The pop-up syntax help is a welcome tool for novices like me. But having
displayed it after typing the opening bracket, is there a setting I
haven't yet discovered that will let me select an option and have it
copied directly into my code?
Screenshot attached, or here:
https://www.dropbox.com/s/9roe6cos4v7024h/PasteOption.jpg?raw=1
Terry
No, it is just a visual reminder.
It is a feature of the underlying library, so not easy to add functionality.
Sent: Fri, 2 Jul 2021 19:42
To: OpenSCAD Mailing List
Subject: [OpenSCAD] Copying syntax option to editor?
Terry
You can select the item in the drop down list and then use ctrl-enter to
insert it into the code. Not at all obvious.
functionality.
Terry
I don't think that works for call-tips.
Sent: Sun, 4 Jul 2021 17:34
Subject: [OpenSCAD] Re: Copying syntax option to editor?
You can select the item in the drop down list and then use ctrl-enter to insert it into the code. Not at all obvious.
Terry
That would be exactly what I'd like - but, like Michael, I can't get
that to work here. I type say 'cube(' and the pop-up appears. But as
soon as I select with the arrow key or mouse it disappears. And then
using Ctrl + Enter has no effect.
Terry
functionality.-----Original Message-----
Subject: [OpenSCAD] Copying syntax option to editor?The pop-up syntax help is a welcome tool for novices like me. But having
copied directly into my code?Screenshot attached, or here:
https://www.dropbox.com/s/9roe6cos4v7024h/PasteOption.jpg?raw=1Terry
Ah I see, the call tips are different.
Terry
functionality.
having
Terry
