Current Top Level Object Is Empty
B
BadCaseOfHerpes
Wed, Mar 30, 2016 3:13 AM
While trying to render an object with f6 It does not appear however it does
with f5. When I try to export the object as an stl i get the message Current
Top Level Object Is Empty.
I cant provide the code as it is made up of a few different imported modules
but i can show the code for the components it is made out of (its a brick
wall with 160 bricks made of slightly offset cylinders and spheres with the
hull command)
Sorry in advance if this is a simple fix I am very new to this but could not
find any similar issues on here or via google search.
so with 1 of these I am fine, with 4 aligned I am fine. When I try to use it
to build a wall that is 160 of these guys it freaks out. Is there a
possibility that using 32 import("brick1.stl") can cause an error like this?
module b1()
module element()
translate([0,0,90])sphere(r=5);
sphere(r=5);
cylinder(90,5,5);
module element2()
translate([0,0,190])sphere(r=5);
sphere(r=5);
cylinder(190,5,5);
hull()
sphere(r=5);
translate([190,0,0])sphere(r=5);
translate([190,90,0])sphere(r=5);
translate([0,90,0])sphere(r=5);
translate([190,90,90])sphere(r=5);
translate([190,0,90])sphere(r=5);
translate([0,90,90])sphere(r=5);
translate([20,93,15])rotate([90,0,0])element();
translate([20,90,30])rotate([90,0,0])element();
translate([20,86,45])rotate([90,0,0])element();
translate([20,90,60])rotate([90,0,0])element();
translate([20,89,75])rotate([90,0,0])element();
translate([40,90,15])rotate([90,0,0])element();
translate([40,88,30])rotate([90,0,0])element();
translate([40,90,45])rotate([90,0,0])element();
translate([40,95,60])rotate([90,0,0])element();
translate([40,90,75])rotate([90,0,0])element();
translate([60,95,15])rotate([90,0,0])element();
translate([60,90,30])rotate([90,0,0])element();
translate([60,90,45])rotate([90,0,0])element();
translate([60,90,60])rotate([90,0,0])element();
translate([60,92,75])rotate([90,0,0])element();
translate([80,90,15])rotate([90,0,0])element();
translate([80,95,30])rotate([90,0,0])element();
translate([80,90,45])rotate([90,0,0])element();
translate([80,90,60])rotate([90,0,0])element();
translate([80,90,75])rotate([90,0,0])element();
translate([100,90,15])rotate([90,0,0])element();
translate([100,90,30])rotate([90,0,0])element();
translate([100,92,45])rotate([90,0,0])element();
translate([100,90,60])rotate([90,0,0])element();
translate([100,92,75])rotate([90,0,0])element();
translate([120,90,15])rotate([90,0,0])element();
translate([120,87,30])rotate([90,0,0])element();
translate([120,90,45])rotate([90,0,0])element();
translate([120,92,60])rotate([90,0,0])element();
translate([120,90,75])rotate([90,0,0])element();
translate([140,90,15])rotate([90,0,0])element();
translate([140,90,30])rotate([90,0,0])element();
translate([140,86,45])rotate([90,0,0])element();
translate([140,90,60])rotate([90,0,0])element();
translate([140,85,75])rotate([90,0,0])element();
translate([160,90,15])rotate([90,0,0])element();
translate([160,88,30])rotate([90,0,0])element();
translate([160,90,45])rotate([90,0,0])element();
translate([160,90,60])rotate([90,0,0])element();
translate([160,90,75])rotate([90,0,0])element();
translate([180,85,15])rotate([90,0,0])element();
translate([180,90,30])rotate([90,0,0])element();
translate([180,87,45])rotate([90,0,0])element();
translate([180,90,60])rotate([90,0,0])element();
translate([180,90,75])rotate([90,0,0])element();
translate([10,15,0])element();
translate([10,30,-2])element();
translate([10,45,0])element();
translate([10,60,3])element();
translate([10,75,0])element();
translate([30,15,-1])element();
translate([30,30,0])element();
translate([30,45,2])element();
translate([30,60,0])element();
translate([30,75,2])element();
translate([50,15,0])element();
translate([50,30,-2])element();
translate([50,45,0])element();
translate([50,60,-2])element();
translate([50,75,0])element();
translate([70,15,-1])element();
translate([70,30,0])element();
translate([70,45,3])element();
translate([70,60,0])element();
translate([70,75,-2])element();
translate([90,15,0])element();
translate([90,30,0])element();
translate([90,45,0])element();
translate([90,60,2])element();
translate([90,75,0])element();
translate([110,15,-4])element();
translate([110,30,0])element();
translate([110,45,-1])element();
translate([110,60,0])element();
translate([110,75,-5])element();
translate([130,15,0])element();
translate([130,30,-3])element();
translate([130,45,0])element();
translate([130,60,3])element();
translate([130,75,0])element();
translate([150,15,0])element();
translate([150,30,0])element();
translate([150,45,-3])element();
translate([150,60,0])element();
translate([150,75,0])element();
translate([170,15,0])element();
translate([170,30,2])element();
translate([170,45,0])element();
translate([170,60,3])element();
translate([170,75,0])element();
translate([4,15,15])rotate([0,90,0])element2();
translate([0,30,15])rotate([0,90,0])element2();
translate([-5,45,15])rotate([0,90,0])element2();
translate([0,60,15])rotate([0,90,0])element2();
translate([1,75,15])rotate([0,90,0])element2();
translate([0,15,30])rotate([0,90,0])element2();
translate([-1,30,30])rotate([0,90,0])element2();
translate([0,45,30])rotate([0,90,0])element2();
translate([4,60,30])rotate([0,90,0])element2();
translate([0,75,30])rotate([0,90,0])element2();
translate([4,15,45])rotate([0,90,0])element2();
translate([0,30,45])rotate([0,90,0])element2();
translate([0,45,45])rotate([0,90,0])element2();
translate([0,60,45])rotate([0,90,0])element2();
translate([1,75,45])rotate([0,90,0])element2();
translate([0,15,60])rotate([0,90,0])element2();
translate([4,30,60])rotate([0,90,0])element2();
translate([0,45,60])rotate([0,90,0])element2();
translate([4,60,60])rotate([0,90,0])element2();
translate([0,75,60])rotate([0,90,0])element2();
translate([0,15,75])rotate([0,90,0])element2();
translate([0,30,75])rotate([0,90,0])element2();
translate([-1,45,75])rotate([0,90,0])element2();
translate([0,60,75])rotate([0,90,0])element2();
translate([-4,75,75])rotate([0,90,0])element2();
translate([5,5,5])b1();
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809.html
While trying to render an object with f6 It does not appear however it does with f5. When I try to export the object as an stl i get the message Current Top Level Object Is Empty. I cant provide the code as it is made up of a few different imported modules but i can show the code for the components it is made out of (its a brick wall with 160 bricks made of slightly offset cylinders and spheres with the hull command) Sorry in advance if this is a simple fix I am very new to this but could not find any similar issues on here or via google search. so with 1 of these I am fine, with 4 aligned I am fine. When I try to use it to build a wall that is 160 of these guys it freaks out. Is there a possibility that using 32 import("brick1.stl") can cause an error like this? module b1() { module element() { translate([0,0,90])sphere(r=5); sphere(r=5); cylinder(90,5,5); } module element2() { translate([0,0,190])sphere(r=5); sphere(r=5); cylinder(190,5,5); } hull() { sphere(r=5); translate([190,0,0])sphere(r=5); translate([190,90,0])sphere(r=5); translate([0,90,0])sphere(r=5); translate([190,90,90])sphere(r=5); translate([190,0,90])sphere(r=5); translate([0,0,90])sphere(r=5); translate([0,90,90])sphere(r=5); translate([20,93,15])rotate([90,0,0])element(); translate([20,90,30])rotate([90,0,0])element(); translate([20,86,45])rotate([90,0,0])element(); translate([20,90,60])rotate([90,0,0])element(); translate([20,89,75])rotate([90,0,0])element(); translate([40,90,15])rotate([90,0,0])element(); translate([40,88,30])rotate([90,0,0])element(); translate([40,90,45])rotate([90,0,0])element(); translate([40,95,60])rotate([90,0,0])element(); translate([40,90,75])rotate([90,0,0])element(); translate([60,95,15])rotate([90,0,0])element(); translate([60,90,30])rotate([90,0,0])element(); translate([60,90,45])rotate([90,0,0])element(); translate([60,90,60])rotate([90,0,0])element(); translate([60,92,75])rotate([90,0,0])element(); translate([80,90,15])rotate([90,0,0])element(); translate([80,95,30])rotate([90,0,0])element(); translate([80,90,45])rotate([90,0,0])element(); translate([80,90,60])rotate([90,0,0])element(); translate([80,90,75])rotate([90,0,0])element(); translate([100,90,15])rotate([90,0,0])element(); translate([100,90,30])rotate([90,0,0])element(); translate([100,92,45])rotate([90,0,0])element(); translate([100,90,60])rotate([90,0,0])element(); translate([100,92,75])rotate([90,0,0])element(); translate([120,90,15])rotate([90,0,0])element(); translate([120,87,30])rotate([90,0,0])element(); translate([120,90,45])rotate([90,0,0])element(); translate([120,92,60])rotate([90,0,0])element(); translate([120,90,75])rotate([90,0,0])element(); translate([140,90,15])rotate([90,0,0])element(); translate([140,90,30])rotate([90,0,0])element(); translate([140,86,45])rotate([90,0,0])element(); translate([140,90,60])rotate([90,0,0])element(); translate([140,85,75])rotate([90,0,0])element(); translate([160,90,15])rotate([90,0,0])element(); translate([160,88,30])rotate([90,0,0])element(); translate([160,90,45])rotate([90,0,0])element(); translate([160,90,60])rotate([90,0,0])element(); translate([160,90,75])rotate([90,0,0])element(); translate([180,85,15])rotate([90,0,0])element(); translate([180,90,30])rotate([90,0,0])element(); translate([180,87,45])rotate([90,0,0])element(); translate([180,90,60])rotate([90,0,0])element(); translate([180,90,75])rotate([90,0,0])element(); translate([10,15,0])element(); translate([10,30,-2])element(); translate([10,45,0])element(); translate([10,60,3])element(); translate([10,75,0])element(); translate([30,15,-1])element(); translate([30,30,0])element(); translate([30,45,2])element(); translate([30,60,0])element(); translate([30,75,2])element(); translate([50,15,0])element(); translate([50,30,-2])element(); translate([50,45,0])element(); translate([50,60,-2])element(); translate([50,75,0])element(); translate([70,15,-1])element(); translate([70,30,0])element(); translate([70,45,3])element(); translate([70,60,0])element(); translate([70,75,-2])element(); translate([90,15,0])element(); translate([90,30,0])element(); translate([90,45,0])element(); translate([90,60,2])element(); translate([90,75,0])element(); translate([110,15,-4])element(); translate([110,30,0])element(); translate([110,45,-1])element(); translate([110,60,0])element(); translate([110,75,-5])element(); translate([130,15,0])element(); translate([130,30,-3])element(); translate([130,45,0])element(); translate([130,60,3])element(); translate([130,75,0])element(); translate([150,15,0])element(); translate([150,30,0])element(); translate([150,45,-3])element(); translate([150,60,0])element(); translate([150,75,0])element(); translate([170,15,0])element(); translate([170,30,2])element(); translate([170,45,0])element(); translate([170,60,3])element(); translate([170,75,0])element(); translate([4,15,15])rotate([0,90,0])element2(); translate([0,30,15])rotate([0,90,0])element2(); translate([-5,45,15])rotate([0,90,0])element2(); translate([0,60,15])rotate([0,90,0])element2(); translate([1,75,15])rotate([0,90,0])element2(); translate([0,15,30])rotate([0,90,0])element2(); translate([-1,30,30])rotate([0,90,0])element2(); translate([0,45,30])rotate([0,90,0])element2(); translate([4,60,30])rotate([0,90,0])element2(); translate([0,75,30])rotate([0,90,0])element2(); translate([4,15,45])rotate([0,90,0])element2(); translate([0,30,45])rotate([0,90,0])element2(); translate([0,45,45])rotate([0,90,0])element2(); translate([0,60,45])rotate([0,90,0])element2(); translate([1,75,45])rotate([0,90,0])element2(); translate([0,15,60])rotate([0,90,0])element2(); translate([4,30,60])rotate([0,90,0])element2(); translate([0,45,60])rotate([0,90,0])element2(); translate([4,60,60])rotate([0,90,0])element2(); translate([0,75,60])rotate([0,90,0])element2(); translate([0,15,75])rotate([0,90,0])element2(); translate([0,30,75])rotate([0,90,0])element2(); translate([-1,45,75])rotate([0,90,0])element2(); translate([0,60,75])rotate([0,90,0])element2(); translate([-4,75,75])rotate([0,90,0])element2(); } } translate([5,5,5])b1(); -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 30, 2016 3:46 AM
Should handle 32 or 160.
Are you sure the F6 finished, "Rendering finished" in console? F6 can take
some time sometimes.
Also try exiting OpenSCAD rerunning and re F5/F6 sometime errors don't show
up a second time if the object is cached.
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16810.html
Should handle 32 or 160. Are you sure the F6 finished, "Rendering finished" in console? F6 can take some time sometimes. Also try exiting OpenSCAD rerunning and re F5/F6 sometime errors don't show up a second time if the object is cached. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16810.html Sent from the OpenSCAD mailing list archive at Nabble.com.
JL
Jean-Paul Louis
Wed, Mar 30, 2016 3:56 AM
Why do you even use cylinders?
For me the solid result looks the same with or without the cylinders.
the hull is built only using the spheres if I am not mistaken.
Just my $0.02,
Jean-Paul
N1JPL
hull command)
module b1()
module element()
sphere(r=5);
cylinder(90,5,5);
module element2()
sphere(r=5);
cylinder(190,5,5);
hull()
sphere(r=5);
Why do you even use cylinders? For me the solid result looks the same with or without the cylinders. the hull is built only using the spheres if I am not mistaken. Just my $0.02, Jean-Paul N1JPL > On Mar 29, 2016, at 11:13 PM, BadCaseOfHerpes <tylermeroth@gmail.com> wrote: > > While trying to render an object with f6 It does not appear however it does > with f5. When I try to export the object as an stl i get the message Current > Top Level Object Is Empty. > > I cant provide the code as it is made up of a few different imported modules > but i can show the code for the components it is made out of (its a brick > wall with 160 bricks made of slightly offset cylinders and spheres with the > hull command) > > Sorry in advance if this is a simple fix I am very new to this but could not > find any similar issues on here or via google search. > so with 1 of these I am fine, with 4 aligned I am fine. When I try to use it > to build a wall that is 160 of these guys it freaks out. Is there a > possibility that using 32 import("brick1.stl") can cause an error like this? > > module b1() > { > module element() > { > translate([0,0,90])sphere(r=5); > sphere(r=5); > cylinder(90,5,5); > } > module element2() > { > translate([0,0,190])sphere(r=5); > sphere(r=5); > cylinder(190,5,5); > } > hull() > { > sphere(r=5); > translate([190,0,0])sphere(r=5); > translate([190,90,0])sphere(r=5); > translate([0,90,0])sphere(r=5); > translate([190,90,90])sphere(r=5); > translate([190,0,90])sphere(r=5); > translate([0,0,90])sphere(r=5); > translate([0,90,90])sphere(r=5); > translate([20,93,15])rotate([90,0,0])element(); > translate([20,90,30])rotate([90,0,0])element(); > translate([20,86,45])rotate([90,0,0])element(); > translate([20,90,60])rotate([90,0,0])element(); > translate([20,89,75])rotate([90,0,0])element(); > translate([40,90,15])rotate([90,0,0])element(); > translate([40,88,30])rotate([90,0,0])element(); > translate([40,90,45])rotate([90,0,0])element(); > translate([40,95,60])rotate([90,0,0])element(); > translate([40,90,75])rotate([90,0,0])element(); > translate([60,95,15])rotate([90,0,0])element(); > translate([60,90,30])rotate([90,0,0])element(); > translate([60,90,45])rotate([90,0,0])element(); > translate([60,90,60])rotate([90,0,0])element(); > translate([60,92,75])rotate([90,0,0])element(); > translate([80,90,15])rotate([90,0,0])element(); > translate([80,95,30])rotate([90,0,0])element(); > translate([80,90,45])rotate([90,0,0])element(); > translate([80,90,60])rotate([90,0,0])element(); > translate([80,90,75])rotate([90,0,0])element(); > translate([100,90,15])rotate([90,0,0])element(); > translate([100,90,30])rotate([90,0,0])element(); > translate([100,92,45])rotate([90,0,0])element(); > translate([100,90,60])rotate([90,0,0])element(); > translate([100,92,75])rotate([90,0,0])element(); > translate([120,90,15])rotate([90,0,0])element(); > translate([120,87,30])rotate([90,0,0])element(); > translate([120,90,45])rotate([90,0,0])element(); > translate([120,92,60])rotate([90,0,0])element(); > translate([120,90,75])rotate([90,0,0])element(); > translate([140,90,15])rotate([90,0,0])element(); > translate([140,90,30])rotate([90,0,0])element(); > translate([140,86,45])rotate([90,0,0])element(); > translate([140,90,60])rotate([90,0,0])element(); > translate([140,85,75])rotate([90,0,0])element(); > translate([160,90,15])rotate([90,0,0])element(); > translate([160,88,30])rotate([90,0,0])element(); > translate([160,90,45])rotate([90,0,0])element(); > translate([160,90,60])rotate([90,0,0])element(); > translate([160,90,75])rotate([90,0,0])element(); > translate([180,85,15])rotate([90,0,0])element(); > translate([180,90,30])rotate([90,0,0])element(); > translate([180,87,45])rotate([90,0,0])element(); > translate([180,90,60])rotate([90,0,0])element(); > translate([180,90,75])rotate([90,0,0])element(); > translate([10,15,0])element(); > translate([10,30,-2])element(); > translate([10,45,0])element(); > translate([10,60,3])element(); > translate([10,75,0])element(); > translate([30,15,-1])element(); > translate([30,30,0])element(); > translate([30,45,2])element(); > translate([30,60,0])element(); > translate([30,75,2])element(); > translate([50,15,0])element(); > translate([50,30,-2])element(); > translate([50,45,0])element(); > translate([50,60,-2])element(); > translate([50,75,0])element(); > translate([70,15,-1])element(); > translate([70,30,0])element(); > translate([70,45,3])element(); > translate([70,60,0])element(); > translate([70,75,-2])element(); > translate([90,15,0])element(); > translate([90,30,0])element(); > translate([90,45,0])element(); > translate([90,60,2])element(); > translate([90,75,0])element(); > translate([110,15,-4])element(); > translate([110,30,0])element(); > translate([110,45,-1])element(); > translate([110,60,0])element(); > translate([110,75,-5])element(); > translate([130,15,0])element(); > translate([130,30,-3])element(); > translate([130,45,0])element(); > translate([130,60,3])element(); > translate([130,75,0])element(); > translate([150,15,0])element(); > translate([150,30,0])element(); > translate([150,45,-3])element(); > translate([150,60,0])element(); > translate([150,75,0])element(); > translate([170,15,0])element(); > translate([170,30,2])element(); > translate([170,45,0])element(); > translate([170,60,3])element(); > translate([170,75,0])element(); > translate([4,15,15])rotate([0,90,0])element2(); > translate([0,30,15])rotate([0,90,0])element2(); > translate([-5,45,15])rotate([0,90,0])element2(); > translate([0,60,15])rotate([0,90,0])element2(); > translate([1,75,15])rotate([0,90,0])element2(); > translate([0,15,30])rotate([0,90,0])element2(); > translate([-1,30,30])rotate([0,90,0])element2(); > translate([0,45,30])rotate([0,90,0])element2(); > translate([4,60,30])rotate([0,90,0])element2(); > translate([0,75,30])rotate([0,90,0])element2(); > translate([4,15,45])rotate([0,90,0])element2(); > translate([0,30,45])rotate([0,90,0])element2(); > translate([0,45,45])rotate([0,90,0])element2(); > translate([0,60,45])rotate([0,90,0])element2(); > translate([1,75,45])rotate([0,90,0])element2(); > translate([0,15,60])rotate([0,90,0])element2(); > translate([4,30,60])rotate([0,90,0])element2(); > translate([0,45,60])rotate([0,90,0])element2(); > translate([4,60,60])rotate([0,90,0])element2(); > translate([0,75,60])rotate([0,90,0])element2(); > translate([0,15,75])rotate([0,90,0])element2(); > translate([0,30,75])rotate([0,90,0])element2(); > translate([-1,45,75])rotate([0,90,0])element2(); > translate([0,60,75])rotate([0,90,0])element2(); > translate([-4,75,75])rotate([0,90,0])element2(); > } > } > translate([5,5,5])b1(); > > > > -- > View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
B
BadCaseOfHerpes
Wed, Mar 30, 2016 12:26 PM
yes I am sure it has finished rendering, i have also restarted OpenSCAD and
my desktop to no avail.
Sometimes it also pops up with an error, but not always which I find strange
and I just got it to pop up again "ERROR: CGAL error in
CGALUtils::applyBinaryOperator union: CGAL ERROR: assertion violation! Expr:
itl != it->second.end() File:
/opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102"
The reason I use cylinders with spheres on the ends is to manipulate two
sides of the rectangular prism with one translate command.
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16816.html
yes I am sure it has finished rendering, i have also restarted OpenSCAD and my desktop to no avail. Sometimes it also pops up with an error, but not always which I find strange and I just got it to pop up again "ERROR: CGAL error in CGALUtils::applyBinaryOperator union: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: /opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_external_structure.h Line: 1102" The reason I use cylinders with spheres on the ends is to manipulate two sides of the rectangular prism with one translate command. -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16816.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Wed, Mar 30, 2016 1:52 PM
does with f5.
Tried your code on my pc. It took about 20 sec for preview(F5), and
instantly for render(F6). Both show up fine.
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 );  $ tips: hash( 1 , 2 ), matrix( 1 , 2 ),sweep( 1 , 2 ), var( 1 , 2 ), lerp , animation ( gif , prodVid ), precision( 1 , 2 ), xl-control , type , rounded polygon , chfont
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16817.html
BadCaseOfHerpes wrote > While trying to render an object with f6 It does not appear however it > does with f5. Tried your code on my pc. It took about 20 sec for preview(F5), and instantly for render(F6). Both show up fine. ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), matrix( 1 , 2 ),sweep( 1 , 2 ), var( 1 , 2 ), lerp , animation ( gif , prodVid ), precision( 1 , 2 ), xl-control , type , rounded polygon , chfont -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16817.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
BadCaseOfHerpes
Wed, Mar 30, 2016 3:29 PM
Runsun the issue isn't that particular object it is when I have 160 of them
stacked to form a brick wall. I have a feeling it has to do with too many
stl imports not liking each other I will rewrite the wall tonight with no
imports and see if this issue persists.
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16821.html
Runsun the issue isn't that particular object it is when I have 160 of them stacked to form a brick wall. I have a feeling it has to do with too many stl imports not liking each other I will rewrite the wall tonight with no imports and see if this issue persists. -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16821.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Wed, Mar 30, 2016 3:46 PM
i c. I like the idea of brick wall. In fact it comes up in my mind once in a
while couple of times.
If I do it, I would most likely just work on the wall surface (and the edge
surface), but not construct the bricks one by one. After all, once the wall
is done, all the inner surfaces are hidden. So making it one by one is like
asking OpenSCAD to work on details you don't need.
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16822.html
i c. I like the idea of brick wall. In fact it comes up in my mind once in a while couple of times. If I do it, I would most likely just work on the wall surface (and the edge surface), but not construct the bricks one by one. After all, once the wall is done, all the inner surfaces are hidden. So making it one by one is like asking OpenSCAD to work on details you don't need. ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), matrix( 1 , 2 ),sweep( 1 , 2 ), var( 1 , 2 ), lerp , animation ( gif , prodVid ), precision( 1 , 2 ), xl-control , type , rounded polygon , chfont -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16822.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Importing STLs is a bit fragile and can sometimes result in such issues.
Since your bricks are made in OpenSCAD, try without exporting to STL and re-importing. That should improve things.
> On Mar 29, 2016, at 23:13 PM, BadCaseOfHerpes <tylermeroth@gmail.com> wrote: > When I try to use it > to build a wall that is 160 of these guys it freaks out. Is there a > possibility that using 32 import("brick1.stl") can cause an error like this? > Importing STLs is a bit fragile and can sometimes result in such issues. Since your bricks are made in OpenSCAD, try without exporting to STL and re-importing. That should improve things. -Marius
Wed, Mar 30, 2016 5:10 PM
h = 100;
cols = 20;
rows = 20;
for (x=[0:rows-1], y=[0:cols-1])
dx = y%2?0:b/2;
translate([5+dx+xb,5, 5+yh])
b1();
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16824.html
Which version are you running? <http://forum.openscad.org/file/n16824/Unbenannt.png> > h = 100; > cols = 20; > rows = 20; > for (x=[0:rows-1], y=[0:cols-1]) > { > dx = y%2?0:b/2; > translate([5+dx+x*b,5, 5+y*h]) > b1(); > } -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16824.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Ronaldo
Wed, Mar 30, 2016 8:28 PM
You don't have to import each instance of the block as they are all equal.
module block() { import("block.stl"); }
// use how may instance you of the block()
View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16829.html
You don't have to import each instance of the block as they are all equal. module block() { import("block.stl"); } // use how may instance you of the block() -- View this message in context: http://forum.openscad.org/Current-Top-Level-Object-Is-Empty-tp16809p16829.html Sent from the OpenSCAD mailing list archive at Nabble.com.
