Re: [OpenSCAD] Rotation question
MV
Maurice van Peursem
Mon, Dec 17, 2018 12:37 AM
I've been looking for an answer to this question for quite some time,
but in the end it turned out easier than I thought. I've defined 3
points (P1, P2 and P3) in space that I want to lay flat (i.e.
parallel to the X - Y plane). Firstly, I translate P1 to the origin
so I get what I described in the question, then I take the
cross-product of the two other (translated) points, en determine the
spherical coordinates of the endpoint of this product. Then 2
rotations will rotate this vector to make it point in the direction
of the Z-axis. The rotated points P1', P2' and P3' are not in the X -
Y plane, but that is no problem, the slicer will fix that.
Maurice
P1=[1,2,3];
P2=[3,4,5];
P3=[-5,6,1];
D=.3;
hull(){                    // original plane
translate(P1)
sphere(D);
translate(P2)
sphere(D);
translate(P3)
sphere(D);
P12=P2-P1;                  // translate P1 to origin
P13=P3-P1;
Cr=cross(P12,P13);          // calculate cross product
R=norm(Cr);                // calculate spherical coordinates
Inclin=acos(Cr.z/R);
Azim=atan2(Cr.y,Cr.x);
rotate([0,-Inclin,0])      // and rotate accodingly
rotate([0,0,-Azim])
color("Red")
hull(){        // rotated plane
translate(P1)
sphere(D);
translate(P2)
sphere(D);
translate(P3)
sphere(D);
A plane is defined by O, X (x1,x2,x3) and Y (y1,y2,y3). What is the
(simplest) way to rotate this plane so that O stays O and both X and
Y rotate to the x, y plane (immaterial where)?
I want to lay an object flat on my printer table, and Cura refuses
to do it unfortunately...
Thanks,
Maurice
I've been looking for an answer to this question for quite some time, but in the end it turned out easier than I thought. I've defined 3 points (P1, P2 and P3) in space that I want to lay flat (i.e. parallel to the X - Y plane). Firstly, I translate P1 to the origin so I get what I described in the question, then I take the cross-product of the two other (translated) points, en determine the spherical coordinates of the endpoint of this product. Then 2 rotations will rotate this vector to make it point in the direction of the Z-axis. The rotated points P1', P2' and P3' are not in the X - Y plane, but that is no problem, the slicer will fix that. Maurice P1=[1,2,3]; P2=[3,4,5]; P3=[-5,6,1]; D=.3; hull(){ // original plane translate(P1) sphere(D); translate(P2) sphere(D); translate(P3) sphere(D); } P12=P2-P1; // translate P1 to origin P13=P3-P1; Cr=cross(P12,P13); // calculate cross product R=norm(Cr); // calculate spherical coordinates Inclin=acos(Cr.z/R); Azim=atan2(Cr.y,Cr.x); rotate([0,-Inclin,0]) // and rotate accodingly rotate([0,0,-Azim]) color("Red") hull(){ // rotated plane translate(P1) sphere(D); translate(P2) sphere(D); translate(P3) sphere(D); } >Hi, > >A plane is defined by O, X (x1,x2,x3) and Y (y1,y2,y3). What is the >(simplest) way to rotate this plane so that O stays O and both X and >Y rotate to the x, y plane (immaterial where)? > >I want to lay an object flat on my printer table, and Cura refuses >to do it unfortunately... > >Thanks, >Maurice
