Hello,
I have almost 2 solutions to implements a module.
I there a way to test performance (time and/or nb triangles) of each
implementation ?
"F6 render" show some informations (cleaning cache every time) but my module
is too small to display something useful.
I try to duplicate the module with a loop on children but I have the same
result in two case so I suspect that I measure duplication time and not my
module time !
One module use polygon with point list.
Second one use difference().
a+
Vicnet
I don't understand what the question is. When you preview or render,
it reports the number of seconds it took to process the geometry. If
the number is too high for your taste, then you can try to make more
efficient module etc. and see if it runs in less time.
On Thu, Mar 22, 2018 at 8:03 AM, vicnet vo.publique@gmail.com wrote:
Hello,
implementation ?
module time !
a+
Vicnet
Em 22 de mar de 2018 13:42, "Hans L" thehans@gmail.com escreveu:
Hello,
implementation ?
module
my
module time !
a+
Vicnet
module time !
Have you tried not using children (which I suppose is just making copies of
the already generated object) and instead repeatedly call the module in a
loop?
I would not expect big differences with 2D models. Anyway, remember that
OpenSCAD saves models in cache so there is no duplicate effort if the very
same model is used many times.
The render value is fine to have some perf values.
The pb is how to test 2 implementations that take few time (milliseconds o
rless?) each so that it is not comparable for one call with render?
of
loop?
Yes, you're right.
i use children() to duplicate so certainly cache is used and I measure
children+cache functions not my module !
I will try to duplicate directly.
Thanks.
a+
vicnet
