Modules as functions
PK
Peter Kriens
Fri, Aug 22, 2025 2:41 PM
The OEP8 https://github.com/openscad/openscad/wiki/OEP8:-Objects-(dictionaries?),-Geometry-as-data,-and-Module-References is the source for the object() and the $this saga. I thought this was extensively discussed looking at the discussions in the PR but I guess the current discussions prove that wrong.
The same PR https://github.com/openscad/openscad/pull/4478 also contained module references. Something that sounded extremely useful to me since that would make name scoping of libraries a lot simpler. It would theoretically allow something like this bosl2= use <BOSL2/std.scad> in the future (not planned).
So this is what is in OEP8.
module literals / module references
new expression component module (<params>) { <body> } yields module reference.
module reference is just a value, can put in variable, put in array, pass as argument, return from function, et cetera.
call as
m(args)
ai
o.m(args)
(expr)(args)
or combinations, e.g. a[i].m(args) for an array of objects with a member that is a module reference.
It will allow code like this.
small = module() cube(10);
big  = module() cube(100);
(s ? small : big)();
v = [ small, big];
v1;
function foo(w) =
w = "c" ? module() cube(5)
: w = "s" ? module() sphere(5)
: undef;
This will enable calling a module from a function which is a pretty big change. Literal modules are now values and can be used anywhere an expression can be used. I.e. they can actually render from a function. (I expect this will give some issues before this works perfectly because ordering between functions/modules is a bit odd in OpenSCAD.)
When a module is instantiated from an expression, its value will be undef.
Should I work on this?
Peter
The OEP8 <https://github.com/openscad/openscad/wiki/OEP8:-Objects-(dictionaries?),-Geometry-as-data,-and-Module-References> is the source for the object() and the $this saga. I thought this was extensively discussed looking at the discussions in the PR but I guess the current discussions prove that wrong. The same PR <https://github.com/openscad/openscad/pull/4478> also contained `module references`. Something that sounded extremely useful to me since that would make name scoping of libraries a lot simpler. It would theoretically allow something like this `bosl2= use <BOSL2/std.scad>` in the future (not planned). So this is what is in OEP8. module literals / module references new expression component module (<params>) { <body> } yields module reference. module reference is just a value, can put in variable, put in array, pass as argument, return from function, et cetera. call as m(args) a[i](args) o.m(args) (expr)(args) or combinations, e.g. a[i].m(args) for an array of objects with a member that is a module reference. It will allow code like this. small = module() cube(10); big = module() cube(100); (s ? small : big)(); v = [ small, big]; v[1](); function foo(w) = w = "c" ? module() cube(5) : w = "s" ? module() sphere(5) : undef; This will enable calling a module from a function which is a pretty big change. Literal modules are now values and can be used anywhere an expression can be used. I.e. they can actually render from a function. (I expect this will give some issues before this works perfectly because ordering between functions/modules is a bit odd in OpenSCAD.) When a module is instantiated from an expression, its value will be undef. Should I work on this? Peter
Fri, Aug 22, 2025 3:31 PM
I don't see how module references allows name scoping of libraries. A
library isn't a module.
And I don't think modules should be called from functions. Reference can be
returned from a function but modules can only be called by statements so I
expect module reference can only be invoked in statements.
On Fri, 22 Aug 2025 at 15:42, Peter Kriens via Discuss <
The OEP8
- new expression component module (<params>) { <body> } yields module
   reference.
   - module reference is just a value, can put in variable, put in
   - call as
      - m(args)
      - a[i](args)
      - o.m(args)
      - (expr)(args)
      - or combinations, e.g. a[i].m(args) for an array of objects
v = [ small, big];
v1;
function foo(w) =
: undef;
Peter
I don't see how module references allows name scoping of libraries. A library isn't a module. And I don't think modules should be called from functions. Reference can be returned from a function but modules can only be called by statements so I expect module reference can only be invoked in statements. On Fri, 22 Aug 2025 at 15:42, Peter Kriens via Discuss < discuss@lists.openscad.org> wrote: > The OEP8 > <https://github.com/openscad/openscad/wiki/OEP8:-Objects-(dictionaries?),-Geometry-as-data,-and-Module-References> is > the source for the object() and the $this saga. I thought this was > extensively discussed looking at the discussions in the PR but I guess the > current discussions prove that wrong. > > The same PR <https://github.com/openscad/openscad/pull/4478> also > contained `module references`. Something that sounded extremely useful to > me since that would make name scoping of libraries a lot simpler. It would > theoretically allow something like this `bosl2= use <BOSL2/std.scad>` in > the future (not planned). > > So this is what is in OEP8. > > > - > > module literals / module references > - new expression component module (<params>) { <body> } yields module > reference. > - module reference is just a value, can put in variable, put in > array, pass as argument, return from function, et cetera. > - call as > - m(args) > - a[i](args) > - o.m(args) > - (expr)(args) > - or combinations, e.g. a[i].m(args) for an array of objects > with a member that is a module reference. > > It will allow code like this. > > small = module() cube(10); > big = module() cube(100); > (s ? small : big)(); > v = [ small, big]; > v[1](); > function foo(w) = > w = "c" ? module() cube(5) > : w = "s" ? module() sphere(5) > : undef; > > > This will enable calling a module from a function which is a pretty big > change. Literal modules are now values and can be used anywhere an > expression can be used. I.e. they can actually render from a function. (I > expect this will give some issues before this works perfectly because > ordering between functions/modules is a bit odd in OpenSCAD.) > > When a module is instantiated from an expression, its value will be undef. > > Should I work on this? > > Peter > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Aug 22, 2025 3:55 PM
Calling modules from functions sure would make debugging easier. I can’t
think of any other use for it at the moment.  And it does seem like it
raises complications associated with execution order.  The utility of
module references in general is not obvious to me.
The feature that seems like a huge one to me is the one that lets us get
geometry data in user space. Then libraries can actually do interesting
stuff to things created using the native geometry capability.
On Fri, Aug 22, 2025 at 11:31 nop head via Discuss <
The OEP8
   reference.
   - call as
      - m(args)
      - a[i](args)
      - o.m(args)
      - (expr)(args)
v = [ small, big];
v1;
function foo(w) =
: undef;
Peter
Calling modules from functions sure would make debugging easier. I can’t think of any other use for it at the moment. And it does seem like it raises complications associated with execution order. The utility of module references in general is not obvious to me. The feature that seems like a huge one to me is the one that lets us get geometry data in user space. Then libraries can actually do interesting stuff to things created using the native geometry capability. On Fri, Aug 22, 2025 at 11:31 nop head via Discuss < discuss@lists.openscad.org> wrote: > I don't see how module references allows name scoping of libraries. A > library isn't a module. > > And I don't think modules should be called from functions. Reference can > be returned from a function but modules can only be called by statements so > I expect module reference can only be invoked in statements. > > On Fri, 22 Aug 2025 at 15:42, Peter Kriens via Discuss < > discuss@lists.openscad.org> wrote: > >> The OEP8 >> <https://github.com/openscad/openscad/wiki/OEP8:-Objects-(dictionaries?),-Geometry-as-data,-and-Module-References> is >> the source for the object() and the $this saga. I thought this was >> extensively discussed looking at the discussions in the PR but I guess the >> current discussions prove that wrong. >> >> The same PR <https://github.com/openscad/openscad/pull/4478> also >> contained `module references`. Something that sounded extremely useful to >> me since that would make name scoping of libraries a lot simpler. It would >> theoretically allow something like this `bosl2= use <BOSL2/std.scad>` in >> the future (not planned). >> >> So this is what is in OEP8. >> >> >> - >> >> module literals / module references >> - new expression component module (<params>) { <body> } yields module >> reference. >> - module reference is just a value, can put in variable, put in >> array, pass as argument, return from function, et cetera. >> - call as >> - m(args) >> - a[i](args) >> - o.m(args) >> - (expr)(args) >> - or combinations, e.g. a[i].m(args) for an array of objects >> with a member that is a module reference. >> >> It will allow code like this. >> >> small = module() cube(10); >> big = module() cube(100); >> (s ? small : big)(); >> v = [ small, big]; >> v[1](); >> function foo(w) = >> w = "c" ? module() cube(5) >> : w = "s" ? module() sphere(5) >> : undef; >> >> >> This will enable calling a module from a function which is a pretty big >> change. Literal modules are now values and can be used anywhere an >> expression can be used. I.e. they can actually render from a function. (I >> expect this will give some issues before this works perfectly because >> ordering between functions/modules is a bit odd in OpenSCAD.) >> >> When a module is instantiated from an expression, its value will be undef. >> >> Should I work on this? >> >> Peter >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Aug 22, 2025 4:00 PM
Model references would be useful so an object can have member modules as
well as functions.
On Fri, 22 Aug 2025, 16:55 Adrian Mariano via Discuss, <
The OEP8
   module reference.
   - call as
      - m(args)
      - a[i](args)
      - o.m(args)
      - (expr)(args)
v = [ small, big];
v1;
function foo(w) =
: undef;
undef.
Peter
Model references would be useful so an object can have member modules as well as functions. On Fri, 22 Aug 2025, 16:55 Adrian Mariano via Discuss, < discuss@lists.openscad.org> wrote: > Calling modules from functions sure would make debugging easier. I can’t > think of any other use for it at the moment. And it does seem like it > raises complications associated with execution order. The utility of > module references in general is not obvious to me. > > The feature that seems like a huge one to me is the one that lets us get > geometry data in user space. Then libraries can actually do interesting > stuff to things created using the native geometry capability. > > On Fri, Aug 22, 2025 at 11:31 nop head via Discuss < > discuss@lists.openscad.org> wrote: > >> I don't see how module references allows name scoping of libraries. A >> library isn't a module. >> >> And I don't think modules should be called from functions. Reference can >> be returned from a function but modules can only be called by statements so >> I expect module reference can only be invoked in statements. >> >> On Fri, 22 Aug 2025 at 15:42, Peter Kriens via Discuss < >> discuss@lists.openscad.org> wrote: >> >>> The OEP8 >>> <https://github.com/openscad/openscad/wiki/OEP8:-Objects-(dictionaries?),-Geometry-as-data,-and-Module-References> is >>> the source for the object() and the $this saga. I thought this was >>> extensively discussed looking at the discussions in the PR but I guess the >>> current discussions prove that wrong. >>> >>> The same PR <https://github.com/openscad/openscad/pull/4478> also >>> contained `module references`. Something that sounded extremely useful to >>> me since that would make name scoping of libraries a lot simpler. It would >>> theoretically allow something like this `bosl2= use <BOSL2/std.scad>` in >>> the future (not planned). >>> >>> So this is what is in OEP8. >>> >>> >>> - >>> >>> module literals / module references >>> - new expression component module (<params>) { <body> } yields >>> module reference. >>> - module reference is just a value, can put in variable, put in >>> array, pass as argument, return from function, et cetera. >>> - call as >>> - m(args) >>> - a[i](args) >>> - o.m(args) >>> - (expr)(args) >>> - or combinations, e.g. a[i].m(args) for an array of objects >>> with a member that is a module reference. >>> >>> It will allow code like this. >>> >>> small = module() cube(10); >>> big = module() cube(100); >>> (s ? small : big)(); >>> v = [ small, big]; >>> v[1](); >>> function foo(w) = >>> w = "c" ? module() cube(5) >>> : w = "s" ? module() sphere(5) >>> : undef; >>> >>> >>> This will enable calling a module from a function which is a pretty big >>> change. Literal modules are now values and can be used anywhere an >>> expression can be used. I.e. they can actually render from a function. (I >>> expect this will give some issues before this works perfectly because >>> ordering between functions/modules is a bit odd in OpenSCAD.) >>> >>> When a module is instantiated from an expression, its value will be >>> undef. >>> >>> Should I work on this? >>> >>> Peter >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Aug 22, 2025 5:42 PM
I monitor this list, but not any/all of the PRs, so Peter's observation
does not surprise me.  Whether this is a good thing or not, I am not
sure.  But Peter's getting there only to discover that there is another
hill to climb is frustrating.
Do we have a clear list of objectives/requirements for this/these new
feature(s)?  Maybe a prioritized list?  Not a proposed syntax but
objectives.  Maybe that will help us focus on what is important.
I monitor this list, but not any/all of the PRs, so Peter's observation does not surprise me.  Whether this is a good thing or not, I am not sure.  But Peter's getting there only to discover that there is another hill to climb is frustrating. Do we have a clear list of objectives/requirements for this/these new feature(s)?  Maybe a prioritized list?  Not a proposed syntax but objectives.  Maybe that will help us focus on what is important. Jon On 8/22/2025 10:41 AM, Peter Kriens via Discuss wrote: > I thought this was extensively discussed looking at the discussions in > the PR but I guess the current discussions prove that wrong. -- This email has been checked for viruses by AVG antivirus software. www.avg.com
V
vulcan_@mac.com
Fri, Aug 22, 2025 9:06 PM
expressions are evaluated before modules,
functions can (currently) only be “called” in an expression
Is intended that module variables, AKA module references, be able to, or even required to, return a value?
so:
function apply_module( dataitem, module_var ) =
module_var( dataitem );
result = apply_module( 12, module_var=cube );
My issues and questions are :
  1. the call to “module_var(dataitem)” in the function is itself an expression, yes? so that would mean that module reference will be invoked in the order of evaluation of expressions in the script, before any other module that draw shapes?
  2. module_var() has to return a value that will be passed back as the result of the function call
  3. the call to apply_module causes “cube” to be assigned to the module_var parameter .. or is that not part of OPE8’s intention?
  4. cube() does not return a value so the function call will return ? undef?
  5. can we guarantee that the value for the dataitem argument will already be defined when apply_module is called? in my example the argument is just a literal 12, but in general it could be a variable defined elsewhere, or the result of a method reference being invoked
Or have i missed one or more points in my reading of OPE8
expressions are evaluated before modules, functions can (currently) only be “called” in an expression Is intended that module variables, AKA module references, be able to, or even required to, return a value? so: `function apply_module( dataitem, module_var ) =`\ ` module_var( dataitem );` `result = apply_module( 12, module_var=cube );` My issues and questions are : 1. the call to “module_var(dataitem)” in the function is itself an expression, yes? so that would mean that module reference will be invoked in the order of evaluation of expressions in the script, before any other module that draw shapes? 2. module_var() has to return a value that will be passed back as the result of the function call 3. the call to apply_module causes “cube” to be assigned to the module_var parameter .. or is that not part of OPE8’s intention? 4. cube() does not return a value so the function call will return ? undef? 5. can we guarantee that the value for the dataitem argument will already be defined when apply_module is called? in my example the argument is just a literal 12, but in general it could be a variable defined elsewhere, or the result of a method reference being invoked Or have i missed one or more points in my reading of OPE8
CC
Cory Cross
Fri, Aug 22, 2025 9:57 PM
On August 22, 2025 5:06:55 PM EDT, vulcan_--- via Discuss discuss@lists.openscad.org wrote:
No, that's "geometry as data" or "geom as data" if you want to find the discussion.
  • Cory
so:
On August 22, 2025 5:06:55 PM EDT, vulcan_--- via Discuss <discuss@lists.openscad.org> wrote: >expressions are evaluated before modules, > >functions can (currently) only be “called” in an expression > >Is intended that module variables, AKA module references, be able to, or even required to, return a value? No, that's "geometry as data" or "geom as data" if you want to find the discussion. - Cory > >so: > >`function apply_module( dataitem, module_var ) =`\ >` module_var( dataitem );` > >`result = apply_module( 12, module_var=cube );` > >My issues and questions are : > >1. the call to “module_var(dataitem)” in the function is itself an expression, yes? so that would mean that module reference will be invoked in the order of evaluation of expressions in the script, before any other module that draw shapes? > >2. module_var() has to return a value that will be passed back as the result of the function call > >3. the call to apply_module causes “cube” to be assigned to the module_var parameter .. or is that not part of OPE8’s intention? > >4. cube() does not return a value so the function call will return ? undef? > >5. can we guarantee that the value for the dataitem argument will already be defined when apply_module is called? in my example the argument is just a literal 12, but in general it could be a variable defined elsewhere, or the result of a method reference being invoked > >Or have i missed one or more points in my reading of OPE8
Sat, Aug 23, 2025 10:57 PM
big change.
Assuming that you're working from my work... No, it does not. Module
references are values, and can be manipulated and created by functions,
but they cannot be invoked in expressions.
Again, no, they cannot.
Module references?  Sure.  Invoking modules from expressions?  I
wouldn't go there.
(Note that PR#4478's geometry values do allow invoking modules from
expressions; the result is a geometry value.  But that's totally
orthogonal to module references.)
On 8/22/2025 4:41 PM, Peter Kriens via Discuss wrote: > This will enable calling a module from a function which is a pretty > big change. Assuming that you're working from my work... No, it does not. Module references are values, and can be manipulated and created by functions, but they cannot be invoked in expressions. > Literal modules are now values and can be used anywhere an expression > can be used. I.e. they can actually render from a function. Again, no, they cannot. > Should I work on this? Module references?  Sure.  Invoking modules from expressions?  I wouldn't go there. (Note that PR#4478's geometry values do allow invoking modules from expressions; the result is a geometry value.  But that's totally orthogonal to module references.)
Sat, Aug 23, 2025 11:07 PM
A library is a collection of functions, modules, and variables.
If you could wrap an entire library up in a single object, you could
avoid having that library consume global namespace.
For instance, with module references you could do:
myLib = object(
     someVar = 5,
     someFunc = function (arg) ... ,
     someMod = module (arg) { ... },
and then you could use myLib.someVar, myLib.someFunc(), and
myLib.someMod(), without needing to put someVar, someFunc, and someMod
into the global namespace.
On 8/22/2025 5:31 PM, nop head via Discuss wrote: > I don't see how module references allows name scoping of libraries. A > library isn't a module. A library is a collection of functions, modules, and variables. If you could wrap an entire library up in a single object, you could avoid having that library consume global namespace. For instance, with module references you could do: myLib = object( someVar = 5, someFunc = function (arg) ... , someMod = module (arg) { ... }, ... ); and then you could use myLib.someVar, myLib.someFunc(), and myLib.someMod(), without needing to put someVar, someFunc, and someMod into the global namespace.
Sat, Aug 23, 2025 11:20 PM
I've got to think that Peter misunderstood; I think that calling modules
from functions would be a lot more work than I'd done in PR#4478.
Module references can be used to allow treating geometry as data, sort
of.  For instance, suppose we're trying to provide a library that lets
you model a train.  You'd like to be able to give the list of cars as an
array, something like [ locomotive, boxcar, boxcar, coalcar, caboose ].
Module references let you do that.
Geometry values, which you mention, fill a very similar niche, but are
both more and less powerful.  My model train demo (which uses PR#4478
features) actually represents its cars as functions that return objects
that include some metadata and a geometry value for the actual model of
the car.
I don't think that you actually need module references if you have
function references and geometry values, but they seem like a good piece
of symmetry.
Yes, in particular the render() function, which accepts a geometry value
and returns a list of vertexes and faces (and other metadata) allows all
sorts of interesting things.
But I already tried bringing in objects, module references, and geometry
values all at the same time, and it stalled for lack of time for people
to think about it.  I am not optimistic about reviving that all-at-once
approach, so would prefer to add the features one at a time.
(I did them all at once so that I could satisfy myself that the
syntactic interactions were workable, and I found that they mostly were.)
On 8/22/2025 5:55 PM, Adrian Mariano via Discuss wrote: > Calling modules from functions sure would make debugging easier. I > can’t think of any other use for it at the moment.  And it does seem > like it raises complications associated with execution order. I've got to think that Peter misunderstood; I think that calling modules from functions would be a *lot* more work than I'd done in PR#4478. > The utility of module references in general is not obvious to me. Module references can be used to allow treating geometry as data, sort of.  For instance, suppose we're trying to provide a library that lets you model a train.  You'd like to be able to give the list of cars as an array, something like [ locomotive, boxcar, boxcar, coalcar, caboose ].  Module references let you do that. Geometry values, which you mention, fill a very similar niche, but are both more and less powerful.  My model train demo (which uses PR#4478 features) actually represents its cars as functions that return objects that include some metadata and a geometry value for the actual model of the car. I don't think that you actually need module references if you have function references and geometry values, but they seem like a good piece of symmetry. > The feature that seems like a huge one to me is the one that lets us > get geometry data in user space. Then libraries can actually do > interesting stuff to things created using the native geometry capability. Yes, in particular the render() function, which accepts a geometry value and returns a list of vertexes and faces (and other metadata) allows all sorts of interesting things. But I already tried bringing in objects, module references, and geometry values all at the same time, and it stalled for lack of time for people to think about it.  I am not optimistic about reviving that all-at-once approach, so would prefer to add the features one at a time. (I did them all at once so that I could satisfy myself that the syntactic interactions were workable, and I found that they mostly were.)
