My idea was not 3d printing the mold, but to machine the mold, that to
from high density steel material.
I am also not sure right now whether it is possible to get the machining
codes from an stl file.
During the process, I have learnt that it is possible to extract the mould
design from the part design in openscad. Though some more work needs to be
done to make it simpler
On Wed, 8 Mar, 2023, 1:02 am andrew goh via Discuss, <
Cc:
Bcc:
Date: Wed, 8 Mar 2023 03:31:47 +0800
Subject: [OpenSCAD] Re: Surface extraction - 3d printed molds
I've been thinking about 3d printing molds, say for polyurethane foam
casting.
I never quite put in the effort to do it.
I'm a novice in this.
I'd seem making 3d printed molds may be difficult as it is after all
rather soft materials, and that the expanding foam may expand so much the
mold could deform.
And that it requires a mold release, which i'd guess things that could be
tried could include shoe polish, baby powder, silicone oil (spray) etc,
silicone spray is actually used in metal molds i'd guess.
that is actually the lesser of problems, but that i'm not sure how toxic
is the polyurethane materials after all MDI etc if it would necessitate
using a proper VOC respirator etc, quite expensive but may after all be
necessary. expanding foams are quite easy to buy say from construction
products businesses, e.g. for foam insulation etc.
no need for the speciality types, just that handling the chemicals I'd
guess would need quite some precautions, VOC respirator etc.
On 05/03/2023 20:37, Sanjeev Prabhakar wrote:
Wow
Great to hear that
I have almost no experience of sand moulding, but we have made hundreds of
die casting moulds if not thousands.
In Engineering we have designers who mainly work on expensive softwares
like nx , Catia, creo, autocad etc.
It's very easy to make mould designs in these softwares, although I don't
work on that.
Many times I show our designers that openscad could be an alternative for
some type of designs.
But it seems they don't take me seriously and it's fine.
I like openscad although till date almost no professional work is done by
me on this, but I intend to make few functions which could be useful for
professional use.
On Sun, 5 Mar, 2023, 2:20 pm nop head, nop.head@gmail.com wrote:
My father was a pattern maker, long before 3D printing was a thing. He
made the patterns out of wood manually and had a set of rulers that were
out by the contraction ratios of different metals, which I still have.
On Sun, 5 Mar 2023 at 08:30, Sanjeev Prabhakar sprabhakar2006@gmail.com
That's a good idea, will give it a try in our next project.
On Sun, 5 Mar, 2023, 12:59 am nop head, nop.head@gmail.com wrote:
You can print a PLA pattern that is the same as the desired final
object but expanded by the amount the metal contracts and then build a sand
or plaster mould around it.
PLA can be burned out just as easily as wax.
On Sat, 4 Mar 2023 at 19:24, Steve Schlaifer steve@jetcafe.org wrote:
You could use this as the start of a lost wax process.
Steve Schlaifer
On Mar 3, 2023 at 4:07 AM -0800, Sanjeev Prabhakar <
sprabhakar2006@gmail.com>, wrote:
Guenther
I am not planning to do anything with this.
I was just checking if dies can be modelled with this approach.
In the process I found it is very complex right now to do something
like this. But lot of learning from this challenging work.
On Fri, 3 Mar, 2023, 3:38 pm Guenther Sohler, <
guenther.sohler@gmail.com> wrote:
it looks very nice!
Whats your workflow like?
apparently you cannot pour molten metal onto the plastic
On Thu, Mar 2, 2023 at 6:45 PM Sanjeev Prabhakar <
bottom mould completely done in openscad.
<Screenshot 2023-03-02 at 11.10.21 PM.png>
From: andrew goh via Discuss discuss@lists.openscad.org
Cc: andrew goh gohandrew@yahoo.com
Bcc:
I use a program called MeshCAM to convert STL files into gCode for my
CNC machine. It is only a 3-axis CNC, so no undercuts, but it does a
credible job of creating surfaces from STL files.
machining codes from an stl file.
mould design from the part design in openscad. Though some more work
needs to be done to make it simpler
Cc:
Bcc:
foam casting.
all rather soft materials, and that the expanding foam may expand
so much the mold could deform.
could be tried could include shoe polish, baby powder, silicone
oil (spray) etc, silicone spray is actually used in metal molds
i'd guess.
toxic is the polyurethane materials after all MDI etc if it would
necessitate using a proper VOC respirator etc, quite expensive but
may after all be necessary. expanding foams are quite easy to buy
say from construction products businesses, e.g. for foam
insulation etc.
I'd guess would need quite some precautions, VOC respirator etc.
Wow
Great to hear that
hundreds of die casting moulds if not thousands.
softwares like nx , Catia, creo, autocad etc.
I don't work on that.
alternative for some type of designs.
done by me on this, but I intend to make few functions which
could be useful for professional use.
thing. He made the patterns out of wood manually and had a
set of rulers that were out by the contraction ratios of
desired final object but expanded by the amount the
metal contracts and then build a sand or plaster
mould around it.
process.
Steve Schlaifer
Prabhakar <sprabhakar2006@gmail.com>, wrote:
Guenther
this approach.
now to do something like this. But lot of
<guenther.sohler@gmail.com> wrote:
it looks very nice!
the plastic
From: andrew goh via Discuss <discuss@lists.openscad.org>
Cc: andrew goh <gohandrew@yahoo.com>
Bcc:
The idea about 3d printing molds is attractive.
As if it is feasible, possible it significantly change the costs of low
run molding and that new molds can be created by simply printing.
The trouble is in the present state of art, this doesn't seem quite
feasible yet.
Plastic is soft and molding materials is expensive and most importantly
worse toxic e.g. polyurethane resin. While the lower cost injection
molding is practically not feasible with 3d printed molds except for a
few cases, the mold plastics itself will injection molding. Actually, 3d
printed molds compares fairly well to silicone molds as that both are
soft materials, with a difference that silicone molds are non-stick, at
least for some materials e.g. polyurethane etc. And that the art of
making silicone molds using silicone pours are fairly well developed,
just that silicone is expensive.
while a 3d printed ABS, PLA plastic cost much less than a same silicone
volume, especially where infill density is reduced.
it probably reduce a $100 mold to a $1 mold.
<discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
From: andrew goh <gohandrew@yahoo.com <mailto:gohandrew@yahoo.com>>
To: discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>
Cc:
Bcc:
foam casting.
i'd guess.
insulation etc.
Wow
Great to hear that
<sprabhakar2006@gmail.com <mailto:sprabhakar2006@gmail.com>>
mould around it.
process.
Steve Schlaifer
<mailto:sprabhakar2006@gmail.com>>, wrote:
Guenther
this approach.
<mailto:guenther.sohler@gmail.com>> wrote:
it looks very nice!
the plastic
To unsubscribe send an email todiscuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
<mailto:discuss@lists.openscad.org>>
Cc: andrew goh <gohandrew@yahoo.com <mailto:gohandrew@yahoo.com>>
Bcc:
