HL
Hans L
Mon, Dec 2, 2019 8:48 PM
For instance right now I'm working on a library for doing affine
transforms on points/paths, to help me build up objects for use with
polyhedron().
Hi Max, not sure how much of this you've already implemented, but I have a
library for essentially the same purpose, here:
https://github.com/thehans/FunctionalOpenSCAD
It doesn't compose matrices, and was written before (still experimental)
first class function support, but maybe some of the code will still be
useful for you.
> polyhedron().
useful for you.
MB
Max Bond
Mon, Dec 2, 2019 9:40 PM
Thanks Hans, I'll check that out!
polyhedron().
>> polyhedron().
> useful for you.
W
WillAdams
Sun, Dec 22, 2019 6:50 AM
The thing which I'd really like to see is a mode where OpenSCAD is a
Workbench in FreeCAD --- model in OpensCAD using the language, then switch
to the drawing/edit view and be able to adjust things
graphically/interactively which would update the parameters of the code (for
bonus points, modifications/additions would be instantiated as new OpenSCAD
code).
code).
richalt2
Fri, Jan 31, 2020 7:20 PM
Belatedly I will kick in:
- multi-threading for performance!
- I would love to get access to the pixel data in surface(), both greyscale
and RGB!! And not have surface() produce an object. Just the data
please.
1. multi-threading for performance!
2. I would love to get access to the pixel data in surface(), both greyscale
and RGB!! And *not* have surface() produce an object. Just the data
please.
Fri, Jan 31, 2020 8:12 PM
On Jan 31, 2020, at 20:20, richalt2 via Discuss discuss@lists.openscad.org wrote:
please.
I don’t quite understand this wish: surface() is a module that takes pixel data as input and generates a shape, so if you just look at your input, that’s pixel data right there.
> On Jan 31, 2020, at 20:20, richalt2 via Discuss <discuss@lists.openscad.org> wrote:
> please.
richalt2
Fri, Jan 31, 2020 8:31 PM
Marius, yes I use surface() sometimes. To get pixel data I presently run a
python script which outputs an openscad list containing the RGB data, into a
.txt file. Then include the .txt.
Can I avoid or automate the python run? Can you offer a snippet of openscad
code which shows echo(some rgb data from a .png file) ?
Thanks!!
Rich
richalt2 (so why does the forum show me as OpenSCAD mailing list?)
Rich Altmaier
Thanks!!
Rich
Rich Altmaier
Fri, Jan 31, 2020 10:22 PM
Thanks for the explanation. I understand your use-case and request now.
Running an external script is probably the best solution right now.
On Jan 31, 2020, at 21:31, richalt2 via Discuss discuss@lists.openscad.org wrote:
Thanks!!
Rich
> On Jan 31, 2020, at 21:31, richalt2 via Discuss <discuss@lists.openscad.org> wrote:
> Thanks!!
> Rich
C
caterpillar
Mon, Feb 10, 2020 6:23 AM
maybe things like this?
<http://forum.openscad.org/file/t1825/photo_sphere.jpg>
source code:
https://github.com/JustinSDK/dotSCAD/blob/master/examples/photo_sphere.scad
https://openhome.cc
C
caterpillar
Mon, Feb 10, 2020 6:32 AM
source code:
https://openhome.cc
C
caterpillar
Thu, Feb 20, 2020 6:44 AM
More examples when you can get pixel data ....
<http://forum.openscad.org/file/t1825/ex.jpg>
https://openhome.cc
