K
Ken
Sat, Aug 29, 2026 11:35 PM
I need flatten the base of an stl file for a friend- if it were in openscad it would be really simple, just difference it with a cube.- but alas, it's not
I have done google searches and there are a plethora of programs that claim to be able to do this, so I thought I would seek opinions on which is the simplest that can do this. It can be either linux or windows, but preferably linux. I'm running linux mint & windows 10 (the W10 box is not allowed off the reservation).
Thanks, Ken
bats059@gmail.com
https://vk7krj.com
TA
Todd Allen
Sun, Aug 30, 2026 12:02 AM
You can probably do it in OpenSCAD. Try:
import("my_friends.stl");
cube(100);
On Sat, Aug 29, 2026 at 6:36 PM Ken via Discuss discuss@lists.openscad.org
alas, it's not
Thanks, Kenbats059@gmail.comhttps://vk7krj.comhttps://vk7krj.com/running.html
cube(100);
On Sat, Aug 29, 2026 at 6:36 PM Ken via Discuss <discuss@lists.openscad.org>
> alas, it's not
> A baby can be defined as an ego with a noise at one end and a smell at the other.
> Your job as parents is to teach them to control all three.
> My job as a grandad is to tell you how you are doing it all wrong!
K
Ken
Sun, Aug 30, 2026 1:01 AM
Thanks Todd- that worked a treat. And it will also come in very useful in the future.
cube(100);
> difference() {
> cube(100);
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Sun, Aug 30, 2026 1:11 AM
You can also do it in any modern Slicer. Import the model, use the
horizontal cut, then export as an STL.
but alas, it's not
> but alas, it's not
> Thanks, Ken
> bats059@gmail.com
> https://vk7krj.com
FH
Father Horton
Sun, Aug 30, 2026 1:37 AM
Or meshmixer, but that's no longer officially supported.
On Sat, Aug 29, 2026 at 8:11 PM Jon Bondy via Discuss <
> alas, it's not
> Thanks, Kenbats059@gmail.comhttps://vk7krj.com <https://urldefense.proofpoint.com/v2/url?u=https-3A__vk7krj.com&d=DwMCaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=vUm9V6-tDkcsAkj-M-CJm0v9FsVgSrvXJ_sMJaHVIOrBe_dmQ0uaL85nspjXv23m&s=362TvkzCUmjWOwDT1it7tnk5XBf7-wFcJXpXP54WnJQ&e=>https://vk7krj.com/running.html <https://urldefense.proofpoint.com/v2/url?u=https-3A__vk7krj.com_running.html&d=DwMCaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=vUm9V6-tDkcsAkj-M-CJm0v9FsVgSrvXJ_sMJaHVIOrBe_dmQ0uaL85nspjXv23m&s=i8enJFaJ8vCNXdX7w0VkfzsWNIJdgomBlEInc6GrFfU&e=>
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> Virus-free.www.avg.com
> <#m_8235156943211792022_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Sun, Aug 30, 2026 4:58 AM
One caveat on importing STLs, at least historically with CGAL, is that many STLs in the wild are not up to OpenSCAD’s picky standards, and the render fails. Maybe Manifold has made that better. Net, do a simple experiment (e.g. union with a cube) with the particular STL before you spend significant effort designing the edit.
K
Ken
Sun, Aug 30, 2026 6:22 AM
Thanks Jordan- these are produced by (I think..) fusion360, I've made simple changes of two this afternoon and so far haven't had any trouble.
But your caveat is appreciated.
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Sun, Aug 30, 2026 9:41 AM
edit.
Yeah, the consensus was here that "STLs from the internet" are
"broken" and that openscad wouldn't open broken STLs. At one point in
time I even had an STL generated by openscad that was "bad".
But diving in I found that the "bad" STLs might have a few "corner
cases" but nothing that was actually forbidden.
With other programs like slicers being able to slice them just fine,
and newer openscad with manifold working just fine with them I've come
to the conclusion that the bug simplie lies with CGAL. It has the
stuckup attitude that everything it can't handle must be bad instead
of thinking there might be a bug somwhere.
So again: Advice is to move to manifold and suddenly there are a lot
less "bad STLs" in the world around us.
** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands.
** KVK: 27239233 **
** 'a' for accelleration.
> edit.
** KVK: 27239233 **
