I can get this to work with F5, but not with F6: it just hangs for
hours, running full CPU. Any thoughts?
rch = 0.1;
ballDiam = 25.4 * 1/4 + rch;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
for (d = [0:1:720]) {
hull(){
rotate([0, 0, d])
translate([hubR + d * myScale, 0, 0])
sphere(d = ballDiam);
rotate([0, 0, d])
translate([hubR + (d+1) * myScale, 0, 0])
translate([0, 0, -ballDiam * 0.7])
cylinder(h=ballDiam, r=28);
spiral();
$fn = 50;
for (d = [0:1:720]) hull()
I think it will just take a very long time or consume all of the memory
because CGAL hates the massive implicit union of objects with lots of
vertices. It simply doesn't scale to high detail models. If you can
construct it with functions that generate lists to feed into polyhedron it
will be much faster.
See the work kitwallace did with knots. A spiral is not too different.
On 14 June 2015 at 01:35, jon jon@jonbondy.com wrote:
I can get this to work with F5, but not with F6: it just hangs for hours,
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
I've been programming for over 40 years. Most of OpenSCAD is
more-or-less intuitive to me. But "functions that generate lists to
feed into polyhedron" leaves me dazed. Just like list comprehensions:
wonderful magic, but magic just the same.
Thanks
On 6/13/2015 8:55 PM, nop head wrote:
$fn = 50;
memory because CGAL hates the massive implicit union of objects with
lots of vertices. It simply doesn't scale to high detail models. If
you can construct it with functions that generate lists to feed into
polyhedron it will be much faster.
On 14 June 2015 at 01:35, jon <jon@jonbondy.com
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
Checked by AVG - www.avg.com http://www.avg.com
Version: 2015.0.6030 / Virus Database: 4360/10009 - Release Date: 06/13/15
On Sat, Jun 13, 2015 at 09:04:13PM -0400, jon wrote:
I've been programming for over 40 years. Most of OpenSCAD is more-or-less
intuitive to me. But "functions that generate lists to feed into
polyhedron" leaves me dazed. Just like list comprehensions: wonderful
List comprehensions aren't a new thing though:
https://en.wikipedia.org/wiki/List_comprehension
Kind regards,
Loong Jin
I found and modified kit wallace's knot code (which is based on some of
your code). Once I understood that the function at the top controlled
the entire object, it was indeed simple. That is, the two of you made
it simple for me! Not sure how to eliminate the requirement that the
tube be closed, though.
$fn = 50;
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
rch = 0.1;
myScale = 1/40;
hubR = 5;
function f(a,b,t) = // spiral
[ (a + t * b) * cos(t),
(a + t * b) * sin(t),
0
$fn = 50;
function m_translate(v) = [ [1, 0, 0, 0],
[0, 1, 0, 0],
[0, 0, 1, 0],
[v.x, v.y, v.z, 1 ] ];
function m_rotate(v) = [ [1, 0, 0, 0],
[0, cos(v.x), sin(v.x), 0],
[0, -sin(v.x), cos(v.x), 0],
[0, 0, 0, 1] ]
* [ [ cos(v.y), 0, -sin(v.y), 0],
[0, 1, 0, 0],
[ sin(v.y), 0, cos(v.y), 0],
[0, 0, 0, 1] ]
* [ [ cos(v.z), sin(v.z), 0, 0],
[-sin(v.z), cos(v.z), 0, 0],
[ 0, 0, 1, 0],
[ 0, 0, 0, 1] ];
function vec3(v) = [v.x, v.y, v.z];
function transform(v, m) = vec3([v.x, v.y, v.z, 1] * m);
function orientate(position, normal) = m_rotate([0,
atan2(sqrt(pow(normal[0], 2) + pow(normal[1], 2)), normal[2]), 0])
* m_rotate([0, 0, atan2(normal[1], normal[0])])
* m_translate(position);
function circle_points(r = 1, a = 0) = a < 360 ? concat([[r * sin(a), r *
cos(a), 0]], circle_points(r, a + 360 / $fn)) : [] ;
function path_points(a, b, step, t = 0) = t <= 720 ? concat([f(a,b,t)],
path_points(a, b, step, t + step)) : [] ;
function transform_points(list, matrix, i = 0) = i < len(list) ? concat([
transform(list[i], matrix) ], transform_points(list, matrix, i + 1)) : [];
function tube_points(profile, path, i = 0) = i < len(path) - 1
? concat(transform_points(profile,
orientate(path[i], (path[i + 1] - path[i])/ 2)), tube_points(profile, path,
i + 1))
: transform_points(profile,
orientate(path[i], (path[i] - path[i - 1])/ 2)) ;
function tube_faces(segs, facets, s, i = 0) = i < facets ? concat([[s *
facets + i,
s *
facets + (i + 1) % facets,
((s +
tube_faces(segs, facets, s, i + 1)) : [];
function path_faces(segs, facets, i = 0) = i < segs - 1 ?
concat(tube_faces(segs, facets, i), path_faces(segs, facets, i + 1)) : [];
function cap(facets, segment = 0, i = 0) = i < facets ? concat(i + facets *
segment, cap(facets, segment, i + 1)) : [];
circle_points = circle_points(ballDiam / 2);
facets = len(circle_points);
path_points = path_points(hubR, myScale, 1);
segments = len(path_points);
tube_points = tube_points(circle_points, path_points);
path_faces = path_faces(segments, facets);
translate(path_points[0])
sphere(ballDiam / 2);
polyhedron(points = tube_points, faces = concat([cap(facets)],
path_faces, [cap(facets, segments - 1)]));
translate(path_points[segments - 1])
your code). Once I understood that the function at the top controlled the
entire object, it was indeed simple. That is, the two of you made it
simple for me! Not sure how to eliminate the requirement that the tube be
closed, though.
$fn = 50;
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
Thank you very much. You are very generous with your time.
On 6/14/2015 8:31 AM, nop head wrote:
rch = 0.1;
myScale = 1/40;
hubR = 5;
0
$fn = 50;
[0, 1, 0, 0],
[0, 0, 1, 0],
[0, 0, 0, 1] ]
[0, 1, 0, 0],
[0, 0, 0, 1] ]
[ 0, 0, 1, 0],
[ 0, 0, 0, 1] ];
r * cos(a), 0]], circle_points(r, a + 360 / $fn)) : [] ;
concat([f(a,b,t)], path_points(a, b, step, t + step)) : [] ;
concat([ transform(list[i], matrix) ], transform_points(list, matrix,
i + 1)) : [];
path, i + 1))
facets * segment, cap(facets, segment, i + 1)) : [];
On 14 June 2015 at 12:41, jon <jon@jonbondy.com
some of your code). Once I understood that the function at the
top controlled the entire object, it was indeed simple. That is,
the two of you made it simple for me! Not sure how to eliminate
the requirement that the tube be closed, though.
$fn = 50;
with lots of vertices. It simply doesn't scale to high detail
models. If you can construct it with functions that generate
lists to feed into polyhedron it will be much faster.
different.
hangs for hours, running full CPU. Any thoughts?
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
Checked by AVG - www.avg.com <http://www.avg.com>
06/13/15
Version: 2015.0.6030 / Virus Database: 4360/10012 - Release Date: 06/14/15
Unfortunately F6 fails on my system but it works in 2 minutes if I remove
the spheres at the end points.
Looks like a bug in OpenScad triggered by unioning nearly coincident faces.
rch = 0.1;
myScale = 1/40;
hubR = 5;
0
$fn = 50;
[0, 1, 0, 0],
[0, 0, 1, 0],
[0, 0, 0, 1] ]
[0, 1, 0, 0],
[0, 0, 0, 1] ]
[ 0, 0, 1, 0],
[ 0, 0, 0, 1] ];
i + 1))
facets + i,
s *
((s +
closed, though.
$fn = 50;
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
PolySet has nonplanar faces. Attempting alternate construction
ERROR: Alternate construction failed. CGAL error in CGAL_Nef_polyhedron3():
CGAL ERROR: assertion violation! Expr: e->incident_sface() !=
SFace_const_handle() File:
/data/OpenSCAD/libraries-mingw32-master/mxe/usr/i686-w64-mingw32.static/include/CGAL/Nef_S2/SM_const_decorator.h
Line: 326
rch = 0.1;
myScale = 1/40;
hubR = 5;
0
$fn = 50;
[0, 1, 0, 0],
[0, 0, 1, 0],
[0, 0, 0, 1] ]
[0, 1, 0, 0],
[0, 0, 0, 1] ]
[ 0, 0, 1, 0],
[ 0, 0, 0, 1] ];
i + 1))
facets + i,
s *
((s +
closed, though.
$fn = 50;
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
06/13/15
Actually it was caused by the winding order of one of the end caps being
wrong. This fixes it: -
function cap(facets, segment = 0, i = 0) = i < facets ? concat(segment ?
facets * segment + i : facets - 1 - i, cap(facets, segment, i + 1)) : [];
Also the sphere facets can be aligned with the tube by adding a rotation:
rotate([0, 180 / $fn, 0]) sphere(ballDiam / 2);
CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr:
e->incident_sface() != SFace_const_handle() File:
Line: 326
faces.
rch = 0.1;
myScale = 1/40;
hubR = 5;
0
$fn = 50;
[0, 1, 0, 0],
[0, 0, 1, 0],
[0, 0, 0, 1] ]
[0, 1, 0, 0],
[0, 0, 0, 1] ]
[ 0, 0, 1, 0],
[ 0, 0, 0, 1] ];
concat([ transform(list[i], matrix) ], transform_points(list, matrix, i +
1)) : [];
i + 1))
facets + i,
s *
((s
of your code). Once I understood that the function at the top controlled
the entire object, it was indeed simple. That is, the two of you made it
closed, though.
$fn = 50;
memory because CGAL hates the massive implicit union of objects with lots
of vertices. It simply doesn't scale to high detail models. If you can
rch = 0.1;
$fn = 50;
module spiral() {
myScale = 1/40;
hubR = 5;
hull(){
rotate([0, 0, d])
rotate([0, 0, d])
spiral();
06/13/15
06/14/15
