Although you have taken care to make the cylinder slightly longer than
the cube, you have the edge of the diameter of the cylinder exactly
touching the top edge of the cube. You can change the $fn value to , a
number such as 25, where the edges do not touch, (zoom in to see what I
mean) or offset the centre slightly, make the cube a bit
bigger/whatever. Better still, do it in 2d and extrude.
Putting the cube difference first, then the edge of the cube has gone,
so it works OK.
$fn=24; // to be reasonably round
ln=30;// length of block
sh=26/2;// separation of bolt holes
bl=sh*3;// width of block
ld=16;// diameter of loom
module ext(){
linear_extrude(ln){
square([bl,ld*1.5],center=true);
translate([0,4])circle(d=ld);
translate([0,8.01])square([ld,ld/2+.1],center=true);
ext();
On 14/03/2023 19:42, gene heskett wrote:
Greatings all;
Possible buglet advisory...
Trying to make a loom clamp to anchor a hot end umbilical cable, seems
like it s/b easy, define a cube and a recipe of differences.
F5 works in a few milliseconds, F6 reports:
[fast-csg] corefinement mesh difference #469: 12 facets vs. 92 facets
[fast-csg-remesh] Remeshed from 214 to 12 faces (94 % improvement)
WARNING: [fast-csg] Corefinement corefinement mesh difference #469 failed
Rendering cancelled on first warning.
I still need to add a couple bolt holes to attach it to the printer.
So I've turned off fast-cgi, and F6 now works.
Cheers, Gene Heskett.
than the cube, you have the edge of the diameter of the cylinder
exactly touching the top edge of the cube. You can change the $fn
value to a number such as 25, where the edges do not touch, (zoom in
to see what I mean) or offset the centre slightly, make the cube a
bit bigger/whatever. Better still, do it in 2d and extrude.
Thanks Ray, I thought that might have been the problem, but I didn't
want to take the chance of possible misleading anyone.
gone,
so it works OK.
module ext(){
linear_extrude(ln){
ext();
Greatings all;
seems
facets
failed
printer.
