User Poll: What do you want to see from OpenSCAD development?
arnholm@arnholm.org
Mon, Nov 11, 2019 4:02 PM
On 2019-11-11 05:15, Doug Moen wrote:
On Sun, Nov 10, 2019, at 2:47 AM, Jordan Brown wrote:
cube(1);
translate([1,1,0]) cube(1);
The specific problem being referenced here is that if you have two
polyhedra that don't intersect (with a non-zero intersection volume),
but they touch at a vertex or touch at an edge, then you can't
represent that in an STL file, because the polygon mesh is not
2-manifold.
Actually, this is not correct. STL as such has no issues representing
such a thing. STL has no shared vertices or edges at all, every vertex
is duplicated for each triangle, and there are no explicit edges. The
problem is not representing such a thing in STL, the problem is
interpreting it consistently by OpenSCAD or any other program reading
it.
An STL file is a "polygon soup", it is simply a set of totally
disconnected triangles with zero shared topology. Such topology must be
guessed at by the program reading it, by comparing coordinates. This is
totally different from most other formats such as OBJ, OFF, AMF or 3MF
where the topology is explicitly represented.
For this reason, STL is particularly unsuitable for sharing models
between CAD applications. A slicer program is more forgiving so that
works better with STL.
This restriction is a problem for users, because it means that shapes
are not closed under union. You can take two valid shapes (cubes in
the above example), union them together, and the result is not
considered valid.
This limitation really only exists because of the STL file format.
No, this is not true. STL has no issues representing this case or any
other case, it does not care about non-manifoldness. It is not STL that
complains in this case, this issue is totally unrelated to STL.
The warning that the model is not 2-manifold can be considered false
alarm in some cases, whether it is a problem or not depends on the
intended use of the model. There is nothing wrong topologically with two
cubes sharing an edge in this way, it just happens to not be 2-manifold.
Manifoldness in this context means "how many times an edge is shared
between adjacent faces". An edge is the topological connection between 2
vertices. For a clean, closed volume every edge is used twice, hence it
is 2-manifold. In this case there are 2 volumes sharing an edge, so that
edge becomes 4-manifold as it is referenced by 4 faces.
But manifoldness is totally irrelevant in the STL file format, you can
write this file to STL without any issue. You can also write a single
triangle to an STL without any issue, there is no volume in that case.
The problem with STL is not that it is limited or restrictive, the
problem with STL is that there are no rules at all, so interpretation of
it becomes a problem.
This limitation doesn't exist in the 3MF file format, which explicitly
supports these kinds of models.
Any of STL, OBJ, OFF, AMF will of course support such a model. It is not
a question of file format.
This statement might be surprising or controversial. The way it works
is: 3MF uses a different mesh representation than STL.
As does OBJ, OFF and AMF. All of them use the kind of topology you
describe below.
In 3MF, there
is an array of points, each point has a numeric ID. Then there is a
separate array of triangles: each triangle is represented by 3 point
IDs, which are indexes into the point array. In a "non-manifold Nef
Polyhedron" (like the 2 cubes in the example), there are 2 or more
disjoint volumes that touch at one or more vertices. These "shared
vertices" must be duplicated in the 3MF points array, so that each
disjoint volume refers to the same shared vertices using distinct
point IDs. Only then do you have a valid 3MF representation. The 3MF
standard discusses this in section 4.1.3: "The producer SHOULD NOT
include duplicate vertices unless coalescing duplicates would create
non-manifold edges."
Not duplicating the vertices is what is causing the edge to be
4-manifold. If 3MF require all edges to be 2-manifold, it is 3MF that is
extra restrictive.
As far as I can tell, CGAL provides the necessary APIs that could be
used to export a non-manifold Nef Polyhedron to a 3MF file, without
creating an invalid 3MF file.
But that seems to violate the rule you just referred to?
On 2019-11-11 05:15, Doug Moen wrote: > On Sun, Nov 10, 2019, at 2:47 AM, Jordan Brown wrote: >>> cube(1); >>> translate([1,1,0]) cube(1); > > The specific problem being referenced here is that if you have two > polyhedra that don't intersect (with a non-zero intersection volume), > but they touch at a vertex or touch at an edge, then you can't > represent that in an STL file, because the polygon mesh is not > 2-manifold. Actually, this is not correct. STL as such has no issues representing such a thing. STL has no shared vertices or edges at all, every vertex is duplicated for each triangle, and there are no explicit edges. The problem is not representing such a thing in STL, the problem is interpreting it consistently by OpenSCAD or any other program reading it. An STL file is a "polygon soup", it is simply a set of totally disconnected triangles with zero shared topology. Such topology must be guessed at by the program reading it, by comparing coordinates. This is totally different from most other formats such as OBJ, OFF, AMF or 3MF where the topology is explicitly represented. For this reason, STL is particularly unsuitable for sharing models between CAD applications. A slicer program is more forgiving so that works better with STL. > This restriction is a problem for users, because it means that shapes > are not closed under union. You can take two valid shapes (cubes in > the above example), union them together, and the result is not > considered valid. > > This limitation really only exists because of the STL file format. No, this is not true. STL has no issues representing this case or any other case, it does not care about non-manifoldness. It is not STL that complains in this case, this issue is totally unrelated to STL. The warning that the model is not 2-manifold can be considered false alarm in some cases, whether it is a problem or not depends on the intended use of the model. There is nothing wrong topologically with two cubes sharing an edge in this way, it just happens to not be 2-manifold. Manifoldness in this context means "how many times an edge is shared between adjacent faces". An edge is the topological connection between 2 vertices. For a clean, closed volume every edge is used twice, hence it is 2-manifold. In this case there are 2 volumes sharing an edge, so that edge becomes 4-manifold as it is referenced by 4 faces. But manifoldness is totally irrelevant in the STL file format, you can write this file to STL without any issue. You can also write a single triangle to an STL without any issue, there is no volume in that case. The problem with STL is not that it is limited or restrictive, the problem with STL is that there are no rules at all, so interpretation of it becomes a problem. > This limitation doesn't exist in the 3MF file format, which explicitly > supports these kinds of models. Any of STL, OBJ, OFF, AMF will of course support such a model. It is not a question of file format. > This statement might be surprising or controversial. The way it works > is: 3MF uses a different mesh representation than STL. As does OBJ, OFF and AMF. All of them use the kind of topology you describe below. > In 3MF, there > is an array of points, each point has a numeric ID. Then there is a > separate array of triangles: each triangle is represented by 3 point > IDs, which are indexes into the point array. In a "non-manifold Nef > Polyhedron" (like the 2 cubes in the example), there are 2 or more > disjoint volumes that touch at one or more vertices. These "shared > vertices" must be duplicated in the 3MF points array, so that each > disjoint volume refers to the same shared vertices using distinct > point IDs. Only then do you have a valid 3MF representation. The 3MF > standard discusses this in section 4.1.3: "The producer SHOULD NOT > include duplicate vertices unless coalescing duplicates would create > non-manifold edges." Not duplicating the vertices is what is causing the edge to be 4-manifold. If 3MF require all edges to be 2-manifold, it is 3MF that is extra restrictive. > As far as I can tell, CGAL provides the necessary APIs that could be > used to export a non-manifold Nef Polyhedron to a 3MF file, without > creating an invalid 3MF file. But that seems to violate the rule you just referred to? Carsten Arnholm
jang0
Tue, Nov 12, 2019 1:42 AM
I would like that OpenSCAD have a "technical draft" focus, the aim of a
technical draft is to facilitate the comunication between the person that
design a part and the people that manufacture it; in this sense developers
can implement specialized functions like those: create iso A, iso E
projectios, dimensioning drawings, create title blocks, etc. Already some
users implemented that; nevertheless there are not so polish functions and
overcomplicate the process of make a draft. In example doesn't take into
account hidden lines or geometry and take a lot of extra work compared to a
GUI technical draft software.
An advantage of OpenSCAD compared to those software is that you can avoid
"mouse" usage; this is very usefull with work that require long designing
periods that harm your wrist. Will be very helpfull if we could create
"professional" technical drafts too.
I would like that OpenSCAD have a "technical draft" focus, the aim of a technical draft is to facilitate the comunication between the person that design a part and the people that manufacture it; in this sense developers can implement specialized functions like those: create iso A, iso E projectios, dimensioning drawings, create title blocks, etc. Already some users implemented that; nevertheless there are not so polish functions and overcomplicate the process of make a draft. In example doesn't take into account hidden lines or geometry and take a lot of extra work compared to a GUI technical draft software. An advantage of OpenSCAD compared to those software is that you can avoid "mouse" usage; this is very usefull with work that require long designing periods that harm your wrist. Will be very helpfull if we could create "professional" technical drafts too. -- Sent from: http://forum.openscad.org/
SC
Sarah Cartwright
Tue, Nov 12, 2019 2:37 AM
I'd love the "thrown together" option to display holes, and intersecting
polygons.
Very useful for STL file imports.
Would it be possible to fix intersecting polygons, zero volume polygons and
holes in OpenSCAD's import?
It sounds difficult - but would make including existing models so much
easier.
I'd love the "thrown together" option to display holes, and intersecting polygons. Very useful for STL file imports. Would it be possible to fix intersecting polygons, zero volume polygons and holes in OpenSCAD's import? It sounds difficult - but would make including existing models so much easier. On Tue, 12 Nov 2019 at 01:30, jang0 <ydmorenoc@unal.edu.co> wrote: > I would like that OpenSCAD have a "technical draft" focus, the aim of a > technical draft is to facilitate the comunication between the person that > design a part and the people that manufacture it; in this sense developers > can implement specialized functions like those: create iso A, iso E > projectios, dimensioning drawings, create title blocks, etc. Already some > users implemented that; nevertheless there are not so polish functions and > overcomplicate the process of make a draft. In example doesn't take into > account hidden lines or geometry and take a lot of extra work compared to a > GUI technical draft software. > An advantage of OpenSCAD compared to those software is that you can avoid > "mouse" usage; this is very usefull with work that require long designing > periods that harm your wrist. Will be very helpfull if we could create > "professional" technical drafts too. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Rob Ward
Tue, Nov 12, 2019 3:55 AM
Aspect 3:
My wish would be for an exportable 2D view (in SVG) of an elevation (xy
or yz or zx or definable) profile that preserved the colours of the
model as seen in preview mode.
I believe someone could write a coloured plane to CAM-GCode package from
such an image for routing, milling or laser work. I hesitate to say it
would be simple only for the fact I would certainly not find it simple,
but others could find it easier? Certainly, if possible, it could
release a lot more of OpenSCAD goodness into these other worlds (eg via
Inkscape+add-ons).
It would also be handy for documentation and trial fit purposes.
Rob
On 10/11/19 9:22 am, Hans L wrote:
Hi everyone,
I wanted to get some input and have a bit of discussion from users
here, regarding what they would most like to see from current or
near-future OpenSCAD development.
What do you feel is the most important aspect to focus on, or would
have the biggest impact to your experience using OpenSCAD:
  1. Stability, squash more bugs in general
  2. Optimize existing code, make OpenSCAD faster
  3. Addition of new features
  4. More / improved documentation
  5. All of the above should be balanced equally
  6. Nothing, I am content
  7. Something else not mentioned
If you have a specific issue in mind related to your choice, please
describe and link to it if there is an existing github issue.
Disclaimer: I am not a project owner for OpenSCAD, I just contribute
code when / where I can.  So this poll is not "official", just created
out of my personal curiosity. There is no guarantee that I or other
volunteer developers will directly address any issues raised here.
Happy modeling,
Hans Loeblich
Aspect 3: My wish would be for an exportable 2D view (in SVG) of an elevation (xy or yz or zx or definable) profile that preserved the colours of the model as seen in preview mode. I believe someone could write a coloured plane to CAM-GCode package from such an image for routing, milling or laser work. I hesitate to say it would be simple only for the fact I would certainly not find it simple, but others could find it easier? Certainly, if possible, it could release a lot more of OpenSCAD goodness into these other worlds (eg via Inkscape+add-ons). It would also be handy for documentation and trial fit purposes. Rob On 10/11/19 9:22 am, Hans L wrote: > Hi everyone, > > I wanted to get some input and have a bit of discussion from users > here, regarding what they would most like to see from current or > near-future OpenSCAD development. > > What do you feel is the most important aspect to focus on, or would > have the biggest impact to your experience using OpenSCAD: > > 1) Stability, squash more bugs in general > 2) Optimize existing code, make OpenSCAD faster > 3) Addition of new features > 4) More / improved documentation > 5) All of the above should be balanced equally > 6) Nothing, I am content > 7) Something else not mentioned > > If you have a specific issue in mind related to your choice, please > describe and link to it if there is an existing github issue. > > Disclaimer: I am not a project owner for OpenSCAD, I just contribute > code when / where I can. So this poll is not "official", just created > out of my personal curiosity. There is no guarantee that I or other > volunteer developers will directly address any issues raised here. > > Happy modeling, > Hans Loeblich > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Nov 12, 2019 4:23 AM
On 11/10/2019 11:33 PM, nop head wrote:
Regardless of file format limitations, non manifold objects cannot
exist in reality, so I think it should be an error to make one and
users should be educated.
Two cubes cannot share a zero width edge. They either overlap by at
least one atom or are separate. It is no coincidence that STL can
represents all physically realisable objects.
While that's mathematically true, in practical reality it's not.
In practical reality I can jam two cubes edge-to-edge and get something
that sure looks like a shared zero-width edge.  Is it really?  It might
be separated by just a little, or down at the atomic level the two might
interpenetrate just a little.  Who cares?  When the printer is spitting
out 0.4mm plastic with a resolution best measured in fractions of a
millimeter, there's no practical difference between a separation of one
micrometer, zero, and an overlap of one micrometer.  The printer can't
represent any of them accurately, so it doesn't matter what it does.
If I have
cube(100);
translate([0,0,100]) cube(50);
translate([50,50,100]) cube(50);
it's clear that the two upper cubes are attached to the lower cube, and
it doesn't matter whether they're attached to each other.  There is no
practical reason why it should be different from
cube(100);
translate([0,0,100]) cube(50.001);
or
cube(100);
translate([0,0,100]) cube(49.999);
... and yet it is.
I would say that it would be correct in any of those cases for the
printer to draw a continuous line across the joint, or to not draw a
continuous line across the joint.  The joint is below its extrusion
width and so exactly what it should do is not well-defined.  (In fact,
it should probably be a user option what to do with volumes that are
below half the extrusion width - either round them out of existence, or
say that every volume deserves to be represented, if only as a single
extrusion.
2D programs deal with hairlines all the time; this seems like the same case.
On 11/10/2019 11:33 PM, nop head wrote: > Regardless of file format limitations, non manifold objects cannot > exist in reality, so I think it should be an error to make one and > users should be educated. > > Two cubes cannot share a zero width edge. They either overlap by at > least one atom or are separate. It is no coincidence that STL can > represents all physically realisable objects. While that's mathematically true, in practical reality it's not. In practical reality I can jam two cubes edge-to-edge and get something that sure looks like a shared zero-width edge.  Is it really?  It might be separated by just a little, or down at the atomic level the two might interpenetrate just a little.  Who cares?  When the printer is spitting out 0.4mm plastic with a resolution best measured in fractions of a millimeter, there's no practical difference between a separation of one micrometer, zero, and an overlap of one micrometer.  The printer can't represent any of them accurately, so it doesn't matter what it does. If I have cube(100); translate([0,0,100]) cube(50); translate([50,50,100]) cube(50); it's clear that the two upper cubes are attached to the lower cube, and it doesn't matter whether they're attached to each other.  There is no practical reason why it should be different from cube(100); translate([0,0,100]) cube(50.001); translate([50,50,100]) cube(50); or cube(100); translate([0,0,100]) cube(49.999); translate([50,50,100]) cube(50); ... and yet it is. I would say that it would be correct in any of those cases for the printer to draw a continuous line across the joint, or to not draw a continuous line across the joint.  The joint is below its extrusion width and so exactly what it should do is not well-defined.  (In fact, it should probably be a user option what to do with volumes that are below half the extrusion width - either round them out of existence, or say that every volume deserves to be represented, if only as a single extrusion. 2D programs deal with hairlines all the time; this seems like the same case.
SD
Steven Dick
Tue, Nov 12, 2019 4:50 AM
Openscad is not a mesh editor.  You might be able to do simple things like
fixing round off errors  during import (which is an eternal problem with
STLs since every vertex is listed separately for every instance of every
edge) ,  but fixing problems like holes and intersecting polygons is the
job of a mesh editor like blender or meshlab.  Use the right tool for the
right job.
Zero size polygons are similar to round off errors.  Some holes and cracks
are not real and are caused by the importer not recognizing two instances
of the same edge due to round off errors, and I can see the importer fixing
these, but a real hole  or intersecting faces from a malformed mesh is much
harder to fix.
polygons.
easier.
Openscad is not a mesh editor. You might be able to do simple things like fixing round off errors during import (which is an eternal problem with STLs since every vertex is listed separately for every instance of every edge) , but fixing problems like holes and intersecting polygons is the job of a mesh editor like blender or meshlab. Use the right tool for the right job. Zero size polygons are similar to round off errors. Some holes and cracks are not real and are caused by the importer not recognizing two instances of the same edge due to round off errors, and I can see the importer fixing these, but a real hole or intersecting faces from a malformed mesh is much harder to fix. On Mon, Nov 11, 2019 at 9:38 PM Sarah Cartwright <sarah@untamed.zone> wrote: > > I'd love the "thrown together" option to display holes, and intersecting > polygons. > Very useful for STL file imports. > > Would it be possible to fix intersecting polygons, zero volume polygons > and holes in OpenSCAD's import? > It sounds difficult - but would make including existing models so much > easier. >
AP
Adam Purdie
Tue, Nov 12, 2019 5:24 AM
My suggestions:
  1. Have a way of integrating custom libraries at the openscad level, i
    currently do "import(../../../project/projectfile.scad)" and it's a little
    tedious, a basic library path like the Arduino app has would be cool
  2. make it so exports can retain colours (or colors if you wish) - may not
    be feasible for the current export formats
  3. make the default features overrideable like in normal OO - for example
    the default center value is "center=false" it would be really nice to be
    able to say something like:
    module square($params) {
    params[center] = true;
    default_square($params)
  4. Create some kinda scheduler for the command line that runs multiple
    processes across threads - i currently do this with my own python code and
    it saves me heaps of rendering time to use all 12 vcpu's :)
right job.
harder to fix.
polygons.
easier.
My suggestions: 1. Have a way of integrating custom libraries at the openscad level, i currently do "import(../../../project/projectfile.scad)" and it's a little tedious, a basic library path like the Arduino app has would be cool 2. make it so exports can retain colours (or colors if you wish) - may not be feasible for the current export formats 3. make the default features overrideable like in normal OO - for example the default center value is "center=false" it would be really nice to be able to say something like: module square($params) { params[center] = true; default_square($params) } 4. Create some kinda scheduler for the command line that runs multiple processes across threads - i currently do this with my own python code and it saves me heaps of rendering time to use all 12 vcpu's :) On Tue, 12 Nov 2019 at 15:50, Steven Dick <kg4ydw@gmail.com> wrote: > Openscad is not a mesh editor. You might be able to do simple things like > fixing round off errors during import (which is an eternal problem with > STLs since every vertex is listed separately for every instance of every > edge) , but fixing problems like holes and intersecting polygons is the > job of a mesh editor like blender or meshlab. Use the right tool for the > right job. > > Zero size polygons are similar to round off errors. Some holes and cracks > are not real and are caused by the importer not recognizing two instances > of the same edge due to round off errors, and I can see the importer fixing > these, but a real hole or intersecting faces from a malformed mesh is much > harder to fix. > > On Mon, Nov 11, 2019 at 9:38 PM Sarah Cartwright <sarah@untamed.zone> > wrote: > >> >> I'd love the "thrown together" option to display holes, and intersecting >> polygons. >> Very useful for STL file imports. >> >> Would it be possible to fix intersecting polygons, zero volume polygons >> and holes in OpenSCAD's import? >> It sounds difficult - but would make including existing models so much >> easier. >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Nov 12, 2019 6:34 AM
Nothing is certain https://en.wikipedia.org/wiki/Uncertainty_principle the
edge is a waveform, electron orbits are also waveforms, so who can tell...
Unless you have:
Heisenberg compensators remove uncertainty from the subatomic
measurements, making transporter travel feasible. Further technology
involved in transportation include a computer pattern buffer to enable a
degree of leeway in the process. When asked "How does the Heisenberg
compensator work?" by Time magazine, Star Trek technical adviser Michael
Okuda responded: "It works very well, thank you."
JordanBrown wrote > On 11/10/2019 11:33 PM, nop head wrote: >> Regardless of file format limitations, non manifold objects cannot >> exist in reality, so I think it should be an error to make one and >> users should be educated. >> >> Two cubes cannot share a zero width edge. They either overlap by at >> least one atom or are separate. It is no coincidence that STL can >> represents all physically realisable objects. > > While that's mathematically true, in practical reality it's not. > > In practical reality I can jam two cubes edge-to-edge and get something > that sure looks like a shared zero-width edge.  Is it really?  Nothing is certain https://en.wikipedia.org/wiki/Uncertainty_principle the edge is a waveform, electron orbits are also waveforms, so who can tell... Unless you have: > Heisenberg compensators remove uncertainty from the subatomic > measurements, making transporter travel feasible. Further technology > involved in transportation include a computer pattern buffer to enable a > degree of leeway in the process. When asked "How does the Heisenberg > compensator work?" by Time magazine, Star Trek technical adviser Michael > Okuda responded: "It works very well, thank you." ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
Tue, Nov 12, 2019 7:19 AM
Adam,
OpenSCAD looks at the OPENSCADPATH environment variable for places to
find libraries.
Jordon,
Since all real objects are 2-manifold I don't see why OpenSCAD needs to be
able to handle non-manifold designs. What advantage is it?
If you want to print two cubes next to each then leave a small gap. They
will then get two separate perimeters. If you want to print two cubes that
are joined overlap them by your printers minimum wall width. Your model
then represents what  you want your printer to print. If you export two
cubes sharing an edge who knows what the printer will do? It is much better
to give an error as soon as possible to avoid creating a model that can't
be printed. Yes the printer may print something but it won't match the
physically impossible model.
In answer to the original question. I don't find OpenSCAD limiting for
creating my designs at the moment. What I would like to see is module
literals to match function literals and a dict / record type. That would
tidy up my code.
A faster geometry engine like Carve looks like it would transform OpenSCAD
as a faster union would allow 3D Minkowski to be fast and that would allow
3D rounding to be practical.
On Tue, 12 Nov 2019 at 05:25, Adam Purdie adam@symmetry.ninja wrote:
My suggestions:
the right job.
polygons.
easier.
Adam, OpenSCAD looks at the OPENSCADPATH environment variable for places to find libraries. Jordon, Since all real objects are 2-manifold I don't see why OpenSCAD needs to be able to handle non-manifold designs. What advantage is it? If you want to print two cubes next to each then leave a small gap. They will then get two separate perimeters. If you want to print two cubes that are joined overlap them by your printers minimum wall width. Your model then represents what you want your printer to print. If you export two cubes sharing an edge who knows what the printer will do? It is much better to give an error as soon as possible to avoid creating a model that can't be printed. Yes the printer may print something but it won't match the physically impossible model. In answer to the original question. I don't find OpenSCAD limiting for creating my designs at the moment. What I would like to see is module literals to match function literals and a dict / record type. That would tidy up my code. A faster geometry engine like Carve looks like it would transform OpenSCAD as a faster union would allow 3D Minkowski to be fast and that would allow 3D rounding to be practical. On Tue, 12 Nov 2019 at 05:25, Adam Purdie <adam@symmetry.ninja> wrote: > > My suggestions: > 1. Have a way of integrating custom libraries at the openscad level, i > currently do "import(../../../project/projectfile.scad)" and it's a little > tedious, a basic library path like the Arduino app has would be cool > 2. make it so exports can retain colours (or colors if you wish) - may not > be feasible for the current export formats > 3. make the default features overrideable like in normal OO - for example > the default center value is "center=false" it would be really nice to be > able to say something like: > module square($params) { > params[center] = true; > default_square($params) > } > 4. Create some kinda scheduler for the command line that runs multiple > processes across threads - i currently do this with my own python code and > it saves me heaps of rendering time to use all 12 vcpu's :) > > On Tue, 12 Nov 2019 at 15:50, Steven Dick <kg4ydw@gmail.com> wrote: > >> Openscad is not a mesh editor. You might be able to do simple things >> like fixing round off errors during import (which is an eternal problem >> with STLs since every vertex is listed separately for every instance of >> every edge) , but fixing problems like holes and intersecting polygons is >> the job of a mesh editor like blender or meshlab. Use the right tool for >> the right job. >> >> Zero size polygons are similar to round off errors. Some holes and >> cracks are not real and are caused by the importer not recognizing two >> instances of the same edge due to round off errors, and I can see the >> importer fixing these, but a real hole or intersecting faces from a >> malformed mesh is much harder to fix. >> >> On Mon, Nov 11, 2019 at 9:38 PM Sarah Cartwright <sarah@untamed.zone> >> wrote: >> >>> >>> I'd love the "thrown together" option to display holes, and intersecting >>> polygons. >>> Very useful for STL file imports. >>> >>> Would it be possible to fix intersecting polygons, zero volume polygons >>> and holes in OpenSCAD's import? >>> It sounds difficult - but would make including existing models so much >>> easier. >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
arnholm@arnholm.org
Tue, Nov 12, 2019 8:30 AM
Carve does not have "native" support for 3D Minkowski, but I have
implemented 3D Minkowski on top of Carve, taking advantage of
multithreading for fast unions.
On 2019-11-12 08:19, nop head wrote: > A faster geometry engine like Carve looks like it would transform > OpenSCAD as a faster union would allow 3D Minkowski to be fast and > that would allow 3D rounding to be practical. Carve does not have "native" support for 3D Minkowski, but I have implemented 3D Minkowski on top of Carve, taking advantage of multithreading for fast unions. Carsten Arnholm
