Thu, Dec 16, 2021 11:33 AM
Theres what looks like a usefull involute gear generator that outputs in .dxf
format on thingiverse. Is there a conversion method?
Thank you.
Cheers, Gene Heskett.
Thank you.
- Louis D. Brandeis
Thu, Dec 16, 2021 12:01 PM
Import the DXF and linear extrude it?
.dxf
Thank you.
> .dxf
> Thank you.
> - Louis D. Brandeis
Thu, Dec 16, 2021 12:28 PM
The other option would be to use an actual OpenSCAD module
generating the gears.
Just one example:
https://github.com/revarbat/BOSL2/wiki/gears.scad
Thu, Dec 16, 2021 1:03 PM
Can I then modify it with scale, rotate, translate etc? That would be ideal
as a foundation for a new, very high ratio planetary drive. We are exploring
different ways to make a harmonic type drive but much shorter axially on the
emc list. Unforch, my printer is down and fedex is sitting on repair parts
from CZ. I got a notice late yesterday that due to logistics, it would NOT
arrive this Friday. But no new date was given. Grrrrrr.
One should treat the part cooling nozzle on a Prusa MK3S as expendable, the
close proximity to the hot block makes it very easily broken when removing it
for wrench access to re-tighten the nozzle, which WILL come loose and leak
eventually under the 240C temps of PETG. At a bit over $2 per, I bought a
dozen so I'd have them on hand along with a bag of the square nuts that mount
it. Other than that, and a titanium heat break, the Prusa MK3S is a Just Works
printer for roll after roll of PETG, I've fed it 8 rolls so far. And I have a
room full of other printers that can't survive 1/4 roll of PETG.
.dxf
Thank you.
Genes Web page http://geneslinuxbox.net:6309/gene
> > .dxf
> > Thank you.
> > - Louis D. Brandeis
- Louis D. Brandeis
Thu, Dec 16, 2021 1:30 PM
I have had problems with that part of my Prusa MK3S also, and always
keep a few spares printed and available.
Thu, Dec 16, 2021 2:04 PM
That is made of PC, which I don't have any of. I did buy a roll of PP but not
even magigoo-pp will make it stick to the Prusa bed, its loose by the time the
brim is half done.
Does anybody know the magic spell?
Thank you.
it for wrench access to re-tighten the nozzle, which WILL come loose and
leak eventually under the 240C temps of PETG. At a bit over $2 per, I
bought a dozen so I'd have them on hand along with a bag of the square
nuts that mount it. Other than that, and a titanium heat break, the Prusa
MK3S is a Just Works printer for roll after roll of PETG, I've fed it 8
rolls so far. And I have a room full of other printers that can't survive
1/4 roll of PETG.
brim is half done.
Thank you.
> > the
> > 1/4 roll of PETG.
- Louis D. Brandeis
Thu, Dec 16, 2021 2:13 PM
I believe that Prusa makes the parts out of PETG, and I use their PETG
to make the parts. I treat them as consumables.
brim is half done.
Thank you.
1/4 roll of PETG.
> brim is half done.
> Thank you.
>>> the
>>> 1/4 roll of PETG.
Thu, Dec 16, 2021 2:18 PM
To print PP you have to stick a sheet of adhesive backed PP film on the
bed. PP only sticks to itself.
The company I bought PP filament from sent PP film sheets with it.
brim is half done.
Thank you.
> Jon
> but not
> time the
> > brim is half done.
> > Thank you.
> >>> the
> removing
> and
> Prusa
> survive
> >>> 1/4 roll of PETG.
Thu, Dec 16, 2021 2:32 PM
I printed the Prusament Polycarbonate blend on a textured sheet with
glue stick. And my understanding is the glue stick was so I could get
the model off, not to get it to stay on. Had no problems at all with
adhesion. Nop head, I don't think polycarbonate and polypropylene
have at all similar properties. Note, however, that I thought the
nozzle on the MK3S was printed in ABS, not PC.
On Thu, Dec 16, 2021 at 9:19 AM nop head nop.head@gmail.com wrote:
To print PP you have to stick a sheet of adhesive backed PP film on the bed. PP only sticks to itself.
brim is half done.
Thank you.
1/4 roll of PETG.
>> Jon
>> > brim is half done.
>> > Thank you.
>> >>> the
>> >>> 1/4 roll of PETG.
Thu, Dec 16, 2021 2:54 PM
Yes, polypropylene and polycarbonate are completely different plastics. I
was replying to
I did buy a roll of PP but not even magigoo-pp will make it stick to the
Prusa bed, its loose by the time the brim is half done.
I print PC on glass with glue stick to make it stick. I think it is PETG
that needs it more for release as it can stick too well.
brim is half done.
Thank you.
was replying to
> >> Jon
> but not
> time the
> >> > brim is half done.
> >> > Thank you.
> expendable,
> >> >>> the
> removing
> loose and
> I
> square
> Prusa
> it 8
> survive
> >> >>> 1/4 roll of PETG.
