K
Ken
Sun, Jul 7, 2024 12:46 AM
I am trying to both round and chamfer a cuboid but get the error
"WARNING: variable chamfer2 not specified as parameter" when I add the
chamfer.
Much searching on google hasn't found an an answer- is it even possible
to do both operations on the one line, or am I asking a bit too much?
If it is possible, what am I doing wrong?
include <BOSL2/rounding.scad>
$fa = 1;
$fs = 0.4;
color ("yellow")
rotate([0,0,0])
translate([0,0,0])
cuboid([46,31,6.5], rounding=15, edges="Z", chamfer2=1);
chamfer.
$fa = 1;
$fs = 0.4;
color ("yellow")
rotate([0,0,0])
translate([0,0,0])
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Sun, Jul 7, 2024 1:51 AM
The cuboid() call doesn't mix rounding and chamfering. It does one or the other, but not both at once. However, you can mix them up using intersection():
cuboid([46,31,6.5], edges=TOP, chamfer=1);
cuboid([46,31,6.5], rounding=15, edges="Z");
-Revar
On Jul 6, 2024, at 5:46 PM, Ken via Discuss discuss@lists.openscad.org wrote:
I am trying to both round and chamfer a cuboid but get the error "WARNING: variable chamfer2 not specified as parameter" when I add the chamfer.
Much searching on google hasn't found an an answer- is it even possible to do both operations on the one line, or am I asking a bit too much?
$fa = 1;
$fs = 0.4;
color ("yellow")
rotate([0,0,0])
translate([0,0,0])
The `cuboid()` call doesn't mix rounding and chamfering. It does one or the other, but not both at once. However, you can mix them up using `intersection()`:
-Revar
> On Jul 6, 2024, at 5:46 PM, Ken via Discuss <discuss@lists.openscad.org> wrote:
> include <BOSL2/std.scad>
> $fa = 1;
> $fs = 0.4;
> color ("yellow")
> rotate([0,0,0])
> translate([0,0,0])
> Cheers, Ken
> bats059@gmail.com
> https://vk7krj.com
> https://vk7krj.com/running.html
> A baby can be defined as an ego with a noise at one end and a smell at the other.
> Your job as parents is to teach them to control all three.
> My job as a grandad is to tell you how you are doing it all wrong!
K
Ken
Sun, Jul 7, 2024 2:38 AM
Thanks Revar, that explains why I get the error.
However, intersection only rounded some of the edges, so I finished up
using two cyl and a cuboid, each chamfered individually. That produced
the shape that I needed.
-Revar
$fa = 1;
$fs = 0.4;
color ("yellow")
rotate([0,0,0])
translate([0,0,0])
> intersection() {
> -Revar
>> On Jul 6, 2024, at 5:46 PM, Ken via Discuss<discuss@lists.openscad.org> wrote:
>> $fa = 1;
>> $fs = 0.4;
>> color ("yellow")
>> rotate([0,0,0])
>> translate([0,0,0])
>> Cheers, Ken
>> bats059@gmail.com
>> https://vk7krj.com
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Sun, Jul 7, 2024 5:12 AM
Actually the reason you get an error is that chamfer2 doesn’t exist because
cuboid just uses chamfer plus the edges= and except= parameters to control
chamfering. This is not directly related to cuboid not supporting
simultaneous rounding and chamfering.
If intersecting didn’t round enough edges it’s because you used the wrong
choice for the edges= parameter. By intersecting two cubes you can
individually round or chamfer every edge as desired.
Also note that more edge treatment options are available using
edge_profile()
On Sat, Jul 6, 2024 at 19:39 Ken via Discuss discuss@lists.openscad.org
using two cyl and a cuboid, each chamfered individually. That produced the
-Revar
On Jul 6, 2024, at 5:46 PM, Ken via Discuss discuss@lists.openscad.org discuss@lists.openscad.org wrote:
$fa = 1;
$fs = 0.4;
color ("yellow")
rotate([0,0,0])
translate([0,0,0])
Cheers, Kenbats059@gmail.comhttps://vk7krj.comhttps://vk7krj.com/running.html
edge_profile()
On Sat, Jul 6, 2024 at 19:39 Ken via Discuss <discuss@lists.openscad.org>
> intersection() {
> -Revar
> On Jul 6, 2024, at 5:46 PM, Ken via Discuss <discuss@lists.openscad.org> <discuss@lists.openscad.org> wrote:
> $fa = 1;
> $fs = 0.4;
> color ("yellow")
> rotate([0,0,0])
> translate([0,0,0])
K
Ken
Sun, Jul 7, 2024 6:11 AM
Thanks Adrian- I spent an hour or so trying out edge_profile(), but it
is a bit above my pay grade at the moment I'm afraid.
I tried an example given in the github page, it worked exactly as shown,
but as soon as I changed it to use my dimensions it gave errors. I have
given up for now, but will get back to it as time allows, using the help
I found in the BOSL2 attachments file.
edge_profile()
On Sat, Jul 6, 2024 at 19:39 Ken via Discussdiscuss@lists.openscad.org
-Revar
On Jul 6, 2024, at 5:46 PM, Ken via Discussdiscuss@lists.openscad.org discuss@lists.openscad.org wrote:
$fa = 1;
$fs = 0.4;
color ("yellow")
rotate([0,0,0])
translate([0,0,0])
Cheers,Kenbats059@gmail.comhttps://vk7krj.comhttps://vk7krj.com/running.html
> edge_profile()
> On Sat, Jul 6, 2024 at 19:39 Ken via Discuss<discuss@lists.openscad.org>
>> intersection() {
>> -Revar
>> On Jul 6, 2024, at 5:46 PM, Ken via Discuss<discuss@lists.openscad.org> <discuss@lists.openscad.org> wrote:
>> $fa = 1;
>> $fs = 0.4;
>> color ("yellow")
>> rotate([0,0,0])
>> translate([0,0,0])
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
