Hello,
I'm using OpenSCAD to export a preview of 3dmodel files for our new
forum. It is run using shell_exec(), exec(), etc. On my primary
development computer it (x32 and x64, latest stable, tested) works great
once every few minutes, but always puts up a crash report on second/next
export properly. I tried killing the script just after executing
openscad.com but it still crashes.
Here's the message:
Problem signature:
Problem Event Name: APPCRASH
Application Name: openscad.com
Application Version: 0.0.0.0
Application Timestamp: 5536adde
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.17651
Fault Module Timestamp: 4e211319
Exception Code: c0000005
Exception Offset: 0000d4d5
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Here's the command line run and the output php gets from running the
program:
c:/progra~2/OpenSCAD/openscad.com -o
D:/xampp/htdocs/dangercore/temp_upload/w1/render.png -D"model="C
:/Users/ian/AppData/Local/Temp/EDF4.tmp/test.STL"" --projection=o
D:/xampp/htdocs/dangercore/openscad
/stl2png.scad
Normalized CSG tree has 1 elements
OpenGL Program Validation results:
Validation successful.
stl2png.scad is simply:
model = "default.stl";
import(file = model);
I just came home to try it on a different rig, and it never crashes as
all! I will just ignore it for now as the server runs the linux version
of openscad and doesn't seem to have any problems either.
To summarize:
- Running from php exec() works perfectly one time, then next runs all
create a crash report box. Leave it for 5-10 minutes and it runs fine again
- Image still created successfully, it just seems like a crash upon exit
- Running same command from command line or .bat file works every time
- Crashes on work computer (x32 and x64), works fine on home computer
and linux server
- There seem to be no zombie processes active when it crashes
Honestly it is just a minor annoyance on one computer and is likely due
to the configuration of that box. However, if anyone sees anything
obvious I'd appreciate a suggestion.
Thank you and best regards,
ian
Hello,
Here's the message:
Problem signature:
Locale ID: 1033
program:
D:/xampp/htdocs/dangercore/temp_upload/w1/render.png -D"model=\"C
:/Users/ian/AppData/Local/Temp/EDF4.tmp/test.STL\"" --projection=o
/stl2png.scad
To summarize:
1. Running from php exec() works perfectly one time, then next runs all
2. Image still created successfully, it just seems like a crash upon exit
3. Running same command from command line or .bat file works every time
4. Crashes on work computer (x32 and x64), works fine on home computer
and linux server
5. There seem to be no zombie processes active when it crashes
ian
