I have the following code, which works well. And does what I want.
What I am having trouble with is, I want the 3rd cylinder to be not only
pointed up from the bottom, as it is now, but I also want to do it pointed
down from the top side. Leaving both sides cylinders "chamfered". So what I
need is a 4th cylinder that points downward from the top.
I can't seem to be able to do this. Can someone help me? Thanks.
$fn=60;
cylinder(h = 8, r = 44);
for (i = [1:16]) {
rotate(i * 360/16, [0,0,1]) translate([0, 35, -2]) cylinder(h = 12, r =
2);
rotate(i * 360/16, [0,0,1]) translate([0, 35, -2]) cylinder(h = 12, r1 =
5, r2=0);
View this message in context: http://forum.openscad.org/mirroring-a-chamfered-cylinder-in-this-part-how-to-tp11964.html
$fn=60;
5, r2=0);
adding:
= 0, r2=5);
inside the loop seems to work, or have I misunderstood - swapping the
values of r1 and r2 and setting the z translation so that the top of the
chamfer is 2mm above the big disc (which, coincidentally, is the same as
for the bottom chamfers).
Ian
Stand firm for what you believe in, until and unless logic and experience
prove you wrong. Remember: when the emperor looks naked, the emperor is
naked, the truth and a lie are not "sort-of the same thing" and there is
no aspect, no facet, no moment of life that can't be improved with pizza.
-Daria Morgendorffer
Ian,
I never thought of what you did, I was trying to use mirror() but it just
didn't seem to work.
Your code made me do a head-bang, for its simplicity!
Thanks a bunch!
Jerry
View this message in context: http://forum.openscad.org/mirroring-a-chamfered-cylinder-in-this-part-how-to-tp11964p11967.html
On 11 March 2015 at 17:08, jdawgaz jdawgaz@gmail.com wrote:
Ian,
Thanks a bunch!
You're welcome. I'm nothing if not simplistic. Sometimes excessively so ;)
Ian
