So, I have three orthogonal vectors and I wish to set my viewport to the 'top
view' of these vectors. How would I go about doing that? I'm thinking that
I would have to modify the $vpr variable, but how?
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289.html
You just set the $vpt, $vpr and $vpd values in your OpenSCAD script, usually
at the beginning, or at the top-level (ie not in any module), of the main
file, eg:
$vpt = [ 0,0,0 ];
$vpr = [ 60,0,30 ];
$vpd = 500;
When you press F5, it will draw the scene from this viewpoint. For more
information, see
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Other_Language_Features#.24vpr.2C_.24vpt_and_.24vpd
When you come to animate your model, you can use $t ("time", is a value
between 0 and 1, see
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Other_Language_Features#.24t
) to move the viewport around your object, eg:
$vpt = [ 0, 0, 0 ];
$vpr = [ 90-$t30, 0.00, 30+$t720 ];
$vpd = 500;
Open the "animate" dialogue, set Time to 0, Steps to 720 and FPS to a number
greater than 0 (depends on model complexity, and how quick your PC is at to
how many FPS you can get). This should move the viewport around the object
in a spiral motion, going up, but keep the focus on the origin.
Ian
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20292.html
Ok. Let's get a more generic example.
I have axis, represented by vectors A, B and C. I want to view that location
as if it were the origin from the top view. How would I do that?
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20293.html
$vpt sets the viewport translation, $vpr sets the rotation ( [0,0,0] sets the
view from above), $vpd sets the distance. So...
$vpt = [ A,B,C ];
$vpr = [ 0,0,0 ];
You may need to set a distance, too. The current viewport vectors are shown
in the bottom left of the OpenSCAD window, usually.
Ian
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20294.html
I don't understand. A, B and C are 3D vectors. $vpt is a triple of numbers.
If A = [1,0,0], B = [0,1,0] and C = [0,0,1], then what you stated was $vpt =
[[1,0,0], [0,1,0], [0,0,1]]; which is a triple of triples. That doesn't
make sense.
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20295.html
Adrian,
You are right. Euler angles really sucks. It is the worst system to
represent rotations.
The rotation of $vpr should be defined by a vector of 3 Euler angles: the
rotation angles about each of the original coordinate system to be applied
to the viewport. Just like rotate(...) for children. The question, the
answer to your question, is how to find this Euler angles given an
orthogonal system for the viewport?
To solve this problem we have to solve a trigonometric system of equations.
Worst than that, there is many interpretation for the Euler angles. Even
worst, depending on the coordinate system, the system of equations has
infinite solutions!
The following code includes a function, RM2EAxyz, that solves the problem
above by converting a rotation matrix into a vector of the three Euler
angles where the rotations are supposed to be applied in the order RxRyRz.
That is what you need.
ax = unit(rands(-1,1,3));
ay = unit(cross(ax,rands(-1,1,3)));
az = unit(cross(ax,ay));
M = [ax, ay, az];
echo(M);
angs = RM2EAxyz(M);
$vpt = [0,0,0];
$vpr = angs;
color("red") show_vector(ax);
color("green") show_vector(ay);
color("blue") show_vector(az,t=3);
// converts a rotation matrix into the Euler angles
// with the order Rx.Ry.Rz
function RM2EAxyz(M) =
let( ang1 = 1-abs(M[0][2])<1e-12 ?
0 :
atan2(M[1][2],M[2][2]),
ang2 = 1-abs(M[0][2])<1e-12 ?
-90*sign(M[0][2]) :
-asin(M[0][2]),
ang3 = 1-abs(M[0][2])<1e-12 ?
atan2(M[2][0],M[1][0])-90 :
atan2(M[0][1],M[0][0]) )
[ang1, ang2, ang3];
// draw a cylinder with the direction of vector v
module show_vector(v,t=1) {
length = norm([v.x,v.y,v.z]); // radial distance
b = acos(v.z/length); // inclination angle
c = atan2(v.y,v.x); // azimuthal angle
rotate([0, b, c])
cylinder(h=length, r=0.01*t);
function unit(v) = norm(v)>0 ? v/norm(v) : undef;
This code is an illustration of how to solve your problem and a test of the
function RM2EAxyz. The first 3 lines generates an orthonormal reference
system: the vectors ax, ay, az, besides being orthogonal, have unitary norm.
With them we form a rotation matrix M and convert M to the Euler angle form
with RM2EAxyz. Those Euler angles are assigned to $vpr. The following 3
lines draw the viewport axis with different colors.
If you animate this code, you will see the original coordinate system (the
system axis) rotating madly about the origin and the 3 drawn vectors
completely motionless: red to the right, green to above and blue projected
on the origin.
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20296.html
Thanks Ronaldo, that's cool. I'm going to have to look into this further.
Thanks again! :)
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20298.html
I have found two other methods to compute the Euler angles from a rotation
matrix:
// a version found in
// https://www.learnopencv.com/rotation-matrix-to-euler-angles/
function RM2EAxyz2(M) =
let( sy = norm([M[0][0],M[0][1]]) )
sy > 1e-6 ?
[ atan2(M[1][2],M[2][2]),
atan2(-M[0][2],sy),
atan2(M[0][1],M[0][0]) ] :
[ atan2(-M[2][1], M[1][1]),
atan2(-M[0][2],sy),
0 ];
// https://www.geometrictools.com/Documentation/EulerAngles.pdf
function RM2EAxyz3(M) =
M[0][2] < 1 ?
-asin(M[0][2]),
// Not a unique solution :
// ang3 +- ang1 = atan2(M[1][0], M[1][1])
[ -atan2(M[1][0], M[1][1]),
-90,
0 ] * sign(M[0][2]);
I have superficially checked them.
Ronaldo said: "Euler angles really sucks. It is the worst system to
represent rotations."
Haha, that's a pretty strong statement. I am considering to use quaternions
to represent 3D rotations in my new geometry engine. The upside is no
gimbal lock, normalization, and the slerp function, which are real
benefits. The downside is that the 4 numbers stored in a quaternion are
incomprehensible to ordinary humans, so you need to use library functions
to manipulate quaternions. Euler angles are at least easier to understand.
It seems you can convert between quaternions and euler angles using matrix
multiplication.
https://en.wikipedia.org/wiki/Conversion_between_quaternions_and_Euler_angles
An OpenSCAD quaternion library might be worthwhile.
On 2 February 2017 at 00:20, Ronaldo rcmpersiano@gmail.com wrote:
Adrian,
infinite solutions!
RxRyRz.
M = [ax, ay, az];
echo(M);
angs = RM2EAxyz(M);
$vpt = [0,0,0];
$vpr = angs;
0 :
-90*sign(M[0][2]) :
-asin(M[0][2]),
[ang1, ang2, ang3];
rotate([0, b, c])
norm.
on the origin.
Thanks for that. Now that I know what to look for, I've found the wiki that
states matrices that do the same thing:
https://en.wikipedia.org/wiki/Euler_angles#Rotation_matrix
View this message in context: http://forum.openscad.org/How-to-translate-3-vector-axis-to-a-camera-viewpoint-tp20289p20301.html
