If you do an F5 on this, and look at it from above and below, sometimes
you see a half-bagel that is above the XY plane, and sometimes one below
the XY plane. Confusing. Is there any way to make it always show the
correct geometry?
// Sink Drain Food Catcher
bd = 80.7; // big diameter
br = bd/2;
sd = 47; // small diameter
ht = 44; // height
module Torus(of, ra)
rotate_extrude(convexity = 10, $fn = 100)
translate([ra + of, 0, 0])
circle(r = ra, $fn = 100);
module CutTorus(of, ra)
Torus(of, ra);
translate([-500, -500, 0])
cube(1000);
cube([br + 55, 1, 1]);
cube([1, 1, ht]);
CutTorus(0, 44);
Make the cube smaller, zoom out further or use orthogonal mode.
The cube gets clipped by the front clipping plane and that breaks OpeCSG.
On Mon, 26 Feb 2024 at 13:21, jon via Discuss discuss@lists.openscad.org
correct geometry?
br = bd/2;
ht = 44; // height
Torus(of, ra);
cube(1000);
cube([1, 1, ht]);
CutTorus(0, 44);
I’m on my iPad at the moment so can’t run your program, but this sounds like https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_does_difference_(or_intersection)_sometimes_not_work_in_preview? .
Running OpenSCAD version 2024.01.23 (git 88d244aed) with manifold checked.
It appears to preview fine, with the half torus always below the XY plane.
On Mon, Feb 26, 2024 at 12:05 PM Jordan Brown via Discuss <
like
previews fine, with or without manifold, but not f6
checked. It appears to preview fine, with the half torus always below
the XY plane.
sounds like
