E
enzo
Sun, Mar 1, 2020 9:28 PM
Please, can anyone help me to understand what's wrong in this code for it
can't work the CSG (no error issued):
module pyramid_side(side, thickness)
linear_extrude(height = 2)
triangle_points =[[0,0],[side,0],[side/2, side * 1.5],[5, 5],[side - 5,
5],[side/2, side * 1.5 - 10]];
triangle_paths =[[0,1,2],[3,4,5]];
polygon(triangle_points,triangle_paths,10);
rotate([109.5, 0, 0])
translate([1, 0, 0])
pyramid_side(100);
rotate([109.5, 0, 90])
translate([-100, 0, 0])
pyramid_side(100);
rotate([109.5, 0, -90])
translate([1, -34, -95])
pyramid_side(100);
rotate([109.5, 0, 180])
translate([-100, -34, -95])
pyramid_side(100);
Preview seems ok, I guess it's not a manifold but how can I fix it?
Thanks
pyramid_side(100);
pyramid_side(100);
pyramid_side(100);
pyramid_side(100);
Thanks
Sun, Mar 1, 2020 10:27 PM
for it can't work the CSG (no error issued):
Works for me. I exported it and the STL looks OK.
What is "can't work the CSG"?
- click on my MichaelAtOz label, there is a link to email me.
* click on my MichaelAtOz label, there is a link to email me.
Sun, Mar 1, 2020 10:39 PM
You code is previewed and rendered fine. It is a manifold. You may not be
happy with the vertices of your model. Try to start from a full pyramid and
excavate it with difference().
module pyramid(height, side) {
linear_extrude(height,scale=0.1/height)
square(side,center=true);
lar3ry
Tue, Mar 3, 2020 4:33 PM
and
I took this one as a bit of a challenge, and this is what I came up with.
I basically used trial and error to size and position the cutters, but I
imagine math would be helpful in sizing everything correctly.
difference () {
pyramid(100,100);
sqcutter();
tricutter();
rotate([0,0,90])
tricutter();
module tricutter () {
rotate([0,-90,0])
translate([32,0,-60])
linear_extrude(120)
scale ([1.1,1,1])
circle(50, $fn=3);
module sqcutter() {
linear_extrude(4.5)
square(90,center=true);
> and
difference () {
pyramid(100,100);
sqcutter();
tricutter();
rotate([0,0,90])
tricutter();
rotate([0,-90,0])
linear_extrude(120)
scale ([1.1,1,1])
circle(50, $fn=3);
module sqcutter() {
# linear_extrude(4.5)
Tue, Mar 3, 2020 4:57 PM
I haven't checked your code yet but it seems that it might be easier to
excavate with the pyramid itself.
lar3ry
Tue, Mar 3, 2020 7:27 PM
I'd be interested to see how you could do that.
Yes, I can use the pyramid to hollow it out:
pyramid(100,100);
translate ([0,0,-5])
pyramid(100,100);
But that still leaves the walls.
I could cut my code down some by eliminating sqcutter() and subsituting the
technique above:
difference () {
pyramid(100,100);
pyramid(100,100);
tricutter();
rotate([0,0,90])
tricutter();
rotate([0,-90,0])
linear_extrude(120)
scale ([1.1,1,1])
circle(50, $fn=3);
pyramid(100,100);
pyramid(100,100);
technique above:
difference () {
pyramid(100,100);
pyramid(100,100);
tricutter();
rotate([0,0,90])
tricutter();
rotate([0,-90,0])
linear_extrude(120)
scale ([1.1,1,1])
circle(50, $fn=3);
Wed, Mar 4, 2020 4:30 AM
There are many alternatives. Here is one:
module A(height,side,a,b,c,d)
pyramid(150,100);
translate([ a, d, b]) pyramid(150,100);
translate([-a,-d, b]) pyramid(150,100);
translate([ 0, 0, c]) pyramid(150,100);
a = 5;
b = 4;
c = 11;
A(150,100,a,b,-c,-a);
A(150,100,a,b,-c, a);
You will need some trigonometry to calculate a, b and c from the pyramid
height and side and the width of the studs.
pyramid(150,100);
a = 5;
b = 4;
c = 11;
lar3ry
Wed, Mar 4, 2020 5:14 AM
You've bent my brain, sir!
Took me a while to figure it out. Very clever.
Wed, Mar 4, 2020 1:28 PM
Here's a fancy one, without any trigonometric stuff:
h=100;
s=60;
d = 5;
intersection()
linear_extrude(h, scale = 0, convexity = 5)
square(s, center = true);
for(i=[0:3])
rotate(i*90)
multmatrix([[1, 0, s/2/h], [0, 1, 0], [0, 0, 1]]) // skew x
translate([-(s-d)/2, 0, 0])
rotate([0,-90,0])
linear_extrude(d, center = true)
ci(s);
offset(-d)ci(s);
module ci(a)
r = a/3sqrt(3);
H = a/2sqrt(3);
scale([h/H, 1, 1])
translate([r/2, 0])circle(r, $fn=3);
h=100;
s=60;
d = 5;
intersection()
for(i=[0:3])
rotate(i*90)
rotate([0,-90,0])
ci(s);
offset(-d)ci(s);
module ci(a)
r = a/3*sqrt(3);
H = a/2*sqrt(3);
scale([h/H, 1, 1])
Thu, Mar 5, 2020 3:33 AM
You are right, Parkinbot: we don't need trigonometry here... neither fancy
skews :)
width = 8;
height = 150;
side = 100;
tower(height, side, width);
module tower(h, s, w)
ds = w*(s+sqrt(ss+4hh))/h;
h0 = h(s-ds)/s;
pyramid(h,s);
translate([0,0, w]) pyramid(h0,[2s, s-ds],[1,0.001]);
translate([0,0, w]) pyramid(h0,[s-ds, 2s],[0.001,1]);
translate([0,0,-h+h0+w]) pyramid(h,s);
module pyramid(height, side, top=0)
linear_extrude(height,scale=top)
skews :)
width = 8;
height = 150;
side = 100;
ds = w*(s+sqrt(s*s+4*h*h))/h;
h0 = h*(s-ds)/s;
pyramid(h,s);
translate([0,0, w]) pyramid(h0,[2*s, s-ds],[1,0.001]);
translate([0,0, w]) pyramid(h0,[s-ds, 2*s],[0.001,1]);
