Could you try these two things?
View this message in context: http://forum.openscad.org/2015-3-crash-tp12110p12112.html
Here it is
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
c:\Program Files\OpenSCAD>openscad --info
OpenSCAD Version: 2015.03
System information: Windows 7 SP1 (v6.1.1.0) 2 CPUs 2.95 GB RAM
Compiler, build date: GCC "4.9.2" 64bit, Mar 10 2015
Boost version: 1_57
Eigen version: 3.2.2
CGAL version, kernels: 4.5, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck
OpenCSG version: OpenCSG 1.3.2
Qt version: 5.4.0
QScintilla version: 2.8.4
MingW build: MingW64
GLib version: 2.42.1
Application Path: c:/Program Files/OpenSCAD
Documents Path: C:\Users\Cat\Documents
Resource Path: c:/Program Files/OpenSCAD
User Library Path: C:/Users/Cat/Documents/OpenSCAD/libraries
User Config Path: C:\Users\Cat\AppData\Local/OpenSCAD
Backup Path: C:/Users/Cat/Documents/OpenSCAD/backups
OPENSCADPATH: <not set>
OpenSCAD library path:
c:/Program Files/OpenSCAD\libraries
OPENSCAD_FONT_PATH: <not set>
OpenSCAD font path:
Warning: Cannot create stencil buffer (GL_EXT_packed_depth_stencil not
supported
GLEW version: 1.11.0
OpenGL Version: 2.1.0 - Build 8.15.10.1855
GL Renderer: Mobile Intel(R) 4 Series Express Chipset Family
GL Vendor: Intel
RGBA(8888), depth(24), stencil(0)
GL_ARB_framebuffer_object: no
GL_EXT_framebuffer_object: yes
GL_EXT_packed_depth_stencil: no
GL context creator: WGL
PNG generator: lodepng
OS info: Microsoft(TM) Windows(TM) 6 1 7601 0x24bd944 amd64
Machine: 8664
OpenGL Program Link OK:
No errors.
note: this is a Dell Latitude e4300 with intel cpu not amd64
I suspect from the above that the afore mentioned log will be of no use. I
look at eventvwr.exe and found no mention of openscad.
I also suspect that this was not really a crash but exit with error.
View this message in context: http://forum.openscad.org/2015-3-crash-tp12110p12127.html
Thanks for the info.
I suspect that your GPU drivers are old. Could you try updating them and see
if that helps?
Intel is known for having low quality drivers, but they've been improving
lately.
View this message in context: http://forum.openscad.org/2015-3-crash-tp12110p12157.html
Updated all drivers. It now works fine. Thank you for the help.
View this message in context: http://forum.openscad.org/2015-3-crash-tp12110p12259.html
