leebc11 (at) acm.org
Tue, Mar 10, 2026 10:31 AM
I’m having a problem where when I rotate my model in the view port with the mouse, OpenSCAD crashes.
Any ideas?
I’m not seeing any obvious settings I can change in the Preferences.
I think this started after a recent snap update.
I’m running OpenSCAD-nightly: version 2026.02.25.snap (git ae3a780de)
on AMD Radeon R7 M360 (RADV ICELAND)
Thank you!
Any ideas?
I’m running [OpenSCAD](https://www.openscad.org/)-nightly: version 2026.02.25.snap (git ae3a780de)\
Thank you!
Wed, Mar 18, 2026 6:12 AM
I think that my problem is happening because my mouse button is flaking out and sending multiple clicks.
I can replicate this issue by pointing in the preview window and rapidly clicking a touchpad mouse button.
Does anyone know of a work around while I order a new mouse?
Wed, Mar 18, 2026 7:19 AM
That is typical of a mouse whose switch button was not fully seated
against the PCB when it was originally soldered in. And it is something
someone who can re-solder it solidly against the PCB can fix. What has
happened is that because it wasn't seated properly, the switch will
gradually pull the copper foil away from the PCB by a thou or so and a
million clicks of the button will cause a contact when the switch
closes, then a break as the copper separates, generating the first
click, then when the finger releases the button, the foil remakes the
connection before the switch reopens, giving the computer a 2nd click as
you lift the finger. We get used to a certain "feel" & a new mouse is
often different enough to make you want the old one. I've probably
restored 50 mice that way.
The best fix is usually a piece of 30 ga wrapping wire, soldered to the
switch contact and long enough it will take a few million more clicks to
break it again, soldered to the PCB trace a half inch away.
Cheers, Gene Heskett, CET.
- Louis D. Brandeis
______________________________________________
- Louis D. Brandeis
Thu, Mar 19, 2026 7:10 PM
2 questions:
1: Why am I still getting more copy's of this post a week later with no
additional content? The only thing changing is the return address.
2: Why are my posts advising how to repair that flaky mouse being routed
to /dev/null?
My post describing how to fix it, probably forever has not come back.
I have no clue if the OP even saw my reply.
Yes, it could be called off-topic but its a topic I as a C.E.T. who CAN
SOLDER,
I've been doing it for a living for about 80 years and am very familiar
with,
and I enjoy helping where I can. Today, modern production methods have
reduced good manual soldering to an almost lost art. And its something
that in retrospect in having several assistants over the last half century,
cannot be simply taught, its an art form more than a procedure to be
taught.
If someone decided my post was off-topic, then so was the original I
replied
to a week ago. . . I shouldn't make that mistake again, but YMMV.
- Louis D. Brandeis
2 questions:
to /dev/null?
SOLDER,
with,
taught.
replied
- Louis D. Brandeis
JR
Jeff Ross
Thu, Mar 19, 2026 7:52 PM
2 questions:
to /dev/null?
CAN SOLDER,
familiar with,
century,
taught.
replied
Your message made it to the list just fine. I have not been getting any
additional copies of the message you replied to, though.
Jeff
> 2 questions:
> to /dev/null?
> CAN SOLDER,
> familiar with,
> century,
> taught.
> replied
Jeff
Thu, Mar 19, 2026 8:48 PM
I find Microsoft mice always develop switch bounce after a couple of years.
It isn't a bad connection, they just don't debounce the switches properly.
The only solution is to replace the switches.
On Thu, 19 Mar 2026 at 19:52, Jeff Ross via Discuss <
2 questions:
to /dev/null?
CAN SOLDER,
familiar with,
century,
taught.
replied
Jeff
> > 2 questions:
> > to /dev/null?
> > CAN SOLDER,
> > familiar with,
> > century,
> > taught.
> > replied
> Jeff
Thu, Mar 19, 2026 10:46 PM
to /dev/null?
CAN SOLDER,
familiar with,
any additional copies of the message you replied to, though.
Hmm, my t-bird is confused? Possibly. I have not been really happy
with it for a couple years.
Thanks Jeff.
- Louis D. Brandeis
>> to /dev/null?
>> CAN SOLDER,
>> familiar with,
Thanks Jeff.
> Jeff
- Louis D. Brandeis
