somewhat off topic: turning a surface into a manifold
Sun, Sep 15, 2024 6:48 PM
I scanned some mushrooms on a tree with a 3D scanner, so I have a
surface, but the object is not closed, solid, or manifold.  Any tips
about how to take a surface and add structure to it behind to enable it
to be printed?
Thanks!
I scanned some mushrooms on a tree with a 3D scanner, so I have a surface, but the object is not closed, solid, or manifold.  Any tips about how to take a surface and add structure to it behind to enable it to be printed? Thanks! Jon -- This email has been checked for viruses by AVG antivirus software. www.avg.com
MP
Marcus Poller
Sun, Sep 15, 2024 8:22 PM
Hi Jon,
I am glad you ask.
(1) it will hurt.
(2) you may like my very experimental workaround.
Let's discuss your options first: Can your slicer deal with the 2d surface and generate a printed result? You would prefer that option.
Here is the idea: Most 3d scanners produce an STL. STL is a list of triangles in 3d space.
Your triangles are supposed to form a closed volume...
... which they aren't
... that is why you can't process the file with any tool.
If instead of using three coordinates to build a triangle...
... let us use three cubes on these coordinates to build a volume.
Run your STL through the attached script. It will generate an OpenSCAD-shape using translate() cube() and hull()
. You can render this shape to get a volume.
Depending on the amount of coordinates, it will take minutes to hours to render your scan. You will not be able to alter the camera angle in preview. You will not be able to zoom in preview.
That will convert your 2d surface area into a 3d volume, that can be handled by most tools. Since it is autogenerated, you cannot postprocess it in any meaningful way (too many coordinates).
If you find this 2d->3d conversion helpfull, you may like to add an additional center cube to hull() to get a closed volume.
Instructions:
In the file stl_to_polyhedron.py replace "zoe4.stl" with your STL-file name.
Run as
python3 stl_to_polyhedron.py >tree_with_mushrooms.scad
@mailinglist:
What is the correct call for a command line OpenSCAD to read a source file and auto generate an STL?
Cheers,
Marcus
Hi Jon, > I scanned some mushrooms on a tree with a 3D scanner, so I have a surface, > but the object is not closed, solid, or manifold.  Any tips about how to > take a surface and add structure to it behind to enable it to be printed? I am glad you ask. (1) it will hurt. (2) you may like my very experimental workaround. Let's discuss your options first: Can your slicer deal with the 2d surface and generate a printed result? You would prefer that option. Here is the idea: Most 3d scanners produce an STL. STL is a list of triangles in 3d space. Your triangles are supposed to form a closed volume... ... which they aren't ... that is why you can't process the file with any tool. If instead of using three coordinates to build a triangle... ... let us use three cubes on these coordinates to build a volume. Run your STL through the attached script. It will generate an OpenSCAD-shape using translate() cube() and hull() . You can render this shape to get a volume. Depending on the amount of coordinates, it will take minutes to hours to render your scan. You will not be able to alter the camera angle in preview. You will not be able to zoom in preview. That will convert your 2d surface area into a 3d volume, that can be handled by most tools. Since it is autogenerated, you cannot postprocess it in any meaningful way (too many coordinates). If you find this 2d->3d conversion helpfull, you may like to add an additional center cube to hull() to get a closed volume. Instructions: In the file stl_to_polyhedron.py replace "zoe4.stl" with your STL-file name. Run as python3 stl_to_polyhedron.py >tree_with_mushrooms.scad @mailinglist: What is the correct call for a command line OpenSCAD to read a source file and auto generate an STL? Cheers, Marcus
JJ
jon jonbondy.com
Sun, Sep 15, 2024 8:38 PM
Marcus:
Thank you.  Where do I find Python3 to install, please.  Is Python3 just
regular Python, or something different?  I know nothing about Python.
On 9/15/2024 4:22 PM, Marcus Poller wrote:
Hi Jon,
I am glad you ask.
(1) it will hurt.
Instructions:
Run as
@mailinglist:
Cheers,
Marcus
Marcus: Thank you.  Where do I find Python3 to install, please.  Is Python3 just regular Python, or something different?  I know nothing about Python. Jon On 9/15/2024 4:22 PM, Marcus Poller wrote: > Hi Jon, > >> I scanned some mushrooms on a tree with a 3D scanner, so I have a surface, >> but the object is not closed, solid, or manifold.  Any tips about how to >> take a surface and add structure to it behind to enable it to be printed? > I am glad you ask. > > (1) it will hurt. > > (2) you may like my very experimental workaround. > > Let's discuss your options first: Can your slicer deal with the 2d surface and generate a printed result? You would prefer that option. > > Here is the idea: Most 3d scanners produce an STL. STL is a list of triangles in 3d space. > Your triangles are supposed to form a closed volume... > ... which they aren't > ... that is why you can't process the file with any tool. > > If instead of using three coordinates to build a triangle... > ... let us use three cubes on these coordinates to build a volume. > > Run your STL through the attached script. It will generate an OpenSCAD-shape using translate() cube() and hull() > . You can render this shape to get a volume. > Depending on the amount of coordinates, it will take minutes to hours to render your scan. You will not be able to alter the camera angle in preview. You will not be able to zoom in preview. > That will convert your 2d surface area into a 3d volume, that can be handled by most tools. Since it is autogenerated, you cannot postprocess it in any meaningful way (too many coordinates). > > If you find this 2d->3d conversion helpfull, you may like to add an additional center cube to hull() to get a closed volume. > > Instructions: > In the file stl_to_polyhedron.py replace "zoe4.stl" with your STL-file name. > Run as > > python3 stl_to_polyhedron.py >tree_with_mushrooms.scad > > > @mailinglist: > What is the correct call for a command line OpenSCAD to read a source file and auto generate an STL? > > Cheers, > Marcus >
JJ
jon jonbondy.com
Sun, Sep 15, 2024 8:45 PM
Never mind.  I found and installed Python, 3.126, from here:
https://www.python.org/downloads/release/python-3126/
After installation, typing "py" at a command line does not work. Typing
"python" brings me to the Microsoft Store.  Typing "python3" brings me
top the MS store.  Typing "python3.12" does not work.  Typing
"python3.12.6" does not work.
Hi Jon,
I am glad you ask.
(1) it will hurt.
Instructions:
Run as
@mailinglist:
Cheers,
Marcus
Never mind.  I found and installed Python, 3.126, from here: https://www.python.org/downloads/release/python-3126/ After installation, typing "py" at a command line does not work. Typing "python" brings me to the Microsoft Store.  Typing "python3" brings me top the MS store.  Typing "python3.12" does not work.  Typing "python3.12.6" does not work. On 9/15/2024 4:22 PM, Marcus Poller wrote: > Hi Jon, > >> I scanned some mushrooms on a tree with a 3D scanner, so I have a surface, >> but the object is not closed, solid, or manifold.  Any tips about how to >> take a surface and add structure to it behind to enable it to be printed? > I am glad you ask. > > (1) it will hurt. > > (2) you may like my very experimental workaround. > > Let's discuss your options first: Can your slicer deal with the 2d surface and generate a printed result? You would prefer that option. > > Here is the idea: Most 3d scanners produce an STL. STL is a list of triangles in 3d space. > Your triangles are supposed to form a closed volume... > ... which they aren't > ... that is why you can't process the file with any tool. > > If instead of using three coordinates to build a triangle... > ... let us use three cubes on these coordinates to build a volume. > > Run your STL through the attached script. It will generate an OpenSCAD-shape using translate() cube() and hull() > . You can render this shape to get a volume. > Depending on the amount of coordinates, it will take minutes to hours to render your scan. You will not be able to alter the camera angle in preview. You will not be able to zoom in preview. > That will convert your 2d surface area into a 3d volume, that can be handled by most tools. Since it is autogenerated, you cannot postprocess it in any meaningful way (too many coordinates). > > If you find this 2d->3d conversion helpfull, you may like to add an additional center cube to hull() to get a closed volume. > > Instructions: > In the file stl_to_polyhedron.py replace "zoe4.stl" with your STL-file name. > Run as > > python3 stl_to_polyhedron.py >tree_with_mushrooms.scad > > > @mailinglist: > What is the correct call for a command line OpenSCAD to read a source file and auto generate an STL? > > Cheers, > Marcus >
Sun, Sep 15, 2024 9:11 PM
Try googling how to add python to path
On Sun, Sep 15, 2024, 3:45 PM jon jonbondy.com via Discuss <
Hi Jon,
surface,
printed?
I am glad you ask.
(1) it will hurt.
Instructions:
name.
Run as
@mailinglist:
Cheers,
Marcus
Try googling how to add python to path On Sun, Sep 15, 2024, 3:45 PM jon jonbondy.com via Discuss < discuss@lists.openscad.org> wrote: > Never mind. I found and installed Python, 3.126, from here: > > https://www.python.org/downloads/release/python-3126/ > > After installation, typing "py" at a command line does not work. Typing > "python" brings me to the Microsoft Store. Typing "python3" brings me > top the MS store. Typing "python3.12" does not work. Typing > "python3.12.6" does not work. > > > On 9/15/2024 4:22 PM, Marcus Poller wrote: > > Hi Jon, > > > >> I scanned some mushrooms on a tree with a 3D scanner, so I have a > surface, > >> but the object is not closed, solid, or manifold. Any tips about how to > >> take a surface and add structure to it behind to enable it to be > printed? > > I am glad you ask. > > > > (1) it will hurt. > > > > (2) you may like my very experimental workaround. > > > > Let's discuss your options first: Can your slicer deal with the 2d > surface and generate a printed result? You would prefer that option. > > > > Here is the idea: Most 3d scanners produce an STL. STL is a list of > triangles in 3d space. > > Your triangles are supposed to form a closed volume... > > ... which they aren't > > ... that is why you can't process the file with any tool. > > > > If instead of using three coordinates to build a triangle... > > ... let us use three cubes on these coordinates to build a volume. > > > > Run your STL through the attached script. It will generate an > OpenSCAD-shape using translate() cube() and hull() > > . You can render this shape to get a volume. > > Depending on the amount of coordinates, it will take minutes to hours to > render your scan. You will not be able to alter the camera angle in > preview. You will not be able to zoom in preview. > > That will convert your 2d surface area into a 3d volume, that can be > handled by most tools. Since it is autogenerated, you cannot postprocess it > in any meaningful way (too many coordinates). > > > > If you find this 2d->3d conversion helpfull, you may like to add an > additional center cube to hull() to get a closed volume. > > > > Instructions: > > In the file stl_to_polyhedron.py replace "zoe4.stl" with your STL-file > name. > > Run as > > > > python3 stl_to_polyhedron.py >tree_with_mushrooms.scad > > > > > > @mailinglist: > > What is the correct call for a command line OpenSCAD to read a source > file and auto generate an STL? > > > > Cheers, > > Marcus > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
MP
Marcus Poller
Tue, Sep 17, 2024 10:48 AM
Hi Jon,
I cannot support Python remotely, I do not support Windows at all.
I can offer: Send me your STL (preferably upload it and send me a download link) and I will process it for you.
Cheers,
Marcus
Hi Jon, > Never mind.  I found and installed Python, 3.126, from here: > After installation, typing "py" at a command line does not work. I cannot support Python remotely, I do not support Windows at all. I can offer: Send me your STL (preferably upload it and send me a download link) and I will process it for you. Cheers, Marcus
