On 2020-04-07 12:28 p.m., Torsten Paul wrote:
On 07.04.20 16:52, Ron Wheeler via Discuss wrote:
If accessing hidden implementation details becomes a
common practice needed by many users of an API, then
the parts of the implementation that are needed should
be formally exposed in the API and documented.
Agreed, and that's what happens. The type test functions
are a good example.
Not really the case that I was talking about.
My point is really about an accidental misunderstanding
of the API resulting from an unintended behavior that
violates the intention of the API and is not documented
officially but has crept into the folklore of the user
community.
I don't follow. It just makes it harder to change/fix,
but otherwise the issue is the same. Extra promotion
of the unintended use does not seem useful, instead
a deprecation warning might be the only way forward.
That would apply if you offer an alternative function with a different
signature and really and truly intend to remove the function in a future
release.
I have never heard of deprecating an undocumented part of a documented
function.
"We have heard that some people have found a way to use this function in
an undocumented way to rotate the entire model rather than just the
included parts by adding 1000 to each of the axis rotation coordinates.
This usage is deprecated, please stop."
At the start of this discussion, I thought that we were talking about
people using an undocumented behavior of an otherwise useful feature.
Probably to take advantage of a useful but undocumented side effect that
had somehow become known to the community.
I would expect that the fix would be to either fix the description to
include the undocumented behavior in the official description or warn
people that a certain behavior is considered to be a bug (Issue xx) and
may cease to happen in a future release.
I would not consider this to be promotion except to people who want to
build landmines into their application that will explode at some future
date without warning except in the release notes(if they are lucky).
Anyone who would do this to themselves deserves whatever happens and
have no moral right to complain when it does.
Ron
Ron Wheeler
Artifact Software
438-345-3369
Give you that one!
Ron
On 2020-04-07 2:20 p.m., Jordan Brown wrote:
On 4/7/2020 5:58 AM, Ron Wheeler via Discuss wrote:
Isn't "observed behavior that is not part of the designed
functionality" the actual definition of a bug.
No (and in a different way than Torsten mentioned). Often there will
be cases that are formally undefined behavior, where the observed
behavior is something that you might want to rely on. For instance, in
JavaScript the order of enumeration of the elements of an object is
formally undefined, but in some implementations it is reliably the
same as the order that the elements were added. It's very easy to
accidentally depend on this behavior, or to deliberately depend on it
without realizing that it's not a designed-in feature.
Ron Wheeler
Artifact Software
438-345-3369
But you said that when you want a face that's a different color you union
on a thin sliver of the other color.
Yes but only for vitamins that show in preview. They don't even have to be
manifold, they just have to look the part. Anything I output as a 2D or 3D
model to CNC route or 3D print is shown in the preview as a single colour
applied at the top level of the object, after all the CGS ops. Sometimes
the actual colour of the filaments and sheets I use. Sometimes contrasting
colours to make assembly views clearer.
On Wed, 8 Apr 2020 at 02:06, Ron Wheeler via Discuss <
Give you that one!
Ron
Isn't "observed behavior that is not part of the designed functionality"
No (and in a different way than Torsten mentioned). Often there will be
cases that are formally undefined behavior, where the observed behavior is
something that you might want to rely on. For instance, in JavaScript the
order of enumeration of the elements of an object is formally undefined,
but in some implementations it is reliably the same as the order that the
elements were added. It's very easy to accidentally depend on this
behavior, or to deliberately depend on it without realizing that it's not a
Ron Wheeler
Artifact Software
438-345-3369rwheeler@artifact-software.com
