When executing the following code
$fn=200;
translate([0,.1,0])
Disk();
Cut_Ball();
module Ball()
sphere(10);
module Disk()
color("Silver")
intersection()
{ Ball();
translate([-12,-12,3]) cube([24,24,2]);
module Cut_Ball()
color("Red")
{ Ball();
As the code stands, a red sphere is generated, with a silver disk inside it
and some red/silver area on the circumference of the disk. When removing the
translate instruction in line 2, a uniformly red sphere is produced by
Preview (F5). Also, when changing $fn, the width of the red/silver area
changes.
To me it means that the code is not executed inside-out, as I would expect,
but rather outside-in, or, if you want, the module Ball() is colored first
and only then are the intersection() and difference() instructions carried
out.
Is that intentional?
wolf
PS.: I use version 2015.03-1 on Kubuntu 14.10
View this message in context: http://forum.openscad.org/Coloring-bug-tp16471.html
I'd call it a bug.
View this message in context: http://forum.openscad.org/Coloring-bug-tp16471p16472.html
out.
I believe this is an instance of https://github.com/openscad/openscad/issues/1000
In general OpenCSG doesn't work well with coincident faces but CGAL does.
If you put render() after color("Red") it works without the translate but
is obviously slow first time because of the $fn = 200.
I render all my objects before colouring them and composing them because
otherwise negative volumes from different objects that happen to coincide
cause Z buffer artefacts.
expect,
first
carried
out.
