Code:
Usage example:
cylinder (h = 4, r=1, center = true, $fn=100);
rotate ([90,0,0]) cylinder (h = 4, r=0.9, center = true, $fn=100);
Source:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#boolean_overview
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15555.html
ahh yes because shapeways charges you for the volume of the object, you need
a hole to let it get out. Its made of powder. However the inside of your
object also needs to be hollow.
Its not right now.... OOps.
In fact the entire linear_extrude in twosides() with its twist trick is to
make a solid. You want a thin outer sheet instead
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15558.html
Make it hollow and difference() the text to be the holes.
Make the text a bit larger and use a Bold font.
Although the Shapeways change to introduce 'machine space' will probably
keep the cost high.
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15559.html
so twosides needs to be rebuilt with cylinder slabs:
module twosides(r=1, i=1) {
h = r2.618;
translate([0,0,h/2])
rotate([0,0,36])
cylinder(h=1, r=r1.01, $fn=5, center=true);
rotate([0,180,0])
rotate([0,0,36])
cylinder(h=1, r=r*1.01, $fn=5, center=true);
to drill a hole.
You need to put this in dodekaeder() and union the twosides() together
before subtracting a "hole".
giving this:
strings = [["A", "Partridge", "in a","Pear Tree"], ["2"," Turtle", "Doves"],
["3","French", "Hens"], ["4","Calling", "Birds"],
["5","Golden", "Rings"], ["6","Geese", "a-laying"],
["12","Drummers", "Drumming"],["7","Swans", "a-swimming"],
["8","Maids", "a-milking"], ["9","Ladies","Dancing"],
["10","Lords", "a-leaping"],["11","Pipers","Piping"]
t_size = 7;
t_spacing = 1.9;
t_height = 1.9;
myfont = "Verdana:style=Bold";
Delta = 0.1;
dodekaeder(40);
module dodekaeder(r = 40)
w = acos(1/sqrt(5));
rotate([0, 0, 180])
twosides(r, 0);
for(i=[0:4])
rotate([0, -w, i72]) // tricky!
twosides(r, i+1);
// hole
translate ([r0.7,r0.5,-r1.3])
cylinder (h = 3, r=r/20, center = true, $fn=8);
h = r2.618;
rotate([0,0,36])
rotate([0,180,0])
rotate([0,0,36])
// text for upper and lower surface
translate([0, 0, h/2-Delta])
multilinetext(strings[i]);
rotate([0, 180, 0])
multilinetext(strings[i+6]);
// module twosides(r=1, i=1) // solid
// h = r*2.618;
// linear_extrude(height = h, center = true, twist = 36) // tricky twist
// circle(r, $fn=5);
// // text for upper and lower surface
// translate([0, 0, h/2-Delta])
// multilinetext(strings[i]);
// rotate([0, 180, 0])
// multilinetext(strings[i+6]);
module multilinetext(t, spacing=t_spacing)
for(i=[0:len(t)-1])
translate([0, (len(t)/2-i)t_sizespacing, 0]) //Note the "1.5" = Line
Spacing
linear_extrude(height = t_height)
text(t[i],halign = "center", valign = "center",
size=t_size,font=myfont);
I'm interested to know how much it costs now. $400 was super expensive.
http://forum.openscad.org/file/n15560/dodec_02_hollow_001307.png
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15560.html
Hi unkerjay,
maybe you should have a look into low polygon count fonts.
I have an extrem low polygon count on thingiverse:
http://www.thingiverse.com/thing:79905
I designed it to have a minimal number of polygons. Now, I know it is not
the most readable font.
Have fun,
TakeItAndRun
2016-01-08 4:45 GMT+01:00 Neon22 mschafer@wireframe.biz:
h = r2.618;
rotate([0,0,36])
rotate([0,180,0])
rotate([0,0,36])
to drill a hole.
giving this:
"Doves"],
"a-swimming"],
t_size = 7;
t_spacing = 1.9;
t_height = 1.9;
Delta = 0.1;
dodekaeder(40);
rotate([0, 0, 180])
twosides(r, 0);
for(i=[0:4])
twosides(r, i+1);
// hole
h = r2.618;
rotate([0,0,36])
rotate([0,180,0])
rotate([0,0,36])
rotate([0, 180, 0])
// h = r*2.618;
for(i=[0:len(t)-1])
Spacing
Thanx.
Here's what I'm doing so far.
Let's see how it works.
Applying your code, complete with hole.
Reducing the size of the font and the
dodec in Openscad. If it's going to
print at all, it might as well print at
half the size and hopefully half (-)
the cost.
And I've switched the font to one of
the boldest fonts I've found:
Revolution (Free Font):
http://www.dafont.com/revolution-saji.font
Downside, it doesn't have numbers or
hyphens. But, that just translates
ALL the text to TEXT. So, better in
that regard as well.
Now, let's see just how much difference
all these changes make.
Stay tuned.
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15565.html
yay.
I mean YAYYYY!
http://forum.openscad.org/file/n15567/YAY_WE_did_it_part1_PNG.png
and after a LITTLE repairing (for... "Wall Thickness")
http://forum.openscad.org/file/n15567/YAY_WE_did_it_part2_PNG.png
SIGNIFICANT reduction in size AND cost.
Stick a fork in it.
It's DONE.
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15567.html
congrats. to get rid of that edge seam at the boundary of the faces - try
adjusting the 1.01 in the two lines that look like this:
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15573.html
Because you had to do "Wall thickness" fix this means the text is right at
the boundary of looking OK or not.
IMHO - you could try to make it a little bigger to improve this.
also fork now in it. (http://www.thingiverse.com/thing:226875)
http://forum.openscad.org/file/n15574/forkinit_001308.png
View this message in context: http://forum.openscad.org/Text-on-a-dodecahedron-tp15409p15574.html
