Tue, Nov 22, 2022 3:59 PM
On Tue, Nov 22, 2022 at 03:21:38PM +0000, nop head wrote:
I don't think I have ever had OpenSCAD make an STL with holes. Sometimes
degenerate triangles or self intersections due to the grid snap. If you
don't have NetFabb studio please can you post one of your STLs and I will
take a look.
Aaargh....
I looked up the thread-head-email with my openscad code. Plonked the
code into a new file, preview-render-saveSTL and then open in
Slic3r. Looks good.
I then started the old version that was installed with the OS. (I
might still have been using that a few days ago) and... same thing:
Looks good.
So somehow... the problem has fixed itself. I'm pretty sure I then was
on the same computer I'm on now: The other one doesn't have this
project. I don't know what changed. I cant deliver you a "bad" STL.
Hi Roger,
I've updated my openscad to version 2022.11.18.ci12805 (git 1746d5a83). It
still shows holes in fast-csg render for your original blade. it throws a
warning in Cura slicer, but OK in Ideamaker slicer, as before. It does the
same for the normal slower csg render wrt messages in slicers, but no
warning in openscad itself. So, depending on the slicer you use, you may
think that the openscad design is flawless. I think this is one reason that
many of the stl's on thingyverse, etc., are faulty.
I have no software that identifies the areas at fault, but it will be at
the differences, I expect. It always seems to occur whenever a relatively
basic shape is modified, not necessarily by differences. I'm not sure if
the latest stable version fails in the same way. (2021.01).
I did find, in one of my cases, that altering $fn value seemed to solve
it, but it may have been that I forgot to flush the cache between
renderings.
On 22/11/2022 10:37, Rogier Wolff wrote:
On Mon, Nov 21, 2022 at 06:53:38PM +0000, Raymond West wrote:
Your original code when fast rendered with all the messaging, etc. produces
a number of holes, and it will not slice properly in Cura. However,
Ideamaker seems to be more tolerant of faulty files, and looks if it would
print OK. Fwiw, i seem to be spending days chasing down holes. There seems
to be some combinations of shapes that openscad can not render successfully.
Even if it renders successfully, with no holes, etc, the slicer still says
it's not watertight.
Making holes in openscad is easy.
pts = [[1,1,1], [1,-1,-1], [-1,1,-1], [-1,-1,1]];
tri1 = [[0,2,1], [0,3,2], [0,1,3], [1,2,3]];
tri2 = [[0,2,1], [0,3,2], [0,1,3]]; // wrong.
translate ([2.5,0,0])
polyhedron (pts, tri1);
polyhedron (pts, tri2); // wrong.
translate ([5,0,0])
rotate ([atan (sqrt(2)),0,0]) rotate (45) polyhedron (pts, tri1);
But in my case I just did some differences and unions. Nothing should
be generating holes. If there are holes (Slic3r reports zero of them
IIRC), that's a bug in Openscad (or one of the libraries it builds
on), and it should be looked into eventually what causes this in this
relatively simple case.
> take a look.
Aaargh....
Slic3r. Looks good.
Looks good.
> On Tue, 22 Nov 2022 at 14:43, Raymond West <raywest@raywest.com> wrote:
> > Hi Roger,
> > renderings.
> > translate ([5,0,0])
> > Roger.
> > OpenSCAD mailing list
Tue, Nov 22, 2022 4:07 PM
It might just be the F5 before F6 bug. If you don't flush the cache in
between you can get a broken STL because the preview can cache PolySets but
without them F6 will do it all in CGAL and get more accurate results.
take a look.
Aaargh....
Slic3r. Looks good.
Looks good.
Hi Roger,
renderings.
translate ([5,0,0])
> > take a look.
> Aaargh....
> Slic3r. Looks good.
> Looks good.
> Roger.
> > > Hi Roger,
> 1746d5a83). It
> throws a
> the
> may
> that
> at
> relatively
> if
> > > renderings.
> produces
> would
> seems
> successfully.
> says
> > > translate ([5,0,0])
> > > Roger.
> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
> f equals m times a. When your f is steady, and your m is going down
Tue, Nov 22, 2022 5:02 PM
That seems unlikely in my use-case. I don't use the Openscad editor. I
use an external editor and have openscad setup to reload/re-F5
automatically whenever I hit "save" in the external editor. So it would
take some millisecond-timing for me to mouse over to the openscad
window and hit F6 before it has re-drawn the project.
(F5 takes 95 ms first time and around 50ms second time. Reder is about 3.7
seconds on my computer).
take a look.
Aaargh....
Slic3r. Looks good.
Looks good.
Hi Roger,
renderings.
translate ([5,0,0])
> > > take a look.
> > Aaargh....
> > Slic3r. Looks good.
> > Looks good.
> > Roger.
> > > > Hi Roger,
> > 1746d5a83). It
> > throws a
> > the
> > may
> > that
> > at
> > relatively
> > if
> > > > renderings.
> > produces
> > would
> > seems
> > successfully.
> > says
> > > > translate ([5,0,0])
> > > > Roger.
