MP
Marcus Poller
Fri, Sep 30, 2022 10:25 PM
Dear OpenSCAD users,
I am new to this list. Please bear with me, feedback is welcome.
I have got an issue that OpenSCAD tells me my shape was not closed and I do not understand why.
Here's the context:
I want to 3d-print a box that looks like it's made of wood. Therefore I decided to apply a texture (SVG) that resembles the annual rings of a tree. I want to apply that texture to the sides of the box. The printer cannot print overhangs without support structure, but overhanging angles of 45° (from base to overhanging outer side) are fine. So I thought I can convert the SVG to a 3d-structure with 45° rises on every side by using minkowski() and applying a cylindrical cone. Of course I need to cheat and convert the 2d SVG to 3d structure first by applying a linear_extrude() before applying minkowski();
I have tried various combinations to get a slice of wooden texture:
- minkowski to printable angles, use cube() and intersect() to cut a piece of proper size. Suffers from a drain of CPU for the minkowski
- minkowski SVG, render, export as STL. Import STL, use cube()+intersect() to cut a piece of proper size. I can provide an example, but its file size is 80 MBytes
- user intersect, apply minkowski.
Each of the approaches failes in one of those ways:
- ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron. (2022-09-25_probedruck_textur.scad)
- WARNING: Object may not be a valid 2-manifold and may need repair! (2022-09-11_probedrucke.scad)
- finishes rendering with an empty screen (2022-09-25_probedruck_textur.scad 3rd piece in x-y-plance)
Affected OpenSCAD Versions:
- OpenSCAD version 2021.01
- OpenSCAD version 2022.09.20.ai12175
I do not understand what I'm doing wrong and could use some advice what kind of problem I created. It's very hard to do extensive testing, because each attempt consumes a lot of CPU and patience. As a side it would be nice to get advice on how to cut CPU time.
I attached my samples. The error messages vary between preview and render.
Cheers,
Marcus
Here's the context:
* minkowski to printable angles, use cube() and intersect() to cut a piece of proper size. Suffers from a drain of CPU for the minkowski
* minkowski SVG, render, export as STL. Import STL, use cube()+intersect() to cut a piece of proper size. I can provide an example, but its file size is 80 MBytes
* user intersect, apply minkowski.
* ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron. (2022-09-25_probedruck_textur.scad)
* WARNING: Object may not be a valid 2-manifold and may need repair! (2022-09-11_probedrucke.scad)
* finishes rendering with an empty screen (2022-09-25_probedruck_textur.scad 3rd piece in x-y-plance)
* OpenSCAD version 2021.01
* OpenSCAD version 2022.09.20.ai12175
Cheers,
Marcus
Michael Marx
Fri, Sep 30, 2022 11:51 PM
DON'T PREVIEW THIS AS IS.
Marcus, please cut it down to a test case which does not run forever, I imagine l & h being smaller
could help.
From: Marcus Poller [mailto:h-openscad.org@crystaldown.de]
Sent: Sat, 1 Oct 2022 08:26
Subject: [OpenSCAD] minkowski + mesh is not closed
why.
Here's the context:
x-y-plance)
Cheers,
Marcus
could help.
> -----Original Message-----
> why.
> Here's the context:
> x-y-plance)
> Cheers,
> Marcus
Michael Marx
Sat, Oct 1, 2022 2:50 AM
2h13m on my system... and peaked just under 4GB memory.
With l=25, h=20, 1m28s, so if anyone want to play start from there.
Sent: Sat, 1 Oct 2022 09:51
Subject: [OpenSCAD] Re: minkowski + mesh is not closed
being smaller
could help.
why.
Here's the context:
x-y-plance)
Cheers,
Marcus
> From: Michael Marx [mailto:michael@marx.id.au]
> To: 'OpenSCAD general discussion'
> being smaller
> could help.
> understand
> > why.
> > Here's the context:
> a
> piece
> in
> > x-y-plance)
> I
> > Cheers,
> > Marcus
> This email has been checked for viruses by AVG antivirus software.
> www.avg.com
Sat, Oct 1, 2022 2:57 AM
Can you share a picture of what you are trying to do?
being smaller
could help.
why.
Here's the context:
x-y-plance)
> imagine l & h
> > being smaller
> > could help.
> I do not
> > understand
> > > why.
> > > Here's the context:
> I decided to apply
> > a
> using minkowski()
> the 2d SVG to 3d
> minkowski();
> piece of proper
> > piece
> MBytes
> (2022-09-
> > in
> > > x-y-plance)
> > I
> consumes a lot of
> cut CPU time.
> render.
> > > Cheers,
> > > Marcus
> > www.avg.com
> www.avg.com
Michael Marx
Sat, Oct 1, 2022 3:10 AM
Correction, that 2h13m was just sample_piece(),
without base() & antiwarp(), which should be minor,
and without the bottom four cube_intersect() conekowski_2d()'s, so god knows how long that would
be...they look expensive.
Same for the 1m28s.
A subsequent (same reduced code) l=30 h=30, was F5=2m20s, F6=0m15s.
Sanjeev, this is what the reduced 2h13m produced, looks similar on the back face.
Sent: Sat, 1 Oct 2022 12:50
Same for the 1m28s.
> From: Michael Marx [mailto:michael.marx@tpg.com.au]
> > being smaller
> > could help.
> > understand
> > > why.
> > > Here's the context:
> apply
> > a
> to
> but
> I
> minkowski()
> 3d
> > piece
> (2022-
> piece
> > in
> > > x-y-plance)
> problem
> > I
> of
> > > Cheers,
> > > Marcus
> > www.avg.com
> www.avg.com
Sat, Oct 1, 2022 3:20 AM
Oh, that seems complicated
I was thinking of something like the attached image.
This took around 5 minutes in my computer (M1 Macbook air)
knows how long that would be...they look expensive.
Same for the 1m28s.
back face.
On Sat, 1 Oct 2022 at 08:42, Michael Marx <michael@marx.id.au> wrote:
> *Correction*, that 2h13m was just sample_piece(),
> Same for the 1m28s.
> back face.
> I imagine l & h
> > > being smaller
> > > could help.
> and I do not
> > > understand
> > > > why.
> > > > Here's the context:
> > apply
> > > a
> apply that texture
> > to
> support structure,
> > but
> fine. So I thought
> > I
> by using
> > minkowski()
> > 3d
> minkowski();
> a piece of proper
> > > piece
> MBytes
> > (2022-
> repair! (2022-09-
> > piece
> > > in
> > > > x-y-plance)
> what kind of
> > problem
> > > I
> > of
> cut CPU time.
> render.
> > > > Cheers,
> > > > Marcus
> > > www.avg.com
> > www.avg.com
> [image: width=]
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> Virus-free.www.avg.com
> <#m_-2484108180385737096_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Michael Marx
Sat, Oct 1, 2022 5:54 AM
Marcus,
First, you should add convexity=10 to all your linear_extrude()'s, 10 may not be perfect, but is a
good number. This fixes preview strange effects, like faces disappearing when moving the display.
Alternatively, if it is not a hungry operation wrap
the linear_extrude() in render() {},
Next time, please comment out or stick into a test module those expensive operations,
like the three at the bottom and mention they can be tested separately.
I normally load up a file and hit F5 to see what's going on, getting a 2hr preview up front is not
nice.
If you have specific errors, it is nice to try to cut down your model to try and find the main
culprit. Try using '*' to block out chunks, a but of trial & error.
Each of the approaches fails in one of those ways:
A. Is the first error only with the sample_piece() or with the three operations at the bottom of
the file included?
B. Is the empty screen just with the 3rd piece, or are all the other bits rendered as well?
As you have found minkowski() is expensive. intersection() can be too.
More on this later.
But make things smaller when testing, bigger usually means more faces, means more processing.
I added:
sf=1/25;
and made your scale
scale([sf,sf]) import("holztextur.svg",center=true);
So you can make l & h smaller, shrink the scale too, this makes for quicker tests.
(However sometimes that can make some errors disappear - like some CGAL errors)
Breaking this down may help others.
First 2022-09-25_probedruck_textur.scad
Module sample_piece() has two sides,
the plane square edged, cheap re CPU, but no 45 degree solution,
though small recesses may be printable. Comment that out for testing.
Then the other side with the minkowski. Expensive.
Then there are three tests at the bottom, commenting those out for now.
I have not looked at the other .scad yet.
For now, can you answer A. & B. above, ATM I don't know which bits you are trying to debug.
With
sf=1/50;
l=10;
w=2;
h=10;
module sample_piece(){
//render()
union(){
cube([l,w,h]);
*translate([0,w+eh,0]) rotate([90,0,0]) linear_extrude(eh, convexity=10) wooden_texture_2d();
rotate([90,0,0])
intersection()
linear_extrude(1, convexity=10)
square([l,h]);
minkowski(){
linear_extrude(pseudo_3d, convexity=10)
cone();
That previews in 10m, and renders in 22s.
Marcus,
nice.
the file included?
More on this later.
I added:
sf=1/25;
and made your scale
With
sf=1/50;
l=10;
w=2;
h=10;
//render()
union(){
cube([l,w,h]);
rotate([90,0,0])
intersection()
square([l,h]);
minkowski(){
cone();
> why.
> Here's the context:
> x-y-plance)
> Cheers,
> Marcus
Michael Marx
Sat, Oct 1, 2022 6:31 AM
and with 2021.01 (can't run newer ones), it has many degenerate faces (yellow) & some
self-intersections (magenta).
Just reporting this for now.
It may explain CGAL errors.
Sent: Sat, 1 Oct 2022 15:54
Marcus,
nice.
the file included?
More on this later.
I added:
sf=1/25;
and made your scale
With
sf=1/50;
l=10;
w=2;
h=10;
//render()
union(){
cube([l,w,h]);
rotate([90,0,0])
intersection()
square([l,h]);
minkowski(){
cone();
tent=emailclient> width=www.avg.com
_____
Marcus,
nice.
the file included?
More on this later.
I added:
sf=1/25;
and made your scale
With
sf=1/50;
l=10;
w=2;
h=10;
//render()
union(){
cube([l,w,h]);
rotate([90,0,0])
intersection()
square([l,h]);
minkowski(){
cone();
> why.
> Here's the context:
> x-y-plance)
> Cheers,
> Marcus
Michael Marx
Sat, Oct 1, 2022 6:51 AM
BTW,
how big is the final box?
how fine-grained do you want the wood effect?
Performance is a factor of size & fine detail.
You could show an example of say the largest side, with l, h & sf with just:
module sample_piece_flat(){
union(){
cube([l,w,h]);
rotate([90,0,0])
That previews quickly.
BTW,
union(){
cube([l,w,h]);
rotate([90,0,0])
> why.
> Here's the context:
> x-y-plance)
> Cheers,
> Marcus
HJ
Hugo Jackson
Sat, Oct 1, 2022 7:01 AM
Have you considered something like the following as an approach to your general problem:
/* Sample piece for wooden texture options - uses overhang options and Minkowski*/
/* v2 2022-09-28 translation to English to ease support of OpenSCAD Mailinglist*/
l=100;
//w=2;
h=80;
//eh=0.5;
//pseudo_3d=0.001;
//base_layer_height=0.15;
//warp_protect_distance=4;
module wooden_texture_2d(){
intersection(){
translate([l,0,0]) scale([1/10,1/10]) import("holztextur.svg",center=true);
square([l,h]);
height = 1;
resolution = .05;
for(z = [0:resolution:height - resolution])
translate([0,0,z])
linear_extrude(resolution)
offset(z)
Simply set “height” to the height of the thickness of the ‘wooden' panel and “resolution” to something that’s some multiple finer than the layer height for the printer you will be using.
This will give you a 3 dimensional 45 degree sloped object of the 2d pattern you started with.
You can use a coarser resolution when you are developing, and increase it when you are ready to render, although preview is pretty zippy for the sample you provided at .05 resolution.
Rendering is still slow, but if you’re preparing this for an FDM printer it’ll still be incredibly faster than using minkowski.
Hope this is useful.
On Sep 30, 2022, at 3:25 PM, Marcus Poller h-openscad.org@crystaldown.de wrote:
Here's the context:
Cheers,
Marcus
<holztextur.svg><2022-09-11_probedrucke.scad><2022-09-25_probedruck_textur.scad>_______________________________________________
l=100;
//w=2;
h=80;
//eh=0.5;
//pseudo_3d=0.001;
intersection(){
square([l,h]);
height = 1;
resolution = .05;
translate([0,0,z])
offset(z)
> On Sep 30, 2022, at 3:25 PM, Marcus Poller <h-openscad.org@crystaldown.de> wrote:
> Here's the context:
> Cheers,
> Marcus
Sat, Oct 1, 2022 7:29 AM
I may be over-simplifying this, but if the SVG won't import cleanly, yet displays correctly in a web browser, just convert the SVG to a PNG or GIF (or take a screenshot of it) and use surface() to load it.
Here's the context:
Cheers,
Marcus
I may be over-simplifying this, but if the SVG won't import cleanly, yet displays correctly in a web browser, just convert the SVG to a PNG or GIF (or take a screenshot of it) and use `surface()` to load it.
- Revar
> Here's the context:
> Cheers,
> Marcus
MP
Marcus Poller
Sat, Oct 1, 2022 11:49 AM
Managementsummary: Dimensions too large.
I used inkscape to convert the SVG to PNG. The resulting PNG is
File name : holztextur.png
File size : 613284 Bytes
MIME type : image/png
Image size : 2628 x 2056
Then I tried to import the image as surface
$ cat 2022-10-01_surface.scad
surface(file="holztextur.png",center=true,convexity=10);
and I get
$ openscad 2022-10-01_surface.scad
Killed
I am just assuming that 2000 pixel is fundamentally oversized for OpenSCAD. Downsizing the image is fine.
I would like to discuss a sane dimension. The longest side in the final object will be 20cm; The plastic thread is very fine at 0.1mm; Oversimplyfying: Each possible plastic thread gets its own pixel. I would expect a (according to Nyquist–Shannon sampling theorem) sane dimension is at minimum 2 pixel per plastic thread. Maybe I am getting it totally wrong, I may sand the product after printing and nobody will ever notice.
More opinions on sane dimensions are welcome.
Previewing in lower dimensions is fine. Can I make OpenSCAD deal with the PNG dimensions for the final render and STL-export?
Cheers
Marcus
Here's the context:
Cheers,
Marcus
and I get
Killed
Cheers
Marcus
> > Here's the context:
> > Cheers,
> > Marcus
MP
Marcus Poller
Sat, Oct 1, 2022 12:37 PM
Managementsummary: Would anybody help me confirm this is not a programming bug?
and I get
Killed
I was curious whether this is an out-of-memory issue or something else. I ran in valgrind
$ valgrind openscad 2022-10-01_surface.scad
==6099== Command: openscad 2022-10-01_surface.scad
==6099==
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /usr/include/CGAL/Interval_nt.h
Line: 279
Explanation: Wrong rounding: did you forget the -frounding-math option if you use GCC (or -fp-model strict for Intel)?
==6099==
==6099== Process terminating with default action of signal 6 (SIGABRT)
I would like to confirm this does not happen with nightly and is dependent on my environment (Debian CGAL-Libraries, CPU, ...). But I recently failed to compile OpenSCAD, so I would like to ask anybody with nightly debug build: Can this behavior be confirmed?
Files for reproduction attached.
Cheers,
Marcus
> and I get
> Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
Michael Marx
Sat, Oct 1, 2022 12:58 PM
Not sure about the crash, but surface() is not good with larger sizes.
Vague recollection of memory issues.
Sent: Sat, 1 Oct 2022 22:37
Subject: [OpenSCAD] CGAL::Assertion (was: minkowski + mesh is not closed)
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
> To: OpenSCAD general discussion
> > and I get
> > Killed
> ==6099==
> Line: 279
> ==6099==
> Cheers,
> Marcus
Sat, Oct 1, 2022 1:07 PM
With the inherently high resolution your model has, I see only
one realistic chance but that's based on the experimental roof()
feature, so it's not possible for a script that needs to work
archived/unchanged for a long time.
It's still going to be slow when combining that with the other
parts of the design. But on a system with enough memory in might
at least produce a result at some point.
- Convert all curves in the SVG to lines at a resolution as
low as possible:
Extensions -> Modify Path -> Flatten Beziers
- Use roof() import("file.svg") which will directly add the
45° 3d structure
Michael Marx
Sat, Oct 1, 2022 1:13 PM
Yes, back in the day doing lithophanes. https://www.thingiverse.com/thing:78719/files
(wow almost a decade)
We lad to limit it ~100-200 x 100-200.
That was surface() with .dat (& 32 bit),
but I imagine the internals for .svg are not much better.
If you could answer the 'BTW' questions it may help re expectations.
Big and fine-detail tend to be bad.
Sent: Sat, 1 Oct 2022 22:58
Subject: [OpenSCAD] Re: CGAL::Assertion (was: minkowski + mesh is not closed)
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
> of
> > > and I get
> > > Killed
> valgrind
> > ==6099==
> > Line: 279
> > ==6099==
> OpenSCAD,
> > Cheers,
> > Marcus
> www.avg.com
Sat, Oct 1, 2022 1:20 PM
Line: 279
Like the explanations says, this is a check in CGAL that verifies
the execution supports floating point rounding math settings.
Valgrind does not support that, triggering this assertion. This
does not happen on the real (Intel) hardware.
It's possible to disable this check by compiling with a special
define CGAL_DISABLE_ROUNDING_MATH_CHECK - I don't remember if the
cmake setup has explicit support for this (it's always added for
WASM compile as that does not support rounding math either).
I have no idea what subtle issues the disabled check will have
on CGAL algorithms. It will make them run, but there might be
differences in point classification producing different results.
> Line: 279
Michael Marx
Sat, Oct 1, 2022 1:23 PM
I'm also wondering if some external processing could be relevant.
Sanjeev's thingi, below, may be relevant.
I have not looked at it in detail, but offloading to python (?) may be good for details. ?????
Dear All,
I have experimented with jupyter notebook to calculate points in space and then passing the same to
openscad for creating 3d shapes.
Found it to be quite interesting.
Wrote almost all the functions of openscad in jupyter notebook.
you can refer to the page below for few examples:
https://github.com/sprabhakar2006/openSCAD
you need to have some working knowledge of numpy and jupyter notebook for this to work.
Regards
Sanjeev
Sent: Sat, 1 Oct 2022 23:14
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
Dear All,
Regards
Sanjeev
> > of
> > > > and I get
> > > > Killed
> > valgrind
> > > ==6099==
> > > Line: 279
> use
> > > ==6099==
> > OpenSCAD,
> confirmed?
> > > Cheers,
> > > Marcus
> > www.avg.com
> www.avg.com
Sat, Oct 1, 2022 2:03 PM
BOSL2 has some new texture support that seems relevant to this, though I'm
not sure if it can really solve the problem. You'd have to compute the
surface somehow, and there might be issues with how the edges get created,
but it will create the shape as one polyhedron, so that should be about as
fast as is possible.
https://github.com/revarbat/BOSL2/wiki/skin.scad#function-texture
Note that the documentation for the texture stuff needs some work. You can
create your own texture using an array or VNF---you don't just have to use
the built-in ones.
Dear All,
this to work.
Regards
Sanjeev
and I get
Killed
==6099==
Line: 279
==6099==
Cheers,
Marcus
the built-in ones.
> Dear All,
> this to work.
> Regards
> Sanjeev
> closed)
> closed)
> closed)
> programming bug?
> take a screenshot
> > > of
> > > > > and I get
> > > > > Killed
> else. I ran in
> > > valgrind
> > > > ==6099==
> > > > Line: 279
> > use
> > > > ==6099==
> (SIGABRT)
> dependent on my
> to compile
> > > OpenSCAD,
> behavior be
> > confirmed?
> > > > Cheers,
> > > > Marcus
> > > www.avg.com
> > www.avg.com
> www.avg.com
BL
Bryan Lee
Sat, Oct 1, 2022 4:39 PM
I appologize, I haven't really been following this thread.
I guess @Marcus Poller:
By any chance are you trying to create terrain for Unity3D? I have
a workflow process for that.
Alternately, if you're just trying to recreate an svg curve in
OpenSCAD, do you have a way to extract points from that curve and create a
cube or cylinder or sphere [x1,y1,0] for each point on the curve,
possibly rotated to angle with the last and next points?
Thus Torsten Paul hast written on Sat, Oct 01, 2022 at 03:07:53PM +0200, and, according to prophecy, it shall come to pass that:
Sat, Oct 1, 2022 9:29 PM
I'm unsure about how big is reasonable using `surface()`. I have, however, converted 1024x1024 grayscale images to .scad file heightfields and rendered them using BOSL2's `heightfield()` and `cylindrical_heightfield()` modules in reasonable time. (link to img2scad.py script below.) I would think `surface()` would be faster, though.
https://raw.githubusercontent.com/revarbat/BOSL2/master/scripts/img2scad.py <https://raw.githubusercontent.com/revarbat/BOSL2/master/scripts/img2scad.py>
https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-heightfield <https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-heightfield>
https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-cylindrical_heightfield <https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-cylindrical_heightfield>
- Revar
MP
Marcus Poller
Sat, Oct 1, 2022 10:28 PM
l=100;
//w=2;
h=80;
//eh=0.5;
//pseudo_3d=0.001;
intersection(){
square([l,h]);
height = 1;
resolution = .05;
translate([0,0,z])
offset(z)
Thank you for taking your time and writing this approach into code!
I had varying results depending on the choosen resolution. It's very easy to crash OpenSCAD (possibly a starvation of RAM) and the performance benefit will be gone when I render several textures the same way.
I will keep playing with it and give the mailinglist an update in a few days. The roof()-function has been proposed as an alternative.
Thank you once more!
Marcus
Here's the context:
Cheers,
Marcus
Hi Hugo,
> l=100;
> //w=2;
> h=80;
> //eh=0.5;
> //pseudo_3d=0.001;
> intersection(){
> square([l,h]);
> height = 1;
> resolution = .05;
> translate([0,0,z])
> offset(z)
Marcus
> > Here's the context:
> > Cheers,
> > Marcus
MP
Marcus Poller
Sat, Oct 1, 2022 10:47 PM
190mm X 110 mm X 60 mm for the bottom, about the same size for the lid.
My personal perception is: The deception of wood depends an the amount of details. I would like to go sub-millimeter in line width.
I attached a picture of the current prototype. I am unhappy with it, because the annual rings are not visible all over the surface. I think some more depth would provide more shadow and enhance the deception. I am also thinking about painting the piece. Any elevated fine line will allow for more paint to stick, so any continous fine line would produce more shade. I am further thinking abound sanding the piece, but I guess that would require further elevation of the annual rings.
I haven't thought about yet. I was under the impression that any shape can be split into a series of surface triangles, that a graphics card can handle a million triangles per second. I just did not see the amount of calculation spent.
union(){
cube([l,w,h]);
rotate([90,0,0])
Yeah, that's great. I'm doing just that
module myminkowski(preview=true){
if(preview) {
linear_extrude(extrude_height) children(0);
} else {
minkowski() children();
That solves my preview performance. :-)
Once I go from preview to render, I still get those error messages. I will need to fix them.
Cheers,
Marcus
> union(){
> cube([l,w,h]);
> rotate([90,0,0])
if(preview) {
} else {
Cheers,
Marcus
> > why.
> > Here's the context:
> > x-y-plance)
> > Cheers,
> > Marcus
> www.avg.com
Michael Marx
Sun, Oct 2, 2022 12:28 AM
them.
If they are repeatable & you can delete or comment out any extraneous code,
post them & I'll have a look. (and give me an expectation of how long it runs for)
Likewise any crashes, it is better if we can catch whatever causes them.
> them.
Sun, Oct 2, 2022 4:20 AM
I am not a strong enough 3D geometry guy to be sure, but I think that
what graphics cards do is linear on the number of triangles, where what
an actual render does is quadratic on the number of triangles.
When you union two things, a graphics card just has to figure out what
pixel is in front. It doesn't have to figure out that two objects
overlap and so the now-internal surfaces need to be eliminated, new
edges calculated, et cetera.
I think this is why OpenSCAD preview is so much faster than render.
Sun, Oct 2, 2022 8:36 AM
I think you can make it near-linear if you use a fractal coordinate
system so that you can quickly eliminate most that will NOT intersect.
pixel is in front.
This is easy: every pixel of your object (even the internal and
"backside" ones!) is transformed onto XY of your screen. The
transformation also gives "some sort" of a Z which can be ignored for
where to draw that pixel. However, even though it is not really
"distance-to-viewpoint" or anything else physical, the resulting Z
value is monotonic. i.e. for objects/pixels further away it is always
larger. So the trick is to draw and fill in ALL triangles, but once
you get to a pixel, you only draw the pixel if your current Z-value is
less. And when you draw a pizel of course you update the z-value for
that pixel.
> pixel is in front.
that pixel.
AG
andrew goh
Mon, Oct 3, 2022 3:27 AM
Hi All, Admins,
I'm just thinking aloud. Can the discussions be on
https://forum.openscad.org/
rather than here in a mailing list?
As the topics are rather varied, a web based forum is a more appropriate
format than do this mailing list.
'mailing list integration' may after all not be necessary, i.e. the
forum and this mailing list can go separate ways.
Thanks,
Andrew
Hi All, Admins,
Thanks,
Andrew
Michael Marx
Mon, Oct 3, 2022 4:13 AM
Andrew,
Short answer, as I'm leaving in 30 seconds, no, that forum is dead.
Long answer a bit later today.
Sent: Mon, 3 Oct 2022 14:28
Subject: [OpenSCAD] Forum
Hi All, Admins,
Thanks,
Andrew
Andrew,
> From: andrew goh [mailto:gohandrew@yahoo.com]
> Hi All, Admins,
> Thanks,
> Andrew
Michael Marx
Mon, Oct 3, 2022 8:24 AM
Sent: Mon, 3 Oct 2022 15:14
Subject: [OpenSCAD] Re: Forum
Andrew,
Hi All, Admins,
Thanks,
Andrew
Make that tomorrow...
> Andrew,
> MichaelAtOz
> > Hi All, Admins,
> > Thanks,
> > Andrew
> www.avg.com
MP
Marcus Poller
Mon, Oct 3, 2022 11:32 AM
45° 3d structure
That's been a failure. The flattened structure does not roof(). It does import and display, but as soon as I use roof(), it disappears.
Reproduction:
Inkscape 1.0.2: Select Image, Extensions -> Modify Path -> Flatten Beziers -> Value 50 -> Apply, Save
OpenSCAD 2022.09.20.ai12175: I had to enable roof in Edit->Preferences->Features->Root->tick_the_box
I attached SVGs and Code to reproduce.
I understand that the idea of converting the SVG into something more edgy is to reduce detail and therefore speed up preview.
I will port the idea to my existing models and compare its rendering time.
Flattening could be a nice improvement over other ideas I got from this mailinglist
module wooden_texture(preview=true){
render()
if( preview) {
linear_extrude(1,convexity=10) import("texture_flatten.svg);
} else {
minkowski(){
import("texture_full_detail.svg");
cylinder(r1=1,r2=0,h=1);
> 45° 3d structure
Reproduction:
render()
if( preview) {
} else {
minkowski(){
