MH
Mark Harrison
Sat, Aug 4, 2018 6:39 AM
Here's something I'm having trouble understanding, if someone can help
me understand I'd be very appreciative.
Here's a nifty way of drawing a cube with cut off corners.
But, it fails on the mirror of the corner at [1,1,1].
module corner(wid) {
corner_points = [[0,0,0],[1,0,0],[0,1,0],[0,0,1]];
corner_faces = [[0,3,1],[0,2,3],[0,1,2],[1,3,2]];
polyhedron(wid*corner_points, corner_faces);
module cornercube(wid, cornerwid) {
cube_vertices = [[0,0,0],[0,0,1],[0,1,0],[0,1,1],
[1,0,0],[1,0,1],[1,1,0],[1,1,1]];
cube(wid);
for (v = cube_vertices) {
#translate(wid*v) mirror(v) corner(cornerwid);
cornercube(20,5);
This code fixes things by handling that corner as a special case.
Can someone explain to me what's different about the one corner?
And is there some transformation that will work on all eight corners?
module cornercube2(wid,cornerwid) {
cube_vertices7 = [[0,0,0],[0,0,1],[0,1,0],[0,1,1],
[1,0,0],[1,0,1],[1,1,0]];
cube_vertices1 = [[1,1,1]];
cube(wid);
for (v = cube_vertices7) {
translate(widv) mirror(v) corner(cornerwid);
for (v = cube_vertices1) {
#translate(widv) rotate([180,90,0]) corner(cornerwid);
cornercube2(20,5);
cube(wid);
cornercube(20,5);
cube(wid);
#translate(wid*v) rotate([180,90,0]) corner(cornerwid);
cornercube2(20,5);
Sat, Aug 4, 2018 2:01 PM
I don't have how to test this now. Have you tried to visualize just the
mirrored awkward corner? Something like:
translate(10*[1,1,1]) mirror ( [1,1,1]) corner(3);
% cube(10);
% cube(10);
Sat, Aug 4, 2018 2:36 PM
Something is wrong with your logic.
Intuitively, I would expect that a rotation and translation is needed to
position each corner.
You are using a mirror and a translation.
It's been a while since I studied matrix transformations, but it seems to
me that a rotation can sometimes be implemented using a mirror, but not
in the general case. So maybe you are getting lucky, and a mirror just
happens to be sufficient to perform the rotation in 7 of the 8 cases?
On 4 August 2018 at 02:39, Mark Harrison marhar@gmail.com wrote:
Here's something I'm having trouble understanding, if someone can help me
cube(wid);
cornercube(20,5);
cube(wid);
cornercube2(20,5);
me that a rotation can *sometimes* be implemented using a mirror, but not
> difference() {
> cube(wid);
> cornercube(20,5);
> difference() {
> cube(wid);
> cornercube2(20,5);
Sat, Aug 4, 2018 2:38 PM
Another way to cut corners off a cube is to intersect it with an
octahedron. I think the logic for this would be easier.
cube(wid);
cornercube(20,5);
cube(wid);
cornercube2(20,5);
>> difference() {
>> cube(wid);
>> cornercube(20,5);
>> difference() {
>> cube(wid);
>> cornercube2(20,5);
runsun
Sun, Aug 5, 2018 2:51 AM
It's indeed a special case. If you transfer the original corner (red color)
DIRECTLY to its position (i.e., w/o mirror()), and compare its relationship
with the one that is mirrored (teal color), you can see from the graph how
it is a special case :
http://forum.openscad.org/file/t602/180804_4_corner_mirroring_1.png
Instead of mirroring 7 times to all corners, mirroring application like this
can be better achieved by mirroring the original one (C0) to [x,0,0] corner
--- make it C1. Then, mirror BOTH C0-C1 to [0,y,0], generating 4 corners,
than again onto [0,0,z] to generate 8 corners:
module corners(wid=20, cornerwid=5)
module mirror_dir(d)
mps = [[1,0,0],[0,1,0],[0,0,1]];
children(); //<==== original copy
translate( wid*mps[d]) mirror( mps[d] ) children(); //<==== mirrored
copy
mirror_dir(2)
mirror_dir(1)
mirror_dir(0)
corner(cornerwid);
http://forum.openscad.org/file/t602/180804_4_corner_mirroring_2.png
This would be a very good general mirroring module for future 8-corner
mirroring.
<http://forum.openscad.org/file/t602/180804_4_corner_mirroring_1.png>
copy
mirror_dir(2)
mirror_dir(1)
mirror_dir(0)
corner(cornerwid);
<http://forum.openscad.org/file/t602/180804_4_corner_mirroring_2.png>
mirroring.
CA
Sun, Aug 5, 2018 12:59 PM
Indeed. The solution is trivial if you write a module defining an
octahedron with vertices on the main axes, distanced "size" from origin,
i.e. module octahedron(size);
Then you can do
module cornercube(wid,cornerwid)
intersection()
octahedron(size=wid*sqrt(2)-cornerwid/2);
cube(size:wid,center=true);
Then you can do
intersection()
Tue, Aug 7, 2018 10:51 AM
Yeah Carsten,
a more convenient way to code this would be:
cornercube(20,5);
module octahedron(d = 10)
scale(dsqrt(3))
cylinder(r1=1, r2=0, h=sqrt(3).5, $fn=4);
scale([1,1,-1])cylinder(r1=1, r2=0, h=sqrt(3)*.5, $fn=4);
module cornercube(d=20, d1=5)
intersection()
cube(d, true);
octahedron(d-d1);
Yeah Carsten,
cornercube(20,5);
scale(d*sqrt(3))
intersection()
cube(d, true);
octahedron(d-d1);
Tue, Aug 7, 2018 11:05 AM
Sorry, I miscalculated the height of the octahedron. It is as easy as this:
scale(d*sqrt(3))
cylinder(r1=1, r2=0, h=1, $fn=4);
scale([1,1,-1])cylinder(r1=1, r2=0, h=1, $fn=4);
scale(d*sqrt(3))
arnholm@arnholm.org
Tue, Aug 7, 2018 11:26 AM
this:
scale(d*sqrt(3))
Yes, you can do it this way, although it is "cheating" as it relies on
the OpenSCAD discretization of a cylinder instead of defining the
polyhedron explicitly. It is more compact, but less readable.
I used a different approach in my own code (not openSCAD), realising
that any convex polyhedron can be defined from just an array of vertex
coordinates. An octahedron is just one of many in this category
https://gist.github.com/arnholm/c71852301b56b318a83a59c20bb29fe8
> this:
> scale(d*sqrt(3))
Tue, Aug 7, 2018 11:41 AM
I don't think that using language primitives is "cheating", but I understand
what you mean. The main problem with the code given by the threadstarter is
that the cube is not centered. With a centered cube everything is clear and
easy.
Btw, there was another calculation error in my octahedron. I hope this the
final version:
x = d * 2 *sqrt(5)/3;
scale(x)
easy.
final version:
scale(x)
