Any idea what is wrong?
inches = 25.4;
eps = 0.01;
$fn = 100;
id = 0.709 * inches + 0.1;
ir = id/2;
th = 2;
le = 1 * inches;
module BottomTubes()
rotate([0, 0, -90]) {
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
rotate([36.9, 0, 0]) rotate([-90, 0, 0])
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
translate([0, 0, -ir - th])
linear_extrude(th)
projection(cut = false)
BottomTubes();
!Bottom();
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
Copy/paste problem? Where is the module Tube() ?
Wat is, where is the Tube() module??
"WARNING: Ignoring unknown module 'Tube' in file , line 13
WARNING: Ignoring unknown module 'Tube' in file , line 15
WARNING: Ignoring unknown module 'Tube' in file , line 17
WARNING: Ignoring unknown module 'Tube' in file , line 19
WARNING: Ignoring unknown module 'Tube' in file , line 20"
Does this come from some library?
jon jon@jonbondy.com ezt írta (időpont: 2023. márc. 15., Sze, 17:31):
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
Tube means what?
Is it a cylinder or a hollow cylinder?
Is it centered or resting on the x-y plane?
In case it is a hollow cylinder there should be OD and ID as parameters
assuming that height = diameter.
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
Sorry.
module Tube(le) {
cylinder(h = le, d = id + 2th);
translate([0, 0, -eps]) cylinder(h = le + 2eps, d = id);
// cylinder(h = 2000, d = 2);
inches = 25.4;
eps = 0.01;
$fn = 100;id = 0.709 * inches + 0.1;
ir = id/2;
th = 2;
le = 1 * inches;module BottomTubes()
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
module Tube(le) {
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
No issues in rendering for me
On Wed, 15 Mar 2023 at 22:56, jon jon@jonbondy.com wrote:
Sorry.
module Tube(le) {
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
Again, sorry for not testing the code. This compiles and then fails with F6
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
module Tube(le) {
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
inches = 25.4;
eps = 0.01;
ir = id/2;
th = 2;
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
I have attached my working code.
Back() is fine with both the current development release and the latest
standard release.
Bottom() creates an STL with the latest standard release, but gets all
confused with the current development release.
Top() is fine with the standard release.
The shapes are not that surprising. I did not expect the current
development release to fail. I was even more surprised that the latest
standard release did much better than the current development release.
with F6
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
module Tube(le) {
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
with F6
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
module Tube(le) {
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
And both F5 and F6 are OK here with the AppImage of
OpenSCAD version 2023.03.05.ai13734 (git 245205575)
You perhaps have an older release?
with F6
inches = 25.4;
eps = 0.01;
$fn = 100;
ir = id/2;
th = 2;
le = 1 * inches;
module Tube(le) {
rotate([0, 90, 0])
Tube(le);
rotate([0, -90, 0])
Tube(le);
rotate([-90, 0, 0])
Tube(3le);
Tube(3le);
Tube(2*le);
module Bottom() {
BottomTubes();
linear_extrude(th)
BottomTubes();
!Bottom();
Sorry too, I should have added its debian linux 11, up to date a/o
yesterday.
