Callable function arguments?
D
DarioPellegrini
Wed, Aug 21, 2019 7:54 PM
Hi, any project which requires to operate on mathematical functions (root
finding, minimization, integration,  here is an example
https://www.thingiverse.com/thing:3179773  ) would greatly benefit from
being able to pass a callable as the argument of a function.
The neatest syntax that I can envisage is something like this:
function g(h,i) = h(i);
function f(i) = i;
echo(g(f,3));
however it could also mimic the module's children pattern:
function g(i) = children[0](i);
function f(i) = i;
echo( g(3) { f; } );
Right now I am circumventing this limitation by pre-defining the internal
function:
function f(i) = i;
function g(i) = f(i);
but this requires a copy of g (which is large, complicated and calls f many
times) for any possible f:
function f1(i) = i;
function g1(i) = f1(i);
function f2(i) = i;
function g2(i) = f2(i);
and, even worse, this approach prevents the possibility of packing g into a
library.
Is anything similar possible/practical/planned/wip within the OpenSCAD
ecosystem?
Hi, any project which requires to operate on mathematical functions (root finding, minimization, integration, here is an example <https://www.thingiverse.com/thing:3179773> ) would greatly benefit from being able to pass a callable as the argument of a function. The neatest syntax that I can envisage is something like this: function g(h,i) = h(i); function f(i) = i; echo(g(f,3)); however it could also mimic the module's children pattern: function g(i) = children[0](i); function f(i) = i; echo( g(3) { f; } ); Right now I am circumventing this limitation by pre-defining the internal function: function f(i) = i; function g(i) = f(i); but this requires a copy of g (which is large, complicated and calls f many times) for any possible f: function f1(i) = i; function g1(i) = f1(i); function f2(i) = i; function g2(i) = f2(i); ... and, even worse, this approach prevents the possibility of packing g into a library. Is anything similar possible/practical/planned/wip within the OpenSCAD ecosystem? -- Sent from: http://forum.openscad.org/
AC
A. Craig West
Wed, Aug 21, 2019 7:57 PM
I would love to have some sort of function pointer support in
openSCAD, it would make a lot of tasks much easier to implement...
On Wed, Aug 21, 2019 at 3:51 PM DarioPellegrini
 function f(i) = i;
 echo(g(f,3));
 function f(i) = i;
function:
 function f(i) = i;
 function f1(i) = i;
 function f2(i) = i;
library.
ecosystem?
I would love to have some sort of function pointer support in openSCAD, it would make a lot of tasks much easier to implement... On Wed, Aug 21, 2019 at 3:51 PM DarioPellegrini <pellegrini.dario@gmail.com> wrote: > > Hi, any project which requires to operate on mathematical functions (root > finding, minimization, integration, here is an example > <https://www.thingiverse.com/thing:3179773> ) would greatly benefit from > being able to pass a callable as the argument of a function. > > The neatest syntax that I can envisage is something like this: > > function g(h,i) = h(i); > function f(i) = i; > > echo(g(f,3)); > > however it could also mimic the module's children pattern: > > function g(i) = children[0](i); > function f(i) = i; > > echo( g(3) { f; } ); > > Right now I am circumventing this limitation by pre-defining the internal > function: > > function f(i) = i; > function g(i) = f(i); > > but this requires a copy of g (which is large, complicated and calls f many > times) for any possible f: > > function f1(i) = i; > function g1(i) = f1(i); > > function f2(i) = i; > function g2(i) = f2(i); > > ... > > and, even worse, this approach prevents the possibility of packing g into a > library. > > Is anything similar possible/practical/planned/wip within the OpenSCAD > ecosystem? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
jschobben
Wed, Aug 21, 2019 11:45 PM
I too would like such a feature! I think there have been a few proposals for
that already.
But, at the risk of derailing the discussion: there are some sneaky tricks
to make it work right now.
Here's one I sometimes use. Basically, the idea is to abuse the mechanics of
include/use, and put your code in multiple .scad files.
Without further ado, here's an example for sorting with a custom compare
function:
--- sort.scad
// Big and complicated function, where you want to use a "function pointer".
// Shamelessly based on quicksort example from the wiki, except that
"compare" is added.
// Note how the function "compare" is undefined here; it's your function
pointer variable.
// input : list of numbers
// output : sorted list of numbers
function quicksort(arr) = !(len(arr)>0) ? [] : let(
pivot  = arr[floor(len(arr)/2)],
lesser  = [ for (y = arr) if (compare(y, pivot) < 0) y ],
equal  = [ for (y = arr) if (compare(y, pivot) == 0) y ],
greater = [ for (y = arr) if (compare(y, pivot) > 0) y ]
) concat(
quicksort(lesser), equal, quicksort(greater)
--- sort_length.scad
// Define a custom comparator, and a version of quicksort that sorts on
"length".
include <sort.scad>
function compare(a, b) = len(a) - len(b);
function quicksort_length(v) = quicksort(v);
--- sort_reverse.scad
// Another quicksort variant, this time sorting backwards
include <sort.scad>
function compare(a, b) = a < b ? 1 : a > b ? -1 : 0;
function quicksort_reverse(v) = quicksort(v);
--- main.scad
use <sort_length.scad>
use <sort_reverse.scad>
data = ["cheese", "kaas", "fromage"];
// sorted on string length: ["kaas", "cheese", "fromage"]
echo(sort_len=quicksort_length(data));
// reverse-sorted on natural comparison: ["kaas", "fromage", "cheese"]
echo(sort_rev=quicksort_reverse(data));
It's a nasty hack, but hey, it works :)
Alternatively, if you want all of it in a single .scad file, you probably
have a fixed amount of uses for "compare" anyway. In that case you might get
away with having a single "compare" function that takes an extra (numerical)
parameter to decide what behavior to use, and pass that parameter on via the
quicksort call.
I too would like such a feature! I think there have been a few proposals for that already. But, at the risk of derailing the discussion: there are some sneaky tricks to make it work right now. Here's one I sometimes use. Basically, the idea is to abuse the mechanics of include/use, and put your code in multiple .scad files. Without further ado, here's an example for sorting with a custom compare function: --- sort.scad // Big and complicated function, where you want to use a "function pointer". // Shamelessly based on quicksort example from the wiki, except that "compare" is added. // Note how the function "compare" is undefined here; it's your function pointer variable. // input : list of numbers // output : sorted list of numbers function quicksort(arr) = !(len(arr)>0) ? [] : let( pivot = arr[floor(len(arr)/2)], lesser = [ for (y = arr) if (compare(y, pivot) < 0) y ], equal = [ for (y = arr) if (compare(y, pivot) == 0) y ], greater = [ for (y = arr) if (compare(y, pivot) > 0) y ] ) concat( quicksort(lesser), equal, quicksort(greater) ); --- sort_length.scad // Define a custom comparator, and a version of quicksort that sorts on "length". include <sort.scad> function compare(a, b) = len(a) - len(b); function quicksort_length(v) = quicksort(v); --- sort_reverse.scad // Another quicksort variant, this time sorting backwards include <sort.scad> function compare(a, b) = a < b ? 1 : a > b ? -1 : 0; function quicksort_reverse(v) = quicksort(v); --- main.scad use <sort_length.scad> use <sort_reverse.scad> data = ["cheese", "kaas", "fromage"]; // sorted on string length: ["kaas", "cheese", "fromage"] echo(sort_len=quicksort_length(data)); // reverse-sorted on natural comparison: ["kaas", "fromage", "cheese"] echo(sort_rev=quicksort_reverse(data)); It's a nasty hack, but hey, it works :) Alternatively, if you want all of it in a single .scad file, you probably have a fixed amount of uses for "compare" anyway. In that case you might get away with having a single "compare" function that takes an extra (numerical) parameter to decide what behavior to use, and pass that parameter on via the quicksort call. -- Sent from: http://forum.openscad.org/
D
DarioPellegrini
Thu, Aug 22, 2019 2:46 PM
files.
I have the feeling that this could be accomplished in a single scad file
just by the preprocessor alone, even without the need of touching the
parser.
Maybe one can help the preprocessor by introducing some syntax, eg prefixing
callable arguments with a special char or keyword, so that the whole tasks
boils down to some text replacement.
function g(h, i) = h(i);
function f(i) = i;
g(callable h=f, 3);
The last line is translated to g_f(3) where g_f is defined by the
preprocessor dropping the callable argument h and replacing h with f in the
body of g.
Of course staying at the preprocessor level is still quite a hack, and one
does not get any useful debug info. But I am not a computer scientist or
software engineer, so I leave the ball to whoever feels like scoring the
goal or serving an assist!
jschobben wrote > abuse the mechanics of include/use, and put your code in multiple .scad > files. I have the feeling that this could be accomplished in a single scad file just by the preprocessor alone, even without the need of touching the parser. Maybe one can help the preprocessor by introducing some syntax, eg prefixing callable arguments with a special char or keyword, so that the whole tasks boils down to some text replacement. function g(h, i) = h(i); function f(i) = i; g(callable h=f, 3); The last line is translated to g_f(3) where g_f is defined by the preprocessor dropping the callable argument h and replacing h with f in the body of g. Of course staying at the preprocessor level is still quite a hack, and one does not get any useful debug info. But I am not a computer scientist or software engineer, so I leave the ball to whoever feels like scoring the goal or serving an assist! -- Sent from: http://forum.openscad.org/
CA
Thu, Aug 22, 2019 9:03 PM
You need something like this
https://gist.github.com/arnholm/7061458777913e5795585eee46fcb664
On 21.08.2019 21:57, A. Craig West wrote: > I would love to have some sort of function pointer support in > openSCAD, it would make a lot of tasks much easier to implement... You need something like this https://gist.github.com/arnholm/7061458777913e5795585eee46fcb664 Carsten Arnholm
Thu, Aug 22, 2019 9:22 PM
I couldn't figure out exactly how that syntax works.  For OpenSCAD, the
original poster's syntax wouldn't work because f can be a function, module
or variable, so there's no way to know what g(f) means if function pointers
can be passed.  So some kind of syntax is needed to clarify.  MATLAB, for
example, uses @ to mark function pointers, so @sin becomes a function
pointer to the sin function.  There's a second syntactic question having to
do with the function definition.  If you write
function g(f,x) = ....
then what is f?  Is it a function or a variable?  The two things have
different name spaces, so you have to decide which one it is.  Or if it's a
variable that contains a function then you need a way to call it.  I'm sure
it's been talked to death in previous posts.  And I agree it would be a
great feature.  Though if I were to prioritize features I'd put the ability
to avoid doing unions and to pass children un-unioned to a submodule first
in line before function pointers.
cacb wrote > On 21.08.2019 21:57, A. Craig West wrote: >> I would love to have some sort of function pointer support in >> openSCAD, it would make a lot of tasks much easier to implement... > > You need something like this > https://gist.github.com/arnholm/7061458777913e5795585eee46fcb664 I couldn't figure out exactly how that syntax works. For OpenSCAD, the original poster's syntax wouldn't work because f can be a function, module or variable, so there's no way to know what g(f) means if function pointers can be passed. So some kind of syntax is needed to clarify. MATLAB, for example, uses @ to mark function pointers, so @sin becomes a function pointer to the sin function. There's a second syntactic question having to do with the function definition. If you write function g(f,x) = .... then what is f? Is it a function or a variable? The two things have different name spaces, so you have to decide which one it is. Or if it's a variable that contains a function then you need a way to call it. I'm sure it's been talked to death in previous posts. And I agree it would be a great feature. Though if I were to prioritize features I'd put the ability to avoid doing unions and to pass children un-unioned to a submodule first in line before function pointers. -- Sent from: http://forum.openscad.org/
Thu, Aug 22, 2019 9:27 PM
A probably better base for the discussion is that one
https://github.com/doug-moen/openscad2/blob/master/rfc/Functions.md
as it's considering the existing OpenSCAD syntax.
A probably better base for the discussion is that one https://github.com/doug-moen/openscad2/blob/master/rfc/Functions.md as it's considering the existing OpenSCAD syntax. ciao, Torsten.
Doug Moen
Thu, Aug 22, 2019 10:23 PM
Okay, I justed updated the OpenSCAD2 project to show the current status.
The original OpenSCAD2 proposal was not popular with some members of the community, and it had some problems with backward compatibility.
Back in 2017, I starting writing an updated proposal, "OpenSCAD bis", which is simpler, and has a lower risk of breaking backwards compatibility. For the record, the document is here: https://github.com/doug-moen/openscad2/blob/master/OpenSCADbis.md
Doug Moen.
Okay, I justed updated the OpenSCAD2 project to show the current status. The original OpenSCAD2 proposal was not popular with some members of the community, and it had some problems with backward compatibility. Back in 2017, I starting writing an updated proposal, "OpenSCAD bis", which is simpler, and has a lower risk of breaking backwards compatibility. For the record, the document is here: https://github.com/doug-moen/openscad2/blob/master/OpenSCADbis.md Doug Moen. On Thu, Aug 22, 2019, at 5:28 PM, Torsten Paul wrote: > A probably better base for the discussion is that one > > https://github.com/doug-moen/openscad2/blob/master/rfc/Functions.md > > as it's considering the existing OpenSCAD syntax. > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
arnholm@arnholm.org
Fri, Aug 23, 2019 6:23 AM
It is not that complicated. In any language, you can have variables that
represent data, such as integers and doubles. In some languages you can
have variables that represent functions. Instead of assigning data to
such variables, you assign functions to them. The AngelCAD statement
funcdef double CALLBACK(int i);
means to declare a function pointer type. In this case the type name is
CALLBACK, representing the signature of a function that takes an integer
argument and returns a double value. So if you have an actual function
with the same signature
double myfunc(int i) { return i*i; }
you can do
CALLBACK@ f = myfunc;
The @ means it is a handle type (i.e. f is a pointer to myfunc). One can
use the variable f later, for example
double value = f(5);
The result will obviously be 25.0
On 2019-08-22 23:22, adrianv wrote: > cacb wrote >> On 21.08.2019 21:57, A. Craig West wrote: >>> I would love to have some sort of function pointer support in >>> openSCAD, it would make a lot of tasks much easier to implement... >> >> You need something like this >> https://gist.github.com/arnholm/7061458777913e5795585eee46fcb664 > > I couldn't figure out exactly how that syntax works. It is not that complicated. In any language, you can have variables that represent data, such as integers and doubles. In some languages you can have variables that represent functions. Instead of assigning data to such variables, you assign functions to them. The AngelCAD statement funcdef double CALLBACK(int i); means to declare a function pointer type. In this case the type name is CALLBACK, representing the signature of a function that takes an integer argument and returns a double value. So if you have an actual function with the same signature double myfunc(int i) { return i*i; } you can do CALLBACK@ f = myfunc; The @ means it is a handle type (i.e. f is a pointer to myfunc). One can use the variable f later, for example double value = f(5); The result will obviously be 25.0 Carsten Arnholm
Fri, Aug 23, 2019 7:13 AM
I think OpenSCAD bis would still have compatibility issues if you put built
in modules into the function and variable namespaces. Keeping the
namespaces separate for compatibility is pointless if you put built in
things in more than one namespace.
For example I have function versions of rotate, translate, etc, that work
on matrices.
Doug Moen.
I think OpenSCAD bis would still have compatibility issues if you put built in modules into the function and variable namespaces. Keeping the namespaces separate for compatibility is pointless if you put built in things in more than one namespace. For example I have function versions of rotate, translate, etc, that work on matrices. On Thu, 22 Aug 2019 at 23:25, Doug Moen <doug@moens.org> wrote: > Okay, I justed updated the OpenSCAD2 project to show the current status. > > The original OpenSCAD2 proposal was not popular with some members of the > community, and it had some problems with backward compatibility. > > Back in 2017, I starting writing an updated proposal, "OpenSCAD bis", > which is simpler, and has a lower risk of breaking backwards compatibility. > For the record, the document is here: > https://github.com/doug-moen/openscad2/blob/master/OpenSCADbis.md > > Doug Moen. > > On Thu, Aug 22, 2019, at 5:28 PM, Torsten Paul wrote: > > A probably better base for the discussion is that one > > > > https://github.com/doug-moen/openscad2/blob/master/rfc/Functions.md > > > > as it's considering the existing OpenSCAD syntax. > > > > ciao, > > Torsten. > > > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
