Hi i'm working on a project and i go the polyhedron part done but what i want
to do next i would need to add a cube but when i add one the polyhedron goes
away. he is my code.
sry for the spelling in the code i suck at it lol.
//handle gaourd
handle2 = -1;
handle1 = 6;
handle = -2;
//where the hand goes.
leagth= -30;
leagth1= -2;
polyhedron(
points=[
[0,0,0], //0
[5,0,0], //1
[5,100,0], //2
[0,100,0], //3
[0,0,10], //4
[5,0,10], //5
[5,100,10], //6
[0,100,10], //7
[2.5,100,20],//8
[2.5,0,20],//9
[2.5,120,4.5],//10
[2.5,100,-10],//11
[2.5,0,-10], //12
[handle2,0,25], //13
[handle1,0,25], //14
[handle2,0,-15],//15
[handle1,0,-15],//16
[handle2,handle,-15],//17
[handle1,handle,-15],//18
[handle2,handle,25], //19
[handle1,handle,25],//20
[.5,leagth,5],//21
[4.5,leagth,5],//22
[3.5,leagth,10],//23
[1.5,leagth,10],//24
[1.5,leagth,0],//25
[3.5,leagth,0],//26
[.5,leagth1,5],//27
[4.5,leagth1,5],//28
[3.5,leagth1,10],//29
[1.5,leagth1,10],//30
[1.5,leagth1,0],//31
[3.5,leagth1,0]],//32
faces = [
[0,1,2,3], //bottom
[0,3,7,4], //left
[1,5,6,2], //right
[1,0,4,5], //front
[3,2,6,7], //back
[4,7,8,9], //left blade
[5,9,8,6], //right blade
[4,9,5], // back 2
[7,8,6], //front 2
[3,10,7], //piont left
[8,7,10], //tip
[10,2,6],
[10,6,8],
[3,2,10], //tip bottom
[12,11,3,0],//bottom blades
[1,2,11,12],//^^
[0,1,12], //back bottom
[10,11,2],
[3,11,10],//ip bottom left
[14,13,15,16,],//handle graud
[18,17,19,20],//handle graud
[13,14,20,19], //handle faces
[17,18,16,15],
[18,20,14,16],
[15,13,19,17],
//handle//
[21,24,23,22,26,25],
[31,32,28,29,30,27],
[27,30,24,21],
[30,29,23,24],
[29,28,22,23],
[28,32,26,22],
[32,31,25,26],
[21,25,31,27]]
View this message in context: http://forum.openscad.org/polyhedron-and-a-cube-other-shapes-also-tp18852.html
Are you clicking F6? Some things (intersection?, difference?) seem to stop
the preview working, so you see nothing until you press F6.
want
goes
//handle gaourd
handle2 = -1;
handle1 = 6;
handle = -2;
leagth= -30;
leagth1= -2;
polyhedron(
points=[
[0,0,0], //0
[5,0,0], //1
[5,100,0], //2
[0,100,0], //3
[0,0,10], //4
[5,0,10], //5
[5,100,10], //6
[0,100,10], //7
[2.5,100,20],//8
[2.5,0,20],//9
[2.5,120,4.5],//10
[2.5,100,-10],//11
[2.5,0,-10], //12
[.5,leagth,5],//21
[4.5,leagth,5],//22
[1.5,leagth,0],//25
[3.5,leagth,0],//26
[.5,leagth1,5],//27
faces = [
[0,1,2,3], //bottom
[0,3,7,4], //left
[1,5,6,2], //right
[1,0,4,5], //front
[3,2,6,7], //back
[4,9,5], // back 2
[7,8,6], //front 2
[8,7,10], //tip
[10,2,6],
[10,6,8],
[1,2,11,12],//^^
[10,11,2],
[17,18,16,15],
[18,20,14,16],
[15,13,19,17],
//handle//
[27,30,24,21],
[30,29,23,24],
[29,28,22,23],
[28,32,26,22],
[32,31,25,26],
[21,25,31,27]]
yes i have bean using both f5 and f6 and both had not worked
On 1 November 2016 at 13:18, Frank van der Hulst drifter.frank@gmail.com
want
goes
//handle gaourd
handle2 = -1;
handle1 = 6;
handle = -2;
leagth= -30;
leagth1= -2;
polyhedron(
points=[
[0,0,0], //0
[5,0,0], //1
[5,100,0], //2
[0,100,0], //3
[0,0,10], //4
[5,0,10], //5
[5,100,10], //6
[0,100,10], //7
[2.5,100,20],//8
[2.5,0,20],//9
[2.5,120,4.5],//10
[2.5,100,-10],//11
[2.5,0,-10], //12
[.5,leagth,5],//21
[4.5,leagth,5],//22
[1.5,leagth,0],//25
[3.5,leagth,0],//26
[.5,leagth1,5],//27
faces = [
[0,1,2,3], //bottom
[0,3,7,4], //left
[1,5,6,2], //right
[1,0,4,5], //front
[3,2,6,7], //back
[4,9,5], // back 2
[7,8,6], //front 2
[8,7,10], //tip
[10,2,6],
[10,6,8],
[1,2,11,12],//^^
[10,11,2],
[17,18,16,15],
[18,20,14,16],
[15,13,19,17],
//handle//
[27,30,24,21],
[30,29,23,24],
[29,28,22,23],
[28,32,26,22],
[32,31,25,26],
[21,25,31,27]]
You polyhedron is not a manifold due to the inclusion of "internal" faces.
For instance, [0,1,2,3] is a internal face and should be removed but it is
not the only one.
View this message in context: http://forum.openscad.org/polyhedron-and-a-cube-other-shapes-also-tp18852p18855.html
