Modules as functions
Sun, Aug 24, 2025 12:47 PM
On 8/24/25 07:50, Jon Bondy via Discuss wrote:
One can always create aliased versions of things like cube() (called,
perhaps, MyCube()) where the defaults are different. There is no need
for this to be an issue for anyone, and one need not change the
language.  Just define what you want and then use your versions of the
modules.
An example of MyCube() plz?
I can't imagine anything better than loading the stack with at least 4
vars, using syntax like mycube([x,y,z,1|0]); where the "0|1" is true|false.
There may be better ways my ancient brain hasn't thought of.  Surely
that would be disastrous in terms of render time in a recursive or
animation program.
On 8/24/2025 7:30 AM, Adrian Mariano via Discuss wrote:
They will never flip the default on the center keyword, because it
would break tons of models.  But we got this right in BOSL2:  objects
appear centered by default. :)
On Sun, Aug 24, 2025 at 1:42 AM larry via Discuss
    On Sat, 2025-08-23 at 23:32 -0400, gene heskett via Discuss wrote:
    <snip>
    > The only thing I'd like to see, is a center keyword that if left
    out,
    > defaults to true, not false.
    YES!
Cheers, Gene Heskett, CET.
  • Louis D. Brandeis
On 8/24/25 07:50, Jon Bondy via Discuss wrote: > One can always create aliased versions of things like cube() (called, > perhaps, MyCube()) where the defaults are different. There is no need > for this to be an issue for anyone, and one need not change the > language.  Just define what you want and then use your versions of the > modules. An example of MyCube() plz? I can't imagine anything better than loading the stack with at least 4 vars, using syntax like mycube([x,y,z,1|0]); where the "0|1" is true|false. There may be better ways my ancient brain hasn't thought of.  Surely that would be disastrous in terms of render time in a recursive or animation program. > > > On 8/24/2025 7:30 AM, Adrian Mariano via Discuss wrote: >> They will never flip the default on the center keyword, because it >> would break tons of models.  But we got this right in BOSL2:  objects >> appear centered by default. :) >> >> On Sun, Aug 24, 2025 at 1:42 AM larry via Discuss >> <discuss@lists.openscad.org> wrote: >> >>     On Sat, 2025-08-23 at 23:32 -0400, gene heskett via Discuss wrote: >> >>     <snip> >> >>     > The only thing I'd like to see, is a center keyword that if left >>     out, >>     > defaults to true, not false. >>     > >> >>     YES! >>     _______________________________________________ >>     OpenSCAD mailing list >>     To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email todiscuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis
Sun, Aug 24, 2025 12:56 PM
modules.
module MyCube (size, center=true)
cube (size, center);
program.
module MyCube (sizec)
cube ([size[0], size[1], size[2]], center=size[3]);
or:
center=isset(size[3]) ? size[3] : true;
cube ([size[0], size[1], size[2]], center=center);
** KVK: 27239233    **
**  'a' for accelleration.
On Sun, Aug 24, 2025 at 08:47:20AM -0400, gene heskett via Discuss wrote: > On 8/24/25 07:50, Jon Bondy via Discuss wrote: > > One can always create aliased versions of things like cube() (called, > > perhaps, MyCube()) where the defaults are different. There is no need > > for this to be an issue for anyone, and one need not change the > > language.  Just define what you want and then use your versions of the > > modules. > An example of MyCube() plz? module MyCube (size, center=true) { cube (size, center); } > I can't imagine anything better than loading the stack with at least 4 vars, > using syntax like mycube([x,y,z,1|0]); where the "0|1" is true|false. > There may be better ways my ancient brain hasn't thought of.  Surely that > would be disastrous in terms of render time in a recursive or animation > program. module MyCube (sizec) { cube ([size[0], size[1], size[2]], center=size[3]); } or: module MyCube (sizec) { center=isset(size[3]) ? size[3] : true; cube ([size[0], size[1], size[2]], center=center); } Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands. ** KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a** is going up. -- Chris Hadfield about flying up the space shuttle. ** 'a' for accelleration.
Sun, Aug 24, 2025 4:40 PM
modules.
program.
where the call would look like MyCube([a,b.c]); ?
or:
Both examples are even more typing. More LOC
(and typu magnets) to get the job done.
I don't see in the current cheat sheet, how a 3 value array is made so
it passes as one named sizec? Not (to me) obvious.
I can see it in a "list" category, sort of. And I  assume it follows
"scope" rules.
But what is "isset"? that keyword does not exist in the current cheat
sheet.
But from the above, I gather that it could be useful albeit more typing.
Thank you Roger.
  • Louis D. Brandeis
On 8/24/25 08:56, Rogier Wolff via Discuss wrote: > On Sun, Aug 24, 2025 at 08:47:20AM -0400, gene heskett via Discuss wrote: >> On 8/24/25 07:50, Jon Bondy via Discuss wrote: >>> One can always create aliased versions of things like cube() (called, >>> perhaps, MyCube()) where the defaults are different. There is no need >>> for this to be an issue for anyone, and one need not change the >>> language.  Just define what you want and then use your versions of the >>> modules. >> An example of MyCube() plz? > module MyCube (size, center=true) > { > cube (size, center); > } > >> I can't imagine anything better than loading the stack with at least 4 vars, >> using syntax like mycube([x,y,z,1|0]); where the "0|1" is true|false. >> There may be better ways my ancient brain hasn't thought of.  Surely that >> would be disastrous in terms of render time in a recursive or animation >> program. where the call would look like MyCube([a,b.c]); ? > module MyCube (sizec) > { > cube ([size[0], size[1], size[2]], center=size[3]); > } > > or: > > module MyCube (sizec) > { > center=isset(size[3]) ? size[3] : true; > cube ([size[0], size[1], size[2]], center=center); > } Both examples are even more typing. More LOC (and typu magnets) to get the job done. I don't see in the current cheat sheet, how a 3 value array is made so it passes as one named sizec? Not (to me) obvious. I can see it in a "list" category, sort of. And I  assume it follows "scope" rules. But what is "isset"? that keyword does not exist in the current cheat sheet. But from the above, I gather that it could be useful albeit more typing. Thank you Roger. > > Roger. Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis
Sun, Aug 24, 2025 10:26 PM
On 8/24/2025 2:17 AM, pca006132 via Discuss wrote:
What do you mean by a syntax to define a module that yields a module
reference? Do you mean you want something like a lambda for function
that creates a new module?
Don't use the word "function", because that word has a specific meaning
in OpenSCAD, but yes, if I'm reading what you're saying correctly.
Just as today you can say:
addOne = function (x) x + 1;
echo(addOne(5));
you should be able to say something like:
cubeSphere = module () { sphere(r=10); cube(15, center=true); };
cubeSphere();
Note that in that second snippet cubeSphere is not a function, because
in OpenSCAD functions and modules are separate mechanisms.
On 8/24/2025 2:17 AM, pca006132 via Discuss wrote: > > What do you mean by a syntax to define a module that yields a module > reference? Do you mean you want something like a lambda for function > that creates a new module? > Don't use the word "function", because that word has a specific meaning in OpenSCAD, but yes, if I'm reading what you're saying correctly. Just as today you can say: addOne = function (x) x + 1; echo(addOne(5)); you should be able to say something like: cubeSphere = module () { sphere(r=10); cube(15, center=true); }; cubeSphere(); Note that in that second snippet cubeSphere is *not* a function, because in OpenSCAD functions and modules are separate mechanisms.
Mon, Aug 25, 2025 1:26 AM
On Aug 23, 2025, at 4:38 PM, Jordan Brown via Discuss discuss@lists.openscad.org wrote:
o = render(g);
This is the really interesting one.  It runs the full rendering process on the geometry value, and returns a list of vertexes and faces (for 3D objects) or points and paths (for 2D objects), and some metadata.  This allows you to create things like bend/wrap operations, along with simpler operations like "center anything".
At BOSL laboratories, we've been wishing for this feature for about a decade.  It would make our software implementations of union() / difference() / intersection() / offset() far faster (and somewhat less buggy), and it would make a 3D version feasible (in reasonable time) for VNFs.  And yes, bend would become better.
  • Revar
> On Aug 23, 2025, at 4:38 PM, Jordan Brown via Discuss <discuss@lists.openscad.org> wrote: > > o = render(g); > This is the really interesting one. It runs the full rendering process on the geometry value, and returns a list of vertexes and faces (for 3D objects) or points and paths (for 2D objects), and some metadata. This allows you to create things like bend/wrap operations, along with simpler operations like "center anything". > At BOSL laboratories, we've been wishing for this feature for about a decade. It would make our software implementations of `union()` / `difference()` / `intersection()` / `offset()` far faster (and somewhat less buggy), and it would make a 3D version feasible (in reasonable time) for VNFs. And yes, bend would become better. - Revar
PK
Peter Kriens
Mon, Aug 25, 2025 12:52 PM
On 24 Aug 2025, at 00:57, Jordan Brown openscad@jordan.maileater.net wrote:
On 8/22/2025 4:41 PM, Peter Kriens via Discuss wrote:
This will enable calling a module from a function which is a pretty big change.
Assuming that you're working from my work... No, it does not.  Module references are values, and can be manipulated and created by functions, but they cannot be invoked in expressions.
Any reason why not? It is very odd to have module reference that is a Value but you can't use it in an expression? It makes the language very strange and unpredictable?
Is there a special reason why we keep statements and expressions so different? I am rather intrigued for the reason about the invocation order.
But anyway, I think I am not going to touch this area anyway ...
Peter
Literal modules are now values and can be used anywhere an expression can be used. I.e. they can actually render from a function.
Again, no, they cannot.
Should I work on this?
Module references?  Sure.  Invoking modules from expressions?  I wouldn't go there.
(Note that PR#4478's geometry values do allow invoking modules from expressions; the result is a geometry value.  But that's totally orthogonal to module references.)
> On 24 Aug 2025, at 00:57, Jordan Brown <openscad@jordan.maileater.net> wrote: > On 8/22/2025 4:41 PM, Peter Kriens via Discuss wrote: >> This will enable calling a module from a function which is a pretty big change. > Assuming that you're working from my work... No, it does not. Module references are values, and can be manipulated and created by functions, but they cannot be invoked in expressions. > Any reason why not? It is very odd to have module reference that is a Value but you can't use it in an expression? It makes the language very strange and unpredictable? Is there a special reason why we keep statements and expressions so different? I am rather intrigued for the reason about the invocation order. But anyway, I think I am not going to touch this area anyway ... Peter >> Literal modules are now values and can be used anywhere an expression can be used. I.e. they can actually render from a function. > Again, no, they cannot. > >> Should I work on this? > Module references? Sure. Invoking modules from expressions? I wouldn't go there. > > (Note that PR#4478's geometry values do allow invoking modules from expressions; the result is a geometry value. But that's totally orthogonal to module references.) > > >
CC
Cory Cross
Mon, Aug 25, 2025 2:20 PM
big change.
Among any other reasons, it's because OpenSCAD has at least 4
environments for names: functions, modules, assignments, and specials.
If there is a call on a name (i.e. name()) then if it's a special name,
look it up in the special environment regardless of statement vs
expression. If it's in an expression, look it up in the function
environment first and then the assignment environment if not found in
the function environment. If it's a statement, look it up module
environment (modules as Values needs to add a lookup into assignments
when it fails to be found in module environment and obviously(?) allow
an expression as a name).
So if you change that you're breaking stuff.
  • Cory
order.
Peter
wouldn't go there.
On 8/25/25 5:52 AM, Peter Kriens via Discuss wrote: >> On 24 Aug 2025, at 00:57, Jordan Brown >> <openscad@jordan.maileater.net> wrote: >> On 8/22/2025 4:41 PM, Peter Kriens via Discuss wrote: >>> This will enable calling a module from a function which is a pretty >>> big change. >> >> Assuming that you're working from my work... No, it does not.  Module >> references are values, and can be manipulated and created by >> functions, but they cannot be invoked in expressions. >> > > Any reason why not? It is very odd to have module reference that is a > Value but you can't use it in an expression? It makes the language > very strange and unpredictable? Among any other reasons, it's because OpenSCAD has at least 4 environments for names: functions, modules, assignments, and specials. If there is a call on a name (i.e. name()) then if it's a special name, look it up in the special environment regardless of statement vs expression. If it's in an expression, look it up in the function environment first and then the assignment environment if not found in the function environment. If it's a statement, look it up module environment (modules as Values needs to add a lookup into assignments when it fails to be found in module environment and obviously(?) allow an expression as a name). So if you change that you're breaking stuff. - Cory > > Is there a special reason why we keep statements and expressions so > different? I am rather intrigued for the reason about the invocation > order. > > But anyway, I think I am not going to touch this area anyway ... > > Peter > > >>> Literal modules are now values and can be used anywhere an >>> expression can be used. I.e. they can actually render from a function. >> >> Again, no, they cannot. >> >>> Should I work on this? >> >> Module references?  Sure.  Invoking modules from expressions?  I >> wouldn't go there. >> >> (Note that PR#4478's geometry values do allow invoking modules from >> expressions; the result is a geometry value.  But that's totally >> orthogonal to module references.) >> >> > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
Mon, Aug 25, 2025 7:08 PM
big change.
Any reason why not?
Because it doesn't align with the overall pattern of the language.
Modules are modules; they do not go in expressions.
I don't think the implementation would be at all amenable to calling
modules from expressions.  From an external point of view, as you noted
there's nothing meaningful for them to return, making it odd to put them
into an expression.
unpredictable?
You absolutely can use module references in expressions.  You can assign
them, put them into arrays, str() them, echo() them, pass them to
functions, et cetera.  You just can't invoke them, because you can't
invoke modules from expressions.
different?
You'd have to ask Marius.  My guess is that the answer is in the
evolution of the language, and in particular the desire to support the
command line's -D option.  At this point, though, it's pretty well
embedded into the language.
Again, my bet is that it's tied up in the desire to support -D.
Also, conceptually, OpenSCAD operations are only sort of ordered.  With
the exception of assert() and the ordering of echo() output, it would be
entirely legal for OpenSCAD to evaluate modules in any order.    With
similar exceptions, it would be legal to evaluate assignments in any
order that preserves the dependency relationship.  In theory this would
allow automatic multithreaded execution, though in practice historically
render time has been so much larger than execution time that nobody has
done it.
Good plan.
On 8/25/2025 2:52 PM, Peter Kriens wrote: >> On 24 Aug 2025, at 00:57, Jordan Brown >> <openscad@jordan.maileater.net> wrote: >> On 8/22/2025 4:41 PM, Peter Kriens via Discuss wrote: >>> This will enable calling a module from a function which is a pretty >>> big change. >> >> Assuming that you're working from my work... No, it does not.  Module >> references are values, and can be manipulated and created by >> functions, but they cannot be invoked in expressions. >> > > Any reason why not? Because it doesn't align with the overall pattern of the language.  Modules are modules; they do not go in expressions. I don't think the implementation would be at all amenable to calling modules from expressions.  From an external point of view, as you noted there's nothing meaningful for them to return, making it odd to put them into an expression. > It is very odd to have module reference that is a Value but you can't > use it in an expression? It makes the language very strange and > unpredictable? You absolutely can use module references in expressions.  You can assign them, put them into arrays, str() them, echo() them, pass them to functions, et cetera.  You just can't invoke them, because you can't invoke modules from expressions. > Is there a special reason why we keep statements and expressions so > different? You'd have to ask Marius.  My guess is that the answer is in the evolution of the language, and in particular the desire to support the command line's -D option.  At this point, though, it's pretty well embedded into the language. >  I am rather intrigued for the reason about the invocation order. Again, my bet is that it's tied up in the desire to support -D. Also, conceptually, OpenSCAD operations are only sort of ordered.  With the exception of assert() and the ordering of echo() output, it would be entirely legal for OpenSCAD to evaluate modules in any order.    With similar exceptions, it would be legal to evaluate assignments in any order that preserves the dependency relationship.  In theory this would allow automatic multithreaded execution, though in practice historically render time has been so much larger than execution time that nobody has done it. > But anyway, I think I am not going to touch this area anyway ... Good plan.
