Re: [OpenSCAD] Beginner help?
K
kintel
Wed, Feb 11, 2015 4:03 AM
You got it almost right:
linear_extrude(height = 300, twist = -360) translate([0, 10, 0]) circle(r =
1);
You don't want to center, since a centered linear extrude centers the entire
resulting 3D object in the origin. Apart from that, you only got the X and Y
of the initial translation mixed up, and the twist inverted (the twist
direction is not very logic I know)
PS! Look up the % and # operators. They are good for debugging such things.
View this message in context: http://forum.openscad.org/Beginner-help-tp11588p11589.html
You got it almost right: linear_extrude(height = 300, twist = -360) translate([0, 10, 0]) circle(r = 1); You don't want to center, since a centered linear extrude centers the entire resulting 3D object in the origin. Apart from that, you only got the X and Y of the initial translation mixed up, and the twist inverted (the twist direction is not very logic I know) PS! Look up the % and # operators. They are good for debugging such things. -- View this message in context: http://forum.openscad.org/Beginner-help-tp11588p11589.html Sent from the OpenSCAD mailing list archive at Nabble.com.
