Sat, Oct 1, 2022 7:29 AM
I may be over-simplifying this, but if the SVG won't import cleanly, yet displays correctly in a web browser, just convert the SVG to a PNG or GIF (or take a screenshot of it) and use surface() to load it.
On Sep 30, 2022, at 3:25 PM, Marcus Poller h-openscad.org@crystaldown.de wrote:
Dear OpenSCAD users,
I am new to this list. Please bear with me, feedback is welcome.
I have got an issue that OpenSCAD tells me my shape was not closed and I do not understand why.
Here's the context:
I want to 3d-print a box that looks like it's made of wood. Therefore I decided to apply a texture (SVG) that resembles the annual rings of a tree. I want to apply that texture to the sides of the box. The printer cannot print overhangs without support structure, but overhanging angles of 45° (from base to overhanging outer side) are fine. So I thought I can convert the SVG to a 3d-structure with 45° rises on every side by using minkowski() and applying a cylindrical cone. Of course I need to cheat and convert the 2d SVG to 3d structure first by applying a linear_extrude() before applying minkowski();
I have tried various combinations to get a slice of wooden texture:
- minkowski to printable angles, use cube() and intersect() to cut a piece of proper size. Suffers from a drain of CPU for the minkowski
- minkowski SVG, render, export as STL. Import STL, use cube()+intersect() to cut a piece of proper size. I can provide an example, but its file size is 80 MBytes
- user intersect, apply minkowski.
Each of the approaches failes in one of those ways:
- ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron. (2022-09-25_probedruck_textur.scad)
- WARNING: Object may not be a valid 2-manifold and may need repair! (2022-09-11_probedrucke.scad)
- finishes rendering with an empty screen (2022-09-25_probedruck_textur.scad 3rd piece in x-y-plance)
Affected OpenSCAD Versions:
- OpenSCAD version 2021.01
- OpenSCAD version 2022.09.20.ai12175
I do not understand what I'm doing wrong and could use some advice what kind of problem I created. It's very hard to do extensive testing, because each attempt consumes a lot of CPU and patience. As a side it would be nice to get advice on how to cut CPU time.
I attached my samples. The error messages vary between preview and render.
Cheers,
Marcus
<holztextur.svg><2022-09-11_probedrucke.scad><2022-09-25_probedruck_textur.scad>_______________________________________________
I may be over-simplifying this, but if the SVG won't import cleanly, yet displays correctly in a web browser, just convert the SVG to a PNG or GIF (or take a screenshot of it) and use `surface()` to load it.
- Revar
> On Sep 30, 2022, at 3:25 PM, Marcus Poller <h-openscad.org@crystaldown.de> wrote:
> Here's the context:
> * minkowski to printable angles, use cube() and intersect() to cut a piece of proper size. Suffers from a drain of CPU for the minkowski
> * minkowski SVG, render, export as STL. Import STL, use cube()+intersect() to cut a piece of proper size. I can provide an example, but its file size is 80 MBytes
> * user intersect, apply minkowski.
> * ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron. (2022-09-25_probedruck_textur.scad)
> * WARNING: Object may not be a valid 2-manifold and may need repair! (2022-09-11_probedrucke.scad)
> * finishes rendering with an empty screen (2022-09-25_probedruck_textur.scad 3rd piece in x-y-plance)
> * OpenSCAD version 2021.01
> * OpenSCAD version 2022.09.20.ai12175
> Cheers,
> Marcus
MP
Marcus Poller
Sat, Oct 1, 2022 11:49 AM
Managementsummary: Dimensions too large.
I used inkscape to convert the SVG to PNG. The resulting PNG is
File name : holztextur.png
File size : 613284 Bytes
MIME type : image/png
Image size : 2628 x 2056
Then I tried to import the image as surface
$ cat 2022-10-01_surface.scad
surface(file="holztextur.png",center=true,convexity=10);
and I get
$ openscad 2022-10-01_surface.scad
Killed
I am just assuming that 2000 pixel is fundamentally oversized for OpenSCAD. Downsizing the image is fine.
I would like to discuss a sane dimension. The longest side in the final object will be 20cm; The plastic thread is very fine at 0.1mm; Oversimplyfying: Each possible plastic thread gets its own pixel. I would expect a (according to Nyquist–Shannon sampling theorem) sane dimension is at minimum 2 pixel per plastic thread. Maybe I am getting it totally wrong, I may sand the product after printing and nobody will ever notice.
More opinions on sane dimensions are welcome.
Previewing in lower dimensions is fine. Can I make OpenSCAD deal with the PNG dimensions for the final render and STL-export?
Cheers
Marcus
Here's the context:
Cheers,
Marcus
and I get
Killed
Cheers
Marcus
> > Here's the context:
> > Cheers,
> > Marcus
MP
Marcus Poller
Sat, Oct 1, 2022 12:37 PM
Managementsummary: Would anybody help me confirm this is not a programming bug?
and I get
Killed
I was curious whether this is an out-of-memory issue or something else. I ran in valgrind
$ valgrind openscad 2022-10-01_surface.scad
==6099== Command: openscad 2022-10-01_surface.scad
==6099==
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /usr/include/CGAL/Interval_nt.h
Line: 279
Explanation: Wrong rounding: did you forget the -frounding-math option if you use GCC (or -fp-model strict for Intel)?
==6099==
==6099== Process terminating with default action of signal 6 (SIGABRT)
I would like to confirm this does not happen with nightly and is dependent on my environment (Debian CGAL-Libraries, CPU, ...). But I recently failed to compile OpenSCAD, so I would like to ask anybody with nightly debug build: Can this behavior be confirmed?
Files for reproduction attached.
Cheers,
Marcus
> and I get
> Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
Michael Marx
Sat, Oct 1, 2022 12:58 PM
Not sure about the crash, but surface() is not good with larger sizes.
Vague recollection of memory issues.
From: Marcus Poller [mailto:h-openscad.org@crystaldown.de]
Sent: Sat, 1 Oct 2022 22:37
Subject: [OpenSCAD] CGAL::Assertion (was: minkowski + mesh is not closed)
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
> -----Original Message-----
> To: OpenSCAD general discussion
> > and I get
> > Killed
> ==6099==
> Line: 279
> ==6099==
> Cheers,
> Marcus
Sat, Oct 1, 2022 1:07 PM
With the inherently high resolution your model has, I see only
one realistic chance but that's based on the experimental roof()
feature, so it's not possible for a script that needs to work
archived/unchanged for a long time.
It's still going to be slow when combining that with the other
parts of the design. But on a system with enough memory in might
at least produce a result at some point.
- Convert all curves in the SVG to lines at a resolution as
low as possible:
Extensions -> Modify Path -> Flatten Beziers
- Use roof() import("file.svg") which will directly add the
45° 3d structure
Michael Marx
Sat, Oct 1, 2022 1:13 PM
Yes, back in the day doing lithophanes. https://www.thingiverse.com/thing:78719/files
(wow almost a decade)
We lad to limit it ~100-200 x 100-200.
That was surface() with .dat (& 32 bit),
but I imagine the internals for .svg are not much better.
If you could answer the 'BTW' questions it may help re expectations.
Big and fine-detail tend to be bad.
Sent: Sat, 1 Oct 2022 22:58
Subject: [OpenSCAD] Re: CGAL::Assertion (was: minkowski + mesh is not closed)
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
> From: Michael Marx [mailto:michael@marx.id.au]
> To: 'OpenSCAD general discussion'
> of
> > > and I get
> > > Killed
> valgrind
> > ==6099==
> > Line: 279
> > ==6099==
> OpenSCAD,
> > Cheers,
> > Marcus
> This email has been checked for viruses by AVG antivirus software.
> www.avg.com
Sat, Oct 1, 2022 1:20 PM
Line: 279
Like the explanations says, this is a check in CGAL that verifies
the execution supports floating point rounding math settings.
Valgrind does not support that, triggering this assertion. This
does not happen on the real (Intel) hardware.
It's possible to disable this check by compiling with a special
define CGAL_DISABLE_ROUNDING_MATH_CHECK - I don't remember if the
cmake setup has explicit support for this (it's always added for
WASM compile as that does not support rounding math either).
I have no idea what subtle issues the disabled check will have
on CGAL algorithms. It will make them run, but there might be
differences in point classification producing different results.
> Line: 279
Michael Marx
Sat, Oct 1, 2022 1:23 PM
I'm also wondering if some external processing could be relevant.
Sanjeev's thingi, below, may be relevant.
I have not looked at it in detail, but offloading to python (?) may be good for details. ?????
Dear All,
I have experimented with jupyter notebook to calculate points in space and then passing the same to
openscad for creating 3d shapes.
Found it to be quite interesting.
Wrote almost all the functions of openscad in jupyter notebook.
you can refer to the page below for few examples:
https://github.com/sprabhakar2006/openSCAD
you need to have some working knowledge of numpy and jupyter notebook for this to work.
Regards
Sanjeev
Sent: Sat, 1 Oct 2022 23:14
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
Dear All,
Regards
Sanjeev
> > of
> > > > and I get
> > > > Killed
> > valgrind
> > > ==6099==
> > > Line: 279
> use
> > > ==6099==
> > OpenSCAD,
> confirmed?
> > > Cheers,
> > > Marcus
> > www.avg.com
> www.avg.com
Sat, Oct 1, 2022 2:03 PM
BOSL2 has some new texture support that seems relevant to this, though I'm
not sure if it can really solve the problem. You'd have to compute the
surface somehow, and there might be issues with how the edges get created,
but it will create the shape as one polyhedron, so that should be about as
fast as is possible.
https://github.com/revarbat/BOSL2/wiki/skin.scad#function-texture
Note that the documentation for the texture stuff needs some work. You can
create your own texture using an array or VNF---you don't just have to use
the built-in ones.
Dear All,
this to work.
Regards
Sanjeev
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
the built-in ones.
> Dear All,
> this to work.
> Regards
> Sanjeev
> closed)
> closed)
> closed)
> programming bug?
> take a screenshot
> > > of
> > > > > and I get
> > > > > Killed
> else. I ran in
> > > valgrind
> > > > ==6099==
> > > > Line: 279
> > use
> > > > ==6099==
> (SIGABRT)
> dependent on my
> to compile
> > > OpenSCAD,
> behavior be
> > confirmed?
> > > > Cheers,
> > > > Marcus
> > > www.avg.com
> > www.avg.com
> www.avg.com
BL
Bryan Lee
Sat, Oct 1, 2022 4:39 PM
I appologize, I haven't really been following this thread.
I guess @Marcus Poller:
By any chance are you trying to create terrain for Unity3D? I have
a workflow process for that.
Alternately, if you're just trying to recreate an svg curve in
OpenSCAD, do you have a way to extract points from that curve and create a
cube or cylinder or sphere [x1,y1,0] for each point on the curve,
possibly rotated to angle with the last and next points?
Thus Torsten Paul hast written on Sat, Oct 01, 2022 at 03:07:53PM +0200, and, according to prophecy, it shall come to pass that:
