Unless you have access to pipe threading for the pipe for the cast iron
fittings, I would expect square section steel tube, or aluminium section
would be better. Plenty of fittings for furniture construction.
Aluminium is considerably easier to work with, lighter weight, needs no
surface finishing, can be cut with normal woodworking tools, etc., but
pipes and cast iron fittings can give you a steam punk effect, if that
is your thing.
Best wishes,
Ray
On 30/01/2022 14:52, Verachten Bruno wrote:
Hi there,
I am thinking of building a desk, but this time not with wood. I would
like to design it with openSCAD.
The structure would be made of metal, but I'm still hesitating between
iron heating pipes with cast iron fittings or aluminum extruded bars.
I have already found aluminum extruded bars within NopScad, I think
the threaded iron heating pipes should be fairly easy to build with
existing components.
Would you already have seen fittings like this designed with openSCAD:
https://homeinvasion.fr/collections/raccords-fonte-noire ?
I haven't found a library yet that does everything, just this set of
files that will help: CTV
https://www.thingiverse.com/thing:4323468
Best regards,
Lots of plans for PVC on the Internet.
I have a library of PVC fittings in OpenSCAD.
iron fittings, I would expect square section steel tube, or aluminium
section would be better. Plenty of fittings for furniture
construction. Aluminium is considerably easier to work with, lighter
weight, needs no surface finishing, can be cut with normal woodworking
tools, etc., but pipes and cast iron fittings can give you a steam
punk effect, if that is your thing.
Best wishes,
Ray
Hi there,
Best regards,
Ron Wheeler
Artifact Software
438-345-3369
