As MichelatOZ pointed out, somehow my eye did not catch the”;” after the
closing brace of the resize.
Yes, the form is something like that you nophead provided, and difference()
is working as it should. I made a little modification to the module, now it
looks like this:
// Module of the airdirector
module airdirector(){
translate([-2.3,0,0])
rotate([0,90,0])
rotate_extrude(convexity=10)
translate([aidelpsl/2-1.8,0,0])
rotate(45)
resize([aidelpsl/3,aidelpss/3])
circle(r=(aidelpsl-aidelpss));
circle(r=(aidelpsl-aidelpss-10*aidthick));
Thanks, again,
Infocean
Also note that you need convexity= in render().
If you try this (to see inside) without it you will see why.
// Draw the airdirectors
color("Teal",0.5)
render(convexity=10)
translate([pairdirector1,0,0])
airdirector();
//color("Teal",0.5)
translate([pairdirector2,0,0])
mirror([1,0,0])
airdirector();
cube(40);
From: infocean via Discuss [mailto:discuss@lists.openscad.org]
Sent: Fri, 19 Mar 2021 04:34
Cc: infocean
Subject: [OpenSCAD] Re: I do not know why difference() does not work for me.
As MichelatOZ pointed out, somehow my eye did not catch the”;” after the closing brace of the resize.
Yes, the form is something like that you nophead provided, and difference() is working as it should. I made a little modification to the module, now it looks like this:
rotate([0,90,0])
rotate(45)
Thanks, again,
Infocean
Sent from the OpenSCAD mailing http://forum.openscad.org/ list archive at Nabble.com.
Suggestion: use #cube so you'll see where it is.
color("Teal",0.5)
airdirector();
//color("Teal",0.5)
mirror([1,0,0])
airdirector();
cube(40);
Cc: infocean
for me.
rotate([0,90,0])
rotate(45)
at Nabble.com.
<#m_5990485673363810638_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
K1FZY (WA4TPW) SK 9/29/37-4/13/15
