Hello ! I am not able to unsubscribe from the mailing list. When I hit
unsubscribe I receive an email with random info with no actual button to
unsubscribe.
There is no setting to unsubscribe.
The software is awesome. The forum is very badly designed.
The results of your email command are provided below. Attached is your
original message. - Results: You did not give the correct password Not
authenticated Usage: set help Show this detailed help. set show
[address=<address>] View your current option settings. If you're posting
from an address other than your membership address, specify your membership
address with address=<address>' (no brackets around the email address, and no quotes!). set authenticate <password> [address=<address>] To set any of your options, you must include this command first, along with your membership password. If you're posting from an address other than your membership address, specify your membership address with address=<address>'
(no brackets around the email address, and no quotes!). set ack on set ack
off When the ack' option is turned on, you will receive an acknowledgement message whenever you post a message to the list. set digest plain set digest mime set digest off When the digest' option is turned off, you will receive
postings immediately when they are posted. Use set digest plain' if instead you want to receive postings bundled into a plain text digest (i.e. RFC 1153 digest). Use set digest mime' if instead you want to receive postings
bundled together into a MIME digest. set delivery on set delivery off Turn
delivery on or off. This does not unsubscribe you, but instead tells Mailman
not to deliver messages to you for now. This is useful if you're going on
vacation. Be sure to use set delivery on' when you return from vacation! set myposts on set myposts off Use set myposts off' to not receive copies
of messages you post to the list. This has no effect if you're receiving
digests. set hide on set hide off Use set hide on' to conceal your email address when people request the membership list. set duplicates on set duplicates off Use set duplicates off' if you want Mailman to not send you
messages if your address is explicitly mentioned in the To: or Cc: fields of
the message. This can reduce the number of duplicate postings you will
receive. set reminders on set reminders off Use set reminders off' if you want to disable the monthly password reminder for this mailing list. Not authenticated Usage: set help Show this detailed help. set show [address=<address>] View your current option settings. If you're posting from an address other than your membership address, specify your membership address with address=<address>' (no brackets around the email address, and
membership address, specify your membership address with address=<address>' (no brackets around the email address, and no quotes!). set ack on set ack off When the ack' option is turned on, you will receive an acknowledgement
mime set digest off When the digest' option is turned off, you will receive postings immediately when they are posted. Use set digest plain' if instead
digest). Use set digest mime' if instead you want to receive postings bundled together into a MIME digest. set delivery on set delivery off Turn delivery on or off. This does not unsubscribe you, but instead tells Mailman not to deliver messages to you for now. This is useful if you're going on vacation. Be sure to use set delivery on' when you return from vacation!
set myposts on set myposts off Use set myposts off' to not receive copies of messages you post to the list. This has no effect if you're receiving digests. set hide on set hide off Use set hide on' to conceal your email
duplicates off Use set duplicates off' if you want Mailman to not send you messages if your address is explicitly mentioned in the To: or Cc: fields of the message. This can reduce the number of duplicate postings you will receive. set reminders on set reminders off Use set reminders off' if you
receive. set reminders on set reminders off Use `set reminders off' if you
want to disable the monthly password reminder for this mailing list. -
Done.
