So then how do you mix python and OpenSCAD ?
"Sometimes I think the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us."
Bill Waterson (Calvin & Hobbes)
On Dec 17, 2023, at 9:17 PM, Sanjeev Prabhakar <sprabhakar2006@gmail.com> wrote:
I am using Jupyter notebook to write python codes for openscad.I tried pythonscad but somehow it did not work.
On Mon, 18 Dec 2023 at 03:46, Dan White via Discuss <discuss@lists.openscad.org> wrote:
Thanks for clarifyingI will look at pythonscad
On Dec 17, 2023, at 3:59 PM, William F. Adams via Discuss <discuss@lists.openscad.org> wrote:
On Sunday, December 17, 2023 at 03:41:14 PM EST, Dan White via Discuss <discuss@lists.openscad.org> wrote:
>I think I am seeing in these examples is a way to generate points using python source code
>and then have the python output to an OpenSCAD source file for rendering.
>Is this accurate ?
No.
The version of OpenSCAD being used here has Python enabled w/in it, so can do rendering from Python files, or working from Python commands/data structures:
There is work on-going to integrate it into OpenSCAD directly:
https://github.com/openscad/openscad/issues/4880
and for folks who aren't good at Python, it is workable to just use it as a project warrants --- for example in the work I have been doing:
I <use ...> one Python file, wrap it in an OpenSCAD file which is also brough in via <use ....>, then reference that OpenSCAD file using <include ...> and that then allows me to use OpenSCAD quite naturally, while taking advantage of (for example) persistent Python variables (so that the position of a virtual CNC machine can be tracked), and the ability of Python to write out files (so that DXF files which do not describe closed regions may be output, or G-code can be written out directly, forgoing the need for a traditional CAM program).
To unsubscribe send an email to discuss-leave@lists.openscad.org_______________________________________________
There are various videos I have posted on my github page you can check them.
https://github.com/sprabhakar2006/openSCAD/tree/main/videos
On Mon, 18 Dec, 2023, 8:51 am Dan White via Discuss, <
On Dec 17, 2023, at 9:17 PM, Sanjeev Prabhakar sprabhakar2006@gmail.com
python source code
Is this accurate ?
No.
structures:
I have posted a video as to how to model this:
May be of some interest to some
https://github.com/sprabhakar2006/openSCAD/blob/main/videos/2_ring_fillet.3gp
On Sun, 17 Dec 2023, 16:47 Sanjeev Prabhakar, sprabhakar2006@gmail.com
difficult to make in openscad as per me.
[image: Screenshot 2023-12-17 at 4.25.16 PM.png]
file can be downloaded from here:
https://github.com/sprabhakar2006/openSCAD/blob/main/complex_fillet.scad
