I am running OpenSCAD 2024.01.06.
In the menu under Edit/Preferences there is a tab Buttons. I selected
<Button 0> to be "Export as Obj". Where is it documented how I can place
or press this button or can someone explain it?
These (along with the Axes tab) are referring to buttons belonging to a
physical gamepad input or other controller/joystick etc. If you have one
plugged in, then the button enumeration is dependent on your
hardware+drivers.
It's not for placing custom UI elements if that's what you were thinking.
On Thu, Jul 25, 2024 at 12:07 PM Todd Allen via Discuss <
Thanks. Yes I was hoping there was a mechanism to add the buttons to the
UI or map them to a keystroke. Anyone know of a good way to emulate a
gamepad buttons using a keyboard in linux?
On Thu, Jul 25, 2024 at 11:02 PM Hans L via Discuss <
hardware+drivers.
