extra lines showing up in SVG export
Mon, Oct 28, 2024 5:53 PM
On 28.10.24 16:43, khackbarth via Discuss wrote:
It's the official version that dates back to 2021.  I'm looking forward to better SVG
import in the new version...
The SVG import did get a couple of updates, but it's not huge changes.
If you are using the release version, that rules out the issue I
suspected. So it would still need some more investigation where
those extra lines are coming from.
On 28.10.24 16:43, khackbarth via Discuss wrote: > It's the official version that dates back to 2021. I'm looking forward to better SVG > import in the new version... The SVG import did get a couple of updates, but it's not huge changes. If you are using the release version, that rules out the issue I suspected. So it would still need some more investigation where those extra lines are coming from. ciao, Torsten.
K
ken@volksswitch.org
Tue, Oct 29, 2024 2:56 PM
Hi William,
You're welcome to download https://volksswitch.org/index.php/volks-devices/customizable-3d-printable-keyguard-for-grid-based-free-form-and-hybrid-aac-apps-on-tablets/  and parse my code which is Open Source.  If you do, let me know and I'll also send you the input file that causes the issue.
I anticipate that it would take about two weeks to create a test harness based on my code.  I was able to update my code to work exclusively with 2D-shapes for this feature in two days.  The feature runs MUCH faster as well.
Thanks,
Ken
Sent: Monday, October 28, 2024 5:03 AM
To: khackbarth via Discuss discuss@lists.openscad.org
Subject: [OpenSCAD] Re: extra lines showing up in SVG export
If you're willing to use OpenPythonSCAD I've been working on a tool which outputs DXF files directly:
https://github.com/WillAdams/gcodepreview https://github.com/WillAdams/gcodepreview
Currently re-writing it, but it does line and arcs (which can then be preserved by your CAM tool), and it should be pretty straight-forward to code up primitives which output matching DXFs.
FWIW, I would be quite interested in a test case which breaks the projection() command --- I've used it in the past, and aside from one moderately complex model (a pair of Mitutoyo calipers) it has always worked for me, (and I believe a subsequent update fixed it).
Hi William, You're welcome to download <https://volksswitch.org/index.php/volks-devices/customizable-3d-printable-keyguard-for-grid-based-free-form-and-hybrid-aac-apps-on-tablets/> and parse my code which is Open Source. If you do, let me know and I'll also send you the input file that causes the issue. I anticipate that it would take about two weeks to create a test harness based on my code. I was able to update my code to work exclusively with 2D-shapes for this feature in two days. The feature runs MUCH faster as well. Thanks, Ken -----Original Message----- From: William F. Adams <willadams@aol.com> Sent: Monday, October 28, 2024 5:03 AM To: khackbarth via Discuss <discuss@lists.openscad.org> Subject: [OpenSCAD] Re: extra lines showing up in SVG export If you're willing to use OpenPythonSCAD I've been working on a tool which outputs DXF files directly: <https://github.com/WillAdams/gcodepreview> https://github.com/WillAdams/gcodepreview Currently re-writing it, but it does line and arcs (which can then be preserved by your CAM tool), and it should be pretty straight-forward to code up primitives which output matching DXFs. FWIW, I would be quite interested in a test case which breaks the projection() command --- I've used it in the past, and aside from one moderately complex model (a pair of Mitutoyo calipers) it has always worked for me, (and I believe a subsequent update fixed it). William
K
ken@volksswitch.org
Tue, Oct 29, 2024 3:00 PM
They're huge changes as far as I'm concerned - and for a different reason than the one in this thread.  OpenSCAD is currently importing curved edges in SVG images with hundreds of segments, which can't successfully be rendered.
Sent: Monday, October 28, 2024 11:54 AM
They're huge changes as far as I'm concerned - and for a different reason than the one in this thread. OpenSCAD is currently importing curved edges in SVG images with hundreds of segments, which can't successfully be rendered. -----Original Message----- From: Torsten Paul <Torsten.Paul@gmx.de> Sent: Monday, October 28, 2024 11:54 AM To: discuss@lists.openscad.org Subject: [OpenSCAD] Re: extra lines showing up in SVG export On 28.10.24 16:43, khackbarth via Discuss wrote: > It's the official version that dates back to 2021. I'm looking > forward to better SVG > import in the new version... The SVG import did get a couple of updates, but it's not huge changes. If you are using the release version, that rules out the issue I suspected. So it would still need some more investigation where those extra lines are coming from. ciao, Torsten.
WF
William F. Adams
Tue, Oct 29, 2024 6:20 PM
It crashed when I enabled "first layer for SVG/DXF file" (using 2023.11.30) --- I'll have to dig around and see what else I can get installed and working in it.
On Tuesday, October 29, 2024 at 10:56:38 AM EDT, khackbarth via Discuss discuss@lists.openscad.org wrote:
Hi William,
You're welcome to download and parse my code which is Open Source.  If you do, let me know and I'll also send you the input file that causes the issue.
Thanks,
Ken
It crashed when I enabled "first layer for SVG/DXF file" (using 2023.11.30) --- I'll have to dig around and see what else I can get installed and working in it. William On Tuesday, October 29, 2024 at 10:56:38 AM EDT, khackbarth via Discuss <discuss@lists.openscad.org> wrote: Hi William,   You're welcome to download and parse my code which is Open Source.  If you do, let me know and I'll also send you the input file that causes the issue.   I anticipate that it would take about two weeks to create a test harness based on my code.  I was able to update my code to work exclusively with 2D-shapes for this feature in two days.  The feature runs MUCH faster as well.   Thanks, Ken     -----Original Message----- From: William F. Adams <willadams@aol.com> Sent: Monday, October 28, 2024 5:03 AM To: khackbarth via Discuss <discuss@lists.openscad.org> Subject: [OpenSCAD] Re: extra lines showing up in SVG export   If you're willing to use OpenPythonSCAD I've been working on a tool which outputs DXF files directly:   https://github.com/WillAdams/gcodepreview   Currently re-writing it, but it does line and arcs (which can then be preserved by your CAM tool), and it should be pretty straight-forward to code up primitives which output matching DXFs.   FWIW, I would be quite interested in a test case which breaks the projection() command --- I've used it in the past, and aside from one moderately complex model (a pair of Mitutoyo calipers) it has always worked for me, (and I believe a subsequent update fixed it).   William _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
