss <discuss@lists.openscad.org> wrote: > > >If you have access to a tilting vice you could use that. > >an excellent point. >Workholding and fixturing are a huge part of CNC, two excellent books on that are: >https://www.goodreads.com/book/show/53168863-jigs-and-fixtures >andhttps://www.goodreads.com/book/show/5042096-jig-and-fixture-handbook > >William > > > -- Diese Nachricht wurde von unterwegs gesendet...
