On 11/11/23 15:04, Rogier Wolff wrote:
On Fri, Nov 10, 2023 at 08:18:13PM -0500, gene heskett via Discuss wrote:
Ok, I've done that and it works up to a final target of .90 but
fails for target values of 1.0 and up.  So what I and going to do is
use that basic code and add an offset to the var i to make the rest
of this up to about 4.0. What I'm making is a gauge set, with the
buttress thread increasing from a starter value to that + the amount
printed on the tab.
    In openscad it might be better to just structure your loops with an
integer as a loop parameter if you want to do this kind of stuff.
So instead of:
for (x=[.10:.10:1.5])
  for (y=[.15:.15:1.5]) {
    if (x % .20) ...
you do:
for (ix=[1:1:15])
  for (iy=[1:1:10]) {
    x = ix * .10;
    y = iy * .15
    if (ix % 2) ...
Good, practical advice Roger, I'll try to remember it next time I do
some repetitive thing that increments a size or???  This may not be
optimum, but I do have it working.  And about to start my 2nd run with a
new printer, an  QIDI X-MAX3, a heavy beast with a 325mm*3 build volume,
runs klipper FAST by remote control.  And sorting a slicer I've never
seen before, a bit like sorting rattlesnakes.  If I don't get bit, a
don't learn...
Thank, take care & stay well.
    Cheers, Gene Heskett.
>> printed on the tab.
> So instead of:
>        if (x % .20) ...
> you do:
>    for (ix=[1:1:15])
>      for (iy=[1:1:10]) {
>        x = ix * .10;
>        y = iy * .15
>        if (ix % 2) ...
don't learn...
> Roger.
  - Louis D. Brandeis
